#244693 - 27/12/2004 01:16 I broke my empeg... again...
thedon
My car was in the shop, so I figured I'd treat myself to a little empeg upgrading... Decided to throw on Amursfoot (sp?) build of 3.0 (Alpha 8, right?)...
The upgrade took, literally, hours to complete... (Maybe around 4?)
The part that took the lion's share of the time was the "pumping partition" part...
When I connected hyperterminal during boot it seems to hang at the following:
Freeing unused kernel memory: 4k initBUG IN DYNAMIC LI
Anyone know what BUG IN DYNAMIC LI means? Is that even a complete error code, or did it break before it finished spitting it out...?
I seem to remember having "pumping partition problems" many other times... I replaced this hard drive a few months ago (in case some of you were thinking that might be it). But in all fairness, I somehow also remember that everytime I had this problem, putting a new HDD in solved it... This empeg has seen at LEAST 5 drives in 2 years, however... I'm too broke and too disapointed to want to believe it's yet ANOTHER dead HDD... Yes, I've tried ALL differant brands/sizes of disks in case you were wondering...
Can anyone offer me any suggestions?
You guys are usually right on top of things... Hoping it's just one of my haven't-done-it-in-a-while-so-i-forgot-something-stupid errors...
Thanks in advance guys!
Joey DIJulio
#244694 - 27/12/2004 02:31 Re: I broke my empeg... again... [Re: thedon]
Post the full log. Every Hyperterminal capture I see from a player booting seems to get totally munged and missing characters so that "half" error might be due to that.
Post the whole log and if you can get something like TeraTerm or CRT use it instead.
You can also try the upgrade again. It can't hurt doing it twice or even 100 times.
Edit:
4 hours is very long for an upgrade. A dodgy drive could esaily slow down the pump process. It takes a while but maybe 10-15 minutes and not 4 hours.
Edited by Shonky (27/12/2004 02:32)
#244695 - 27/12/2004 02:37 Re: I broke my empeg... again... [Re: Shonky]
thedon
Maaaaaaan... I REALLY don't want another dead drive...
Here is the full (allbeit hyperterminal based) dump...
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg55 (peter@tatu) (gcc version 2.95.3 20010315
(release)) #12 Wed Jul 7 18:19:57 BST 2004
empeg-car player (hardware revision 9, serial number 10101193)
Command line: mem=16m
POSIX conformance testing
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
ttyS00 at 0xf8010000 (irq = 15) is a
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005380).
empeg RDS driver initialised
empeg power-pic driver initialised (
empeg single channel IDE
Probing primary interface...
hda: TOSHIBA MK3017GAP, ATA DISK drive
hda: TOSHIBA MK3017GAP, 28615MB w/0kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:04:a
9
Partition check:
empeg-pump v0.03 (19980601)
#244696 - 27/12/2004 02:52 Re: I broke my empeg... again... [Re: thedon]
The hyperterminal capture looks OK and there aren't any errors which point to it being a drive problem either.
Might be best to go back to 2.00 final. First thing I'd try is another upgrade but to 2.00 final instead. If that's OK, then try 3.0a8 (which I've had no major problems with).
The error might be something like "BUG IN DYNAMIC LINK LIBRARY" or something like that. It's definitely not a complete error. I grepped the kernel source for for the string and didn't find anything and it doesn't appear the player has started yet, so I'm not sure where it's coming from.
I assume you can't Ctrl-C and get a terminal prompt or anything like that?
In absence of any other ideas, try the upgrade (or downgrade really) again.
#244697 - 27/12/2004 02:56 Re: I broke my empeg... again... [Re: Shonky]
thedon
Man... It's been some time... I didn't even think of the control-c.... I figured it would be dynamic link library, but wasn't positive... but if a grep of the kernel yeilded nothing - then i REALLY am clueless as to what it might be... I'll try the downgrade to 2.00 final and see how that goes... I'll report back in a few
Wish me luck!
Joey
#244698 - 27/12/2004 03:50 Re: I broke my empeg... again... [Re: thedon]
genixia
Verify hard drive cable isn't loose and all the other FAQed 'No Hard drive found' causes. You might also want to verify the integrity of the build that you used somehow, although the 4 hour upgrade does suggest a hardware issue.
#244699 - 27/12/2004 04:38 Re: I broke my empeg... again... [Re: genixia]
I agree it's worth checking the cables etc although the boot log doesn't seem to show any problems with detecting the drive. Not that that is definitive of course.
We'll see how the upgrade goes. Any ideas where the error could come from? About the only other place is the bootloader that I can think of.
#244700 - 27/12/2004 09:28 Re: I broke my empeg... again... [Re: Shonky]
thedon
okay... well, it took a few more hours... again...
Then, it booted up, hung on the Rio Digital Audio screen... and Hyperterminal LIT up...
Scrolling (like in an edless loop) garbage to the effect of...
Function entered at [<4006d324>] from [<40063f5c>]0000d at [<40063ee4>] from [<020009b8>]9 : 02000a4
r4 = BFFFFF24 : 4004c000 r
Function entered at [<40063ee4>] from [<020009b8>]00000 r7 = 00000000 : bffffe9c ip : bffffebc f
r10 = 4001D858 r9 = 00000000 r8 = 00000000 r7 = 00000000 r4 = 4001E5EC02000a48 r8 : 0200158c B
r10 = 4012C1
Contro
r6 = 02000994 r5 = 00000000 r4 = 4001E5ECfffffe8, code 00000 r4 :
Function entered a
init: permission fault on section, address=0xffffffe8, code 0009aee8>]12b644 r1
r4 = BFFFFF24: 00000
r10 = 4012C128 r
pc : [<400558d4>] lr : [<4009aee8>]000
Flags: nzCv IRQs on FIQs on
r10
sp : bffffe9c ip : bffffebc fp : bffffeb8t [<4006d358>] from [<4006d338>], co
Co
r7
r10: 4012c128 r9 : 02000a48 r8 : 0200158c = 4012C128 r5 = 00000001 r4 = 4000C2A801
r7 : 0200077c r6 : 4000c2a8 r5 : 00000000 r4 : 00000000d at [<4006d324>] from ,
r6 = 02000994 r5 = 00000000 r4 = 4001E5EC= 00000000 r7 = 000000004
r4 = B
r10 = 40
init: permission fault on section, address=0xffffffe8, code 0 00000000 r4 = 4
Function en
pc : [<400558d4>] lr : [<4009aee8>] = 0
sp : bffffe9c ip : bffffebc fp : bffffeb8 r4 = 4000C2A8 0200077c r6 : 4000c2a8 r5
r10: 4012c128 r9 : 02000a48 r8 : 0200158c324>] from [<40063f5c>]on, address=0xff
r3
Fla
r3 : 4004c000 r2 : 4012b644 r1 : 4006d404 r0 : 00000188 r9 = 00000000 r8 = 00000000 r7 = 000000008>]5EC2
Contr
Flags: nzCv IRQs on FIQs on Mode USER_32 Segment user0994 r5 = 00000000 r4 = 4001E5EC:
Control: C0FA517D Table: C0FA517D DAC: 00000 section,
r7 : 0200077c r6 : 4000c2a8 r5 : 00000000 r4 : 00000000tered at [<40063ee4>] from [<020009b8>]4000c2a8 r5 : 0000
r3 : 4004c000 r2 : 4012b644 r1 : 4006d404 r0 : 00000188000 r8 = 00000000 r7 = 00000000 r2 : 4012b644 r1 : 4006
Flags: nzCv IRQs on FIQs on Mode USER_32 Segment user0000000 r4 = 4001E5ECags: nzCv
Control: C0FA517D Table: C0FA517D DAC: 00000015ss=0xffffffe8, code 0077c r6 : 4000c2a8 r5 : 00
Function entered at [<4009aeb4>] from [<4006d404>] lr : [<4009aee8>]000 0
F
r10 = 4012C128 r6 = 4000C2A8 r5 = 00000000 r4 = 00000000d358>] from [<4006d338>]4012C128
Function entered at [<4006d358>] from [<4006d338>] 4000C2A801
r10 = 4012C128 r5 = 00000001 r4 = 400m , 58d4>] lr
Function entered at
r6 = 02000994 r5 = 00000000 r4 = 4001E5ECode 0: 4006d404
Function entered
r10 = 4
init: permission fault on section, address=0xffffffe8, code 0 on FIQs on
r4 = BFFFFF24 Segment u
sp : bffffe9
Function e
pc : [<400558d4>] lr : [<4009aee8>]]trol: C0FA517D Table:
r10: 4012c128
sp : bffffe9c ip : bffffebc fp : bffffeb8 r4 = 4000C2A8000000on enter
r7 : 0200077c
r10: 4012c128 r9 : 02000a48 r8 : 0200158cd324>] from [<40063f5c>] r4 = 4001E5EC2C12
r7 : 0200077c r6 : 4000c2a8 r5 : 00000000 r4 : 000000004
Function entered at [<40063ee4>] from [<020009b8>]tion e
pc : [<400558d4>] lr : [<4009aee8>]58>] from [<4006d338>]ER_32 Segment u
sp : bffffe9c ip : bffffebc fp : bffffeb812C128 r5 = 00000001 r4 = 4000C2A8Table:
r10: 4012c128 r9 : 02000a48 r8 : 0200158cion entered at [<4006d324>] from [<40063f5c
r7 : 0200077c r6 : 4000c2a8 r5 : 00000000 r4 : 00000000BFFFFF24 : 0200158c0 =
sp
Flags: nzCv IRQs on FIQs on Mode USER_32 Segment user48 r8 : 02
r6 = 02000994 r5 = 00000000 r4 = 4001E5EC0
Control: C0FA517D Table: C0FA517D DAC: 00000015permission fault on section, address=0xffffffe8,
r4 = BFFFFF24
Flags
r4 = BFFFFF24 FIQs on Mod
Function entered at [<40063ee4>] from [<020009b8>]r5
r10: 4012c128
sp : bffffe
Control: C0FA517D T
r10 = 4001D858 r9 = 00000000 r8 = 00000000 r7 = 00000000012c128 r9 : 020
r6 = 02000994 r5 = 00000000 r4 = 4001E5ECc2a8 r5 : 00
init: permission fault on section, address=0xffffffe8, code 0 r2 : 4012b644 r1 : 4006d4
r10 = 4
r6 = 02000994 r5 = 00000000 r4 = 4001E5EC r4 : 00000000: 4
F
init: permission fault on section, address=0xffffffe8, code 0: 4006d404 r0 : 0000018824 FIQs
pc : [<400558d4>] lr : [<4009aee8>]s on FIQs on Mode USER_32 Segmen
r
sp : bffffe9c ip : bffffebc fp : bffffeb8000000 r7 = 000
r10: 4012c128 r9 : 02000a48 r8 : 0200158c063f5c>]4 r5 = 00000000 r4
Function enter
r7 : 0200077c r6 : 4000c2a8 r5 : 00000000 r4 : 00000000ed at [<40063ee4>] from [<020009b8>]012C128 r6 = 4000C2A8
r3 : 4004c000 r2 : 4012b644 r1 : 4006d404 r0 : 00000188 r8 = 00000000 r7 = 00000000
r10 = 4012C128 r5 = 00000001 r4 = 4000C2A8 0200077c r6 : 4000c2a8 r5 : 00000000 r4 :
Function entered at [<4006d324>] from [<40063f5c>]on, address=0xff
r4 = BFFFFF24: 0000018810 =
r10 = 4001D858 r9 = 00000000 r8 = 00000000 r7 = 000000008>]]EC2
Control: C0FA517D Table: C0FA517D DAC: 00000015c =
r6 = 02000994 r5 = 00000000 r4 = 4001E5EC:
r10 = 4012C128 r5 = 00000001 r4 = 4000C2A8 r7 = 00000000] from [<020009b8>] : bfff
r7
Function entered at [<4006d324>] from [<40063f5c>]000000000 r4 = 4001E5ECd338>]ser09b8>]= 000000004
Function entered at [<40063ee4>] from [<020009b8>]: 00000015= 00000
r10 = 4001D858 r9 = 00000000 r8 = 00000000 r7 = 00000000012c128 r9 : 02000a48 r8
Contro
init: permission fault on section, address=0xffffffe8, code 0077c r6 : 4000c2a8 r5 : 00000000 r4 : 0
r10 = 4012C128 r
Fla
Contr
r10 = 40
init: permission fault on section, address=0xffffffe8, code 0 00000000 r4 = 400
Function en
pc : [<400558d4>] lr : [<4009aee8>] = 00000000=0xffffffe8, code 0a48 r
F
sp : bffffe9c ip : bffffebc fp : bffffeb8 r4 = 4000C2A800000 r4 = 4001E5EC: [<4009a
r10: 4012c128 r9 : 02000a48 r8 : 0200158c324>] from [<40063f5c>] 00000015ss=0xffffff
r7 : 0200077c r6 : 4000c2a8 r5 : 00000000 r4 : 0000000001E5ECaeb4>] from [<4006d404>] lr : [
init: permission
r3 : 4004c000 r2 : 4012b644 r1 : 4006d404 r0 : 00000188 00000000 r4 = 00000000d358>] from [<4006d338
pc : [<4005
Flags: nzCv IRQs on FIQs on Mode USER_32 Segment user] from
sp : bffffe9c ip : bffffebc fp : bffffeb84000c2
Control: C0FA517D Table: C0FA517D DAC: 00000c128 r9 : 02000a4 lr
sp : bfff
r10: 4012c128 r9 : 02000a48 r8 : 0200158c0 r8 = 00000000 r7 = 00000000015C10: 4012
r7 : 0200077c r6 : 4000c2a8 r5 : 00000000 r4 : 000000000994 r5 = 00000000 r4 = 4001E5ECode 04000c2a8 r5 : 0000
r3 : 4004c000 r2 : 4012b644 r1 : 4006d404 r0 : 00000188ress=0xffffffe8, code 000004c000 r2 : 4012b644 r1 : 4006
Flags: nzCv IRQs on FIQs on Mode USER_32 Segment user9aee8>]m [<4006d338>]lags: nzCv
r10: 4012c128
sp : bffffe
Control: C0FA517D Table: C0FA517D DAC: 00000015= 4000C2A8
r7 : 0200077c
Function entered at [<4009aeb4>] from [<4006d404>]3f5c>]om [<0
r10 = 4012C128 r6 = 4000C2A8 r5 = 00000000 r4 = 0000000063ee4>] from [<020
Function entered at [<4006d358>] from [<4006d338>]= 00000000 r7 = 0000000
r6 = 02000994 r5 = 00000000 r4 = 4001E5EC02000a48 r8 : 0200158cio
r10 = 4012C128 r
init: permission fault on section, address=0xffffffe8, code 00000 r4 :
pc : [<400558d4>] lr : [<4009aee8>]12b644 r1
r4 = BFFFFF24: 00000188C:
sp : bffffe9c ip : bffffebc fp : bffffeb820009b8>]7 =
r10: 4012c128 r9 : 02000a48 r8 : 0200158c000 r8 = 00000000 r7 = 0000000001E5EC2
Co
r7 : 0200077c r6 : 4000c2a8 r5 : 00000000 r4 : 00000000000994 r5 = 00000000 r4 = 4001E5EC
Function entered at
r3 : 4004c000 r2 : 4012b644 r1 : 4006d404 rn section, 58d4>] lr
r
init: permission fault on section, address=0xffffffe8, code 0[<40063ee4>] from [<020009b8>]9 : 02000a4
r4 = BFFFFF24 : 40
pc : [<400558d4>] lr : [<4009aee8>]4>] from [<020009b8>]00000 r7 = 00000
sp : bffffe9c ip : bffffebc fp : bffffeb81D858 r9 = 00000000 r8 = 00000000 r7 = 0
r10: 4012c128 r9 : 02000a48 r8 : 0200158cfe9c ip : b
r1
Contro
r6 = 02000994 r5
r7 : 0200077c r6 : 4000c2a8 r5 : 00000000 r4 : 000000000a48 r8 :
r3 : 4004c000 r2 : 4012b644 r1 : 4006d404 r0 : 0000018810 = 4012C128 r
Flags: nzCv IRQs on FIQs on Mode USER_32 Segment userfffebc fp : bffffeb8t [<4006d358>] from [<4006d338>], co
Control: C0FA517D Table: C0FA517D DAC: 00000015c = 4012C128 r5 = 00000001 r4 = 4000C2A8e4
r7 :
Function entered at [<4009aeb4>] from [<4006d404>]000d at [<4006d324>] from
Functio
r10 = 4012C128 r5 = 00000001 r4 = 4000C2A8 DAC: 00000015 r4 = 4001E5ECffffe9c ip : bff
Function entered at [<4006d324>] from [<40063f5c>] from [<4006d404>]s=0xffffffe8, code 0a48 r8
sp
r4 = BFFFFF24: b
r10 = 401
Function entered at [<40063ee4>] from [<020009b8>]09aee8>] 4012c128 r9 : 02000a48 r8 : 0200
r
sp
r10 = 4001D858 r9 = 00000000 r8 = 00000000 r7 = 000000004000c2a8 r5 : 0000000
r10 = 401
r6 = 02000994 r5 = 00000000 r4 = 4001E5EC4c00
Function
init: permission fault on section, address=0xffffffe8, code 0d4
Flags: nzCv
r3 : 4004c000
r4 = BFFFFF24 r1 : 4006d404
F
pc : [<400558d4>] lr : [<4009aee8>]020009b8>] 4000c2
Control: C0FA5
Flags
sp : bfff
r10: 4012c1
Function entered at [<4009aeb4>] from [<4006d404>] [<40063ee4>] from [<020
r10 = 4012C128 r6 = 4000C2A8 r5 = 00000000 r4 = 00000000<020009b8>]00000 r7 = 0000000
Function entered at [<4006d358>] from [<4006d338>] = 00000000 r4 = 4001E5EC r1 : 4006
Flags: nzCv
r10 = 4012C128 r5 = 00000001 r4 = 4000C2A800000 r4 = 4001E5ECfffffe8, code 0 on FIQs
Function entered at [<4006d324>] from [<40063f5c>] 00000015ss=0xffffffe8, code 0009aee8>]ntrol: C0FA
r4 = BFFFFF24on entered at
Function entered a<4006d404>] lr
init: permission fault on section, address=0xffffffe8, code 06 = 4000C2A8 r5 = 00000000 r4 = 00000000d358>] from [<4006d
sp : bffffe9c ip : bffffebc fp : bffffeb8 : 4000c2a8 r5 : 000
r10 = 4012C128 r5 =
r10: 4012c128 r9 : 02000a48 lr
r10 = 4
init:
Function entered at [<4009aeb4>] from [<4006d404>]de 0 on FIQs on Mode USER_32 Segmen
r
sp : bff
r10 = 4012C128 r6 = 4000C2A8 r5 = 00000000 r4 = 00000000C0FA517D Table:
r10: 4012c128
Function entered at [<4006d358>] from [<4006d338>]200077c
r10 = 4012C128 r5 = 00000001 r4 = 4000C2A87 : 0200077c r6 : 4000c2a8 r5 : 00000000 r
Function entered at [<4006d324>] from [<40063f5c>] [<020009b8>]tion e
r4 = BFFFFF24r
Function entered at [<4009aeb4>] from [<4006d404>]0 = 0000000040
r10 = 4012C128 r6 = 4000C2A8 r5 = 00000000 r4 = 00000000[<4006d338>]000c2a8 r5 : 00
Function entered at [<4006d358>] from [<4006d338>]: 40
Function entered at [<4006d324>] from [<40063f5c>] [<40063ee4>] fr
r4 = BFFFFF24: 00000188C: 0
Function entered at [<40063ee4>] from [<020009b8>]7 =
r10 = 4001D858 r9 = 00000000 r8 = 00000000 r7 = 0000000001E5EC2
init: permission fault on section, 58d4>] lr
r10 = 4012C128 r5 = 00000001 r4 = 4000C2A8f5c>]000001884>] from [<020009b8>] : bfff
r7
Function entered at [<4006d324>] from [<40063f5c>]0000d at [<40063ee4>] from [<020009b8>]= 000000006
Function entered at [<40063ee4>] from [<020009b8>]00000 r7 = 00000000E5EC 4004c000 r2 : 4012b644
r10 = 4001D858 r9 = 00000000 r8 = 00000000 r7 = 00000000 r4 = 4001E5ECode 0a48 r
Flags
Function entered
r1
Contro
r6 = 02000994 r5 = 00000000 r4 = 4001E5ECfffffe8, code 04012c128
sp
r4 = BFFFFF24l:
init: permission fault on section, address=0xffffffe8, code 0009aee8>]]0012c128 r9 : 020
Func
r10: 401
r10 = 4012C128 r
pc : [<400558d4>] lr : [<4009aee8>]0002A8000000E5ECc2a8
r7 : 0200077c
r10
sp : bffffe9c ip : bffffebc fp : bffffeb8t [<4006d358>] from [<4006d338>]5ECode
r7
r10: 4012c128 r9 : 02000a48 r8 : 0200158c = 4012C128 r5 = 00000001 r4 = 4000C2A8e4
r4 = BFFFFF24
r3 : 4004c000 r2
Oh my... Any ideas?
Also, if an upgrade is taking forever, I wanted to know if it is SAFE (with 100% certainty) to just pull the power on the empeg, to reseat cables, etc and start all over? Or could that render my empeg inoperable? (Meaning I should just wait it out and then try again 4 hours later... Just seems like a long time to wait for nothing...)
I'll try reseating cables now in the meantime...
Thanks,
Joey
#244701 - 27/12/2004 09:48 Re: I broke my empeg... again... [Re: thedon]
All of that "garbage" is something crashing. For that to happen you've got dodgy hardware somewhere.
The empeg should handle this fine. Absolute worse case could be corrupting the harddrives if they were read/write when you pull the plug. And worst case result of that would be reformatting the drives and reloading your music.
Basically you can't render it inoperable since the bootloader will always let you recover. I would have no problem doing it myself.
If you can get to a shell prompt (and it would seem you can't), I'd suggest an fsck of the drives
#244702 - 27/12/2004 09:54 Re: I broke my empeg... again... [Re: Shonky]
thedon
Okay, we'll I'm trying once again... I took the empeg apart, made sure the cables were nice n' firmly connected... Giving it another whirl...
I'm curious though, and maybe this is s stupid question... But this could all be due to a bad cable couldn't it? I ask because I'm starting to wonder if I *really* had five (5) bad hard drives or maybe just one (1) bad cable... How would I go about getting a replacement cable if this indeed is the throne in my side...
Or any other ideas are good to...
Joey
#244703 - 27/12/2004 10:06 Re: I broke my empeg... again... [Re: thedon]
Yes very good chance it could be a cable. It would definitely be worth trying. It looks like you only have one drive. If so simply try the other connector on the cable.
Drive errors usually look a little bit different since the drive won't even let the empeg read the data if they know they're dieing and reports bad sector reads etc. In your case data is getting corrupted somewhere. This could be in any number of places:
The drive
The drive cable
The empeg RAM
etc and also any connections PCB, cables etc in between.
You can get cables from Eutronix (link at the top) or I believe Rob Schofiel (schofiel on the BBS) is offering them soon (if not already).
#244704 - 27/12/2004 10:09 Re: I broke my empeg... again... [Re: thedon]
Also, read this if you haven't already.
All those things can apply to your situation.
#244705 - 27/12/2004 10:22 Re: I broke my empeg... again... [Re: Shonky]
thedon
Haha... Yep, that picture looks JUST like my cable...
Funny part is - The cable I have now IS a replacement cable sent to me by empeg support many moons ago, hmmm...
I guess I'm just rough of my gear. Or maybe its the two 15" subs... Or maybe it's both... For my sake/sanity, I should just stick with buying everything "industrial"... I have a horrible habbit of breaking everying <insert argument for better/stronger/hardend built products> I buy, so maybe I shouldn't be surprised....
I'll go ahead and see about getting a new cable and see what happens... Although, my eye has wandered over to the "pumping partition" window on my third go at it (after reseating my bad cable and using the other connector) and lo' and behold it appears to be going a bit faster...
Hmmm... I'll cross my fingers and maybe get a new cable as reassurance...
Thanks for all the help Shonky
Joey
PS: I haven't had my eye on the forum that much lately... Any talk about a Beta (or even a new Alpha if I dare ask) for v3?
I guess when Trillian (my IM app of choice) started revving up and finally released their highly anticipated v3 (Alpha, Beta, and Final) of their software I pig-headedly assumed that I'd find something going on with the v3 work for the empeg... Maybe not? Maybe not where I've been looking?
#244706 - 27/12/2004 20:08 Re: I broke my empeg... again... [Re: Shonky]
mcomb
Loc: San Carlos, CA
Yeah, what he said. I'd try a RAM test next (search the faq for "ctrl-t" for directions)?
-Mike
#244707 - 28/12/2004 01:51 Re: I broke my empeg... again... [Re: mcomb]
It's an easy test to do but I don't ever recall anyone ever finding dodgy RAM during that test. I would expect RAM to die early in it's life OR last a long time.
Can't hurt to try and faulty RAM could easily cause these sorts of problems. I doubt he would have got that far into the upgrade if the RAM was faulty though.
