Ok, I decided to run smartctl following a FAQ. here is teh result:
_____________________________
empeg:/drive0/var# ./smartctl -s on /dev/hda
smartctl version 5.33 [arm-empeg-linux-gnu] Copyright (C) 2002-4 Bruce Allen
Home page is
http://smartmontools.sourceforge.net/=== START OF ENABLE/DISABLE COMMANDS SECTION ===
SMART Enabled.
empeg:/drive0/var# ./smartctl -l error /dev/hda
Home page is
http://smartmontools.sourceforge.net/=== START OF READ SMART DATA SECTION ===
SMART Error Log Version: 1
Warning: ATA error count 0 inconsistent with error log pointer 1
ATA Error Count: 0
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 0 occurred at disk power-on lifetime: 1 hours (0 days + 1 hours)
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
40 59 02 cf 2f 03 e0 Error: UNC at LBA = 0x00032fcf = 208847
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
20 00 02 cf 2f 03 e0 00 6d+09:12:50.107 READ SECTOR(S)
20 00 02 8c 00 00 e0 00 6d+09:12:50.100 READ SECTOR(S)
20 00 28 6c 48 00 e0 00 6d+09:12:50.086 READ SECTOR(S)
20 00 10 5a 48 00 e0 00 6d+09:12:50.083 READ SECTOR(S)
20 00 34 94 48 00 e0 00 6d+09:12:50.071 READ SECTOR(S)
Error -1 occurred at disk power-on lifetime: 0 hours (0 days + 0 hours)
When the command that caused the error occurred, the device was in an unknown state.
00 00 03 11 00 00 00
cf 1d 00 00 00 40 02 52 40d+04:43:35.599 [RESERVED]
cf 1d 00 00 00 00 02 51 40d+04:43:35.599 [RESERVED]
8c 1d 00 00 00 00 02 4f 27d+04:29:01.312 [VENDOR SPECIFIC]
3e 1d 00 00 00 00 02 4e 12d+00:58:38.465 WRITE DMA QUEUED FUA EXT
96 1d 00 00 00 00 02 41 29d+03:05:13.536 STANDBY [RET-4]
Error -2 occurred at disk power-on lifetime: 89 hours (3 days + 17 hours)
When the command that caused the error occurred, the device was in a vendor specific state.
59 00 00 00 03 11 00 at LBA = 0x00110300 = 1114880
40 c4 52 1d 00 00 00 e0 12d+10:16:34.818 READ VERIFY SECTOR(S)
00 c4 51 1d 00 00 00 e0 00:00:52.994 NOP [Reserved subcommand]
00 c4 4f 1d 00 00 00 e0 00:00:35.842 NOP [Reserved subcommand]
00 c4 4e 1d 00 00 00 e0 00:00:15.874 NOP [Reserved subcommand]
00 c4 40 1d 00 00 00 e0 00:00:38.402 NOP [Reserved subcommand]
Error -3 occurred at disk power-on lifetime: 3074 hours (128 days + 2 hours)
03 11 e0 59 00 00 03 Error:
00 03 e0 c4 ac 1f 00 2f 00:00:16.384 NOP [Reserved subcommand]
00 00 e0 c4 ab 1f 00 00 00:00:00.000 NOP [Abort queued commands]
00 00 e0 c4 a9 1f 00 01 00:00:00.000 NOP [Abort queued commands]
00 00 e0 c4 a8 1f 00 40 00:00:00.000 NOP [Abort queued commands]
00 00 e0 c4 9b 1f 00 59 00:00:00.000 NOP [Abort queued commands]
Error -4 occurred at disk power-on lifetime: 0 hours (0 days + 0 hours)
cf 00 2f 03 e0 59 00
27 cf 2f 03 e0 c4 f4 02 7d+18:11:42.208 READ NATIVE MAX ADDRESS EXT
27 8c 00 00 e0 c4 f3 02 7d+18:10:36.672 READ NATIVE MAX ADDRESS EXT
27 3e 01 00 e0 c4 f1 02 7d+18:08:25.600 READ NATIVE MAX ADDRESS EXT
27 96 40 00 e0 c4 f0 02 7d+18:07:20.064 READ NATIVE MAX ADDRESS EXT
27 0c 59 00 e0 c4 e9 02 7d+17:59:41.312 READ NATIVE MAX ADDRESS EXT
empeg:/drive0/var#
empeg:/drive0/var# ./smartctl -t short /dev/hda
Home page is
http://smartmontools.sourceforge.net/=== START OF OFFLINE IMMEDIATE AND SELF-TEST SECTION ===
Sending command: "Execute SMART Short self-test routine immediately in off-line mode".
Drive command "Execute SMART Short self-test routine immediately in off-line mode" successful.
Testing has begun.
Please wait 2 minutes for test to complete.
Test will complete after Wed Jul 6 21:54:08 2005
Use smartctl -X to abort test.
empeg:/drive0/var# ./smartctl -l selftest /dev/hda
Home page is
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Short offline Completed without error 00% 174 -
Home page is
ATA Error Count: 0
______________________________
I am now performing a loooong test.
However, how worried should I be?
