#248580 - 07/02/2005 03:58
Windows XP, Jreceiver and RioBoot - looking for alternate boots
I have a windows xp platform running jreceiver 0.2.5. using rioboot. Currently I am using rioplay .29a2 instead of reza's client, because its faster and doesnt hang up as much. Previously I had a linux server, and used trio - that machine crashed and burned, and due to work reasons, i can't go that route again. [i need the box this server is on to be a windows box.] My only real issue atm with rioplay is that it plays tracks in alphabetical order (not track number) and that there is no random button. [all the other limitations i can live with.] I do mis the receiver synch that trio had .. as i have 4 of these damn things  [used to be great when we threw parties] My questions are : 1) is there an alternate bootloader that I can use with rioboot that is fast, and will play tracks in the order they are reced from jrec or 2) is there any docs for using trio 1.6 with my config ? I noticed on the trio site that they say it doesn't work with rioboot atm. but there was some (very confusing looking) workaround .. is there a stepthrough, or does anyone have any experience with this ? I thank you all in advance.
#248581 - 07/02/2005 09:07
Re: Windows XP, Jreceiver and RioBoot - looking for alternate boots
[Re: rembrandt]
Why not use arm to boot the rios?
Before moving to linux/trio/jrec I had Windows/trio/arm, you'd just have Windows/trio/jrec/arm
Vince
Vince, UK
RioCar 20GB + 20GB, tuner & stalk, 5 x Audio Receivers
#248582 - 07/02/2005 11:56
[Re: rembrandt]
tRio can be made to play with RioBoot. When you expand the receiver.arf file that comes with the riot-x.y.z package on a Windows machine you'll get a load of errors. These are down to symbolic-links which aren't supported on either FAT or NTFS. The work around is to make multiple copies of the actual files and name them with the symbolic names.
For example, in the bin directory there appears to be 76 files but in fact there are only 6 files (bash, busybox, lcd, ldd, nc & sh), and 70 symlinks; all of which point to busybox. So, in this directory you need to make 70 copies of busybox and name them: basename, cat, chgrp, chmod, chmod, ..., etc. Do this for each of the directories and voila! It's a bit of a kludge but I can assure you it works. I've got this going on both XP and Windows 2003.
-DR
#248583 - 07/02/2005 12:09
[Re: drule]
Thats a pretty clever kludge  not being in front of the home computer atm .. how can i tell which is a file and whilch is a symlink ? and is there a better program to expand tar? i used winrar with the arf that came with the rio .. and it went nuts when i tried to connect to it.
#248584 - 07/02/2005 17:37
[Re: rembrandt]
WinRAR seems to do the job perfectly except for one error (see below). I originally untar'ed receiver.arf on a linux box and WinSCP'ed the files back over.
Looking at it again, I see that there's a symlink ../tftpboot/default/dev/core that points to /proc/kcore (this is where the WinRAR error occurs). That's /proc off the Linux root not the proc directory under tftpboot which is empty. I made a copy of /proc/kcore as ../tftpboot/default/dev/core and it works fine but I was just wondering what riot is using this file for since it is 270MB?
I'd like to post a zip of riot for RioBoot users but having to include this file would make it too big.
Cheers Dave
#248585 - 08/02/2005 00:36
[Re: drule]
OK .. with the arf set as default in my reioboot/tf* dir and with core put in /dev I can start up trio start up jreceiver and the nfs and portmapper software for rioboot
i can stream to winamp.
when i try to start my receiver .. i get looking fo server .. connectiong to server (the nfs goes nuts eventually rebooting with the following appearing in the nfs window.
im so close i can taste it.
et NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 4915 20 offset NFS read C:\Program Files\rioboot\tftpboot\Default\bin\sh,4096 bytes 4096 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 4956 16 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 4997 12 offset NFS read C:\Program Files\rioboot\tftpboot\Default\bin\sh,4096 bytes 8192 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 5038 08 offset NFS read C:\Program Files\rioboot\tftpboot\Default\bin\sh,4096 bytes 12288 offse t NFS lookup C:\Program Files\rioboot\tftpboot\Default\etc\ld.so.cache NFS lookup C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6 NFS read C:\Program Files\rioboot\tftpboot\Default\bin\sh,4096 bytes 114688 offs et NFS read C:\Program Files\rioboot\tftpboot\Default\bin\sh,4096 bytes 118784 offs et NFS read C:\Program Files\rioboot\tftpboot\Default\bin\sh,4096 bytes 122880 offs et NFS read C:\Program Files\rioboot\tftpboot\Default\bin\sh,4096 bytes 126976 offs et NFS read C:\Program Files\rioboot\tftpboot\Default\bin\sh,4096 bytes 131072 offs et NFS read C:\Program Files\rioboot\tftpboot\Default\bin\sh,4096 bytes 135168 offs et NFS read C:\Program Files\rioboot\tftpboot\Default\bin\sh,4096 bytes 139264 offs et NFS read C:\Program Files\rioboot\tftpboot\Default\bin\sh,4096 bytes 143360 offs et NFS read C:\Program Files\rioboot\tftpboot\Default\bin\sh,4096 bytes 81920 offse t NFS read C:\Program Files\rioboot\tftpboot\Default\bin\sh,4096 bytes 86016 offse t NFS read C:\Program Files\rioboot\tftpboot\Default\bin\sh,4096 bytes 90112 offse t NFS read C:\Program Files\rioboot\tftpboot\Default\bin\sh,4096 bytes 94208 offse t NFS read C:\Program Files\rioboot\tftpboot\Default\bin\sh,4096 bytes 147456 offs et NFS read C:\Program Files\rioboot\tftpboot\Default\bin\sh,4096 bytes 151552 offs et NFS read C:\Program Files\rioboot\tftpboot\Default\bin\sh,4096 bytes 155648 offs et NFS read C:\Program Files\rioboot\tftpboot\Default\bin\sh,4096 bytes 159744 offs et NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 6062 08 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 6103 04 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 6144 00 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 6184 96 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 5898 24 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 5939 20 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 5980 16 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 6021 12 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 8355 84 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 8396 80 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 8437 76 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 8478 72 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 2949 12 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 2990 08 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 3031 04 offset NFS read C:\Program Files\rioboot\tftpboot\Default\bin\sh,4096 bytes 65536 offse t NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 3072 00 offset NFS read C:\Program Files\rioboot\tftpboot\Default\bin\sh,4096 bytes 69632 offse t NFS read C:\Program Files\rioboot\tftpboot\Default\bin\sh,4096 bytes 73728 offse t NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 3112 96 offset NFS read C:\Program Files\rioboot\tftpboot\Default\bin\sh,4096 bytes 77824 offse t NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 3194 88 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 3235 84 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 3153 92 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 5734 40 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 5775 36 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 5816 32 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 2785 28 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 5857 28 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 2826 24 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 2867 20 offset NFS lookup C:\Program Files\rioboot\tftpboot\Default\etc\fstab NFS read C:\Program Files\rioboot\tftpboot\Default\etc\fstab,4096 bytes 0 offset
NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 2908 16 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 2457 60 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 3768 32 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 2498 56 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 2539 52 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 3809 28 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 2580 48 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 3850 24 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 3891 20 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 2621 44 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 6389 76 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 2662 40 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 2703 36 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 6430 72 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 2744 32 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 6471 68 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 6512 64 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 6553 60 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 6594 56 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 6635 52 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6,4096 bytes 6676 48 offset NFS lookup tftpboot\Default\proc NFS lookup tftpboot\Default\sbin NFS lookup C:\Program Files\rioboot\tftpboot\Default\sbin\test NFS lookup C:\Program Files\rioboot\tftpboot\Default\bin\sh NFS lookup C:\Program Files\rioboot\tftpboot\Default\lib\ld-linux.so.2 NFS lookup C:\Program Files\rioboot\tftpboot\Default\etc\ld.so.preload NFS lookup C:\Program Files\rioboot\tftpboot\Default\etc\ld.so.cache NFS lookup C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6 NFS lookup C:\Program Files\rioboot\tftpboot\Default\sbin\riot NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 0 offset
NFS lookup C:\Program Files\rioboot\tftpboot\Default\lib\ld-linux.so.2 NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 458752 o ffset NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 462848 o ffset NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 466944 o ffset NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 471040 o ffset NFS lookup C:\Program Files\rioboot\tftpboot\Default\etc\ld.so.cache NFS lookup C:\Program Files\rioboot\tftpboot\Default\lib\libpthread.so.0 NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libpthread.so.0,4096 byte s 0 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libpthread.so.0,4096 byte s 4096 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libpthread.so.0,4096 byte s 8192 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libpthread.so.0,4096 byte s 12288 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libpthread.so.0,4096 byte s 65536 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libpthread.so.0,4096 byte s 69632 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libpthread.so.0,4096 byte s 73728 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libpthread.so.0,4096 byte s 77824 offset NFS lookup C:\Program Files\rioboot\tftpboot\Default\lib\libm.so.6 NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libm.so.6,4096 bytes 0 of fset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libm.so.6,4096 bytes 4096 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libm.so.6,4096 bytes 8192 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libm.so.6,4096 bytes 1228 8 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libm.so.6,4096 bytes 1474 56 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libm.so.6,4096 bytes 1515 52 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libm.so.6,4096 bytes 1556 48 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libm.so.6,4096 bytes 1597 44 offset NFS lookup C:\Program Files\rioboot\tftpboot\Default\lib\libc.so.6 NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libm.so.6,4096 bytes 1638 4 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libm.so.6,4096 bytes 2048 0 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libm.so.6,4096 bytes 2457 6 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libm.so.6,4096 bytes 2867 2 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libpthread.so.0,4096 byte s 49152 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libpthread.so.0,4096 byte s 53248 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libpthread.so.0,4096 byte s 57344 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libpthread.so.0,4096 byte s 61440 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libm.so.6,4096 bytes 1146 88 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libm.so.6,4096 bytes 1187 84 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libm.so.6,4096 bytes 1228 80 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libm.so.6,4096 bytes 1269 76 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libpthread.so.0,4096 byte s 16384 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libpthread.so.0,4096 byte s 20480 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libpthread.so.0,4096 byte s 24576 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libpthread.so.0,4096 byte s 28672 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libpthread.so.0,4096 byte s 32768 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libpthread.so.0,4096 byte s 36864 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libpthread.so.0,4096 byte s 40960 offset NFS read C:\Program Files\rioboot\tftpboot\Default\lib\libpthread.so.0,4096 byte s 45056 offset NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 4096 off set NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 8192 off set NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 12288 of fset NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 262144 o ffset NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 266240 o ffset NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 270336 o ffset NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 274432 o ffset NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 65536 of fset NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 69632 of fset NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 73728 of fset NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 77824 of fset NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 278528 o ffset NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 282624 o ffset NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 286720 o ffset NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 290816 o ffset NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 16384 of fset NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 20480 of fset NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 24576 of fset NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 28672 of fset NFS lookup C:\Program Files\rioboot\tftpboot\Default\dev\display NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 327680 o ffset NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 331776 o ffset NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 335872 o ffset NFS read C:\Program Files\rioboot\tftpboot\Default\sbin\riot,4096 bytes 339968 o ffset
#248586 - 08/02/2005 02:10
[Re: rembrandt]
i should also note .. I also tried using ARM/Jrec and trio I get this error after the rio boots into Trio
SSDP Discovery of jreceiver failed"
in my jrec window i get : ... 5453 [RioStatusDaemon] WARN status.RioStatusDaemon - socket problem with rio st atus java.net.BindException: Address already in use: Cannot bind at java.net.PlainDatagramSocketImpl.bind(Native Method) at java.net.DatagramSocket.bind(Unknown Source) at java.net.DatagramSocket.<init>(Unknown Source) at java.net.DatagramSocket.<init>(Unknown Source) at java.net.DatagramSocket.<init>(Unknown Source) at jreceiver.client.rio.status.RioStatusDaemon.doWork(RioStatusDaemon.ja va:229) at jreceiver.util.Daemon$1.run(Daemon.java:94) at java.lang.Thread.run(Unknown Source) 5547 [RioSSDP] ERROR status.RioSSDP - unrecoverable IO problem, stopping worker
java.net.BindException: Address already in use: Cannot bind at java.net.PlainDatagramSocketImpl.bind(Native Method) at java.net.DatagramSocket.bind(Unknown Source) at java.net.DatagramSocket.<init>(Unknown Source) at java.net.DatagramSocket.<init>(Unknown Source) at java.net.DatagramSocket.<init>(Unknown Source) at jreceiver.client.rio.status.RioSSDP$1.run(RioSSDP.java:153) at java.lang.Thread.run(Unknown Source
I get this when i try to request music lists to queue
#248587 - 08/02/2005 12:01
[Re: rembrandt]
Regarding the SSDP discovery of jreceiver error. Did you remember to install the jreceiver-rio-0.2.5 component? The install instructions are near the bottom of the JReceiver: Rio Install page and are easily missed.
Dave
#248588 - 08/02/2005 12:11
[Re: drule]
yeah
turns out the arm/jrec/trio error was an ip conflict (somehow) in my conf file for jrec i changed the references that were localhost:8080 to the actual ip of the box .. and that stopped the arm/jrec errors.
haven't had the courage to get back at rioboot :P but the day is still young
#248589 - 16/02/2005 02:11
[Re: drule]
Quote: WinRAR seems to do the job perfectly except for one error (see below). I originally untar'ed receiver.arf on a linux box and WinSCP'ed the files back over.
I use gnu tar myself. It recreates the symlinks, though neither Windows nor Java understands them - at least they're easy to track down with "find" or whatever.
No, no, no...
/proc/kcore isn't really a file. It's a view of the ram on the current system. It only exists at runtime. Since I couldn't symlink to it, I just left /dev/core out. I haven't noticed a problem.
If there were a problem, it wouldn't be solved by copying a ram snapshot off a LInux box anyway.
As for all the busybox copies, I suspect riot doesn't use most of them either. Might be worth narrowing it down a bit to save space - all those copies do add up. I haven't bothered since it doesn't really hurt anything.
Problem solved?
I used to post these periodically but I've gotten lazy. I'm still running a post 1.5 beta myself - not something I should share. I'll post one if I ever catch up with the current release and there's still a need but if you have one handy you should definitely go for it.
#248590 - 16/02/2005 12:38
[Re: justDave]
Problem solved indeed. Thanks for the info on /proc/kcore. Us Linux newbies learn something new everyday. I will zip up a RioBoot version of tRio 1.6 and make it available.
-DR
