#243333 - 05/12/2004 15:17
empeg not holding settings, please help!!!
Hello, my empeg (MK2A) is giving me a headache. I just installed it in a 03 Tahoe after it sat on the shelf for 3 months. When I first powered it on it said "Player Settings Lost" and would continue to do this on every boot until I performed a reboot through Hijack. It now seems to boot up correctly but all settings are lost, (clock, current song, volume, etc.) I opened up the unit and checked the super cap on the board and it was 3.42V. Is this the source of my problems? How does the memory system work? I have constant power wired up to the sled as well as switched. Any help would be greatly appreciated.
Nick
#243334 - 05/12/2004 15:42
Re: empeg not holding settings, please help!!!
[Re: farmtech]
The cap is just used for the RTC. The actual settings are stored in flash which doesn't need any power to retain the data. As to why you lost the settings *shrug* it shouldn't have worn out yet unless you've been sitting there rebooting it a few million times. Something must have corrupted the setting.
#243335 - 05/12/2004 17:04
[Re: tman]
Quote: Something must have corrupted the setting.
Agreed. First thing is you need to apply a fresh build of 2.0 final software, pure, and see if that solves the problem.
#243336 - 05/12/2004 17:58
Ok, I will give that a try and let you know what happens.
Thanks.
#243337 - 05/12/2004 21:20
[Re: farmtech]
Ok, I just got finished using the Rio upgrade wizard. It seems to have upgraded just fine, I now have the RIO splash screen and my Hijack is gone. I still am not able to retain any settings or clock. When I plug the AC adapter in it starts with the same song every time in pause mode I can start the song playing, forward to a different song and set the volume but as soon as I unplug the power supply and plug it back in every thing resets. Now what???
#243338 - 06/12/2004 18:09
[Re: farmtech]
Losing Hijack is expected - just grab the latest version and reapply it using logoedit.
The lost settings thing is a real problem. The player relies on energy stored in its power supply capacitors to write the flash when the power fails. I suspect that perhaps one of these has gone bad.
#243339 - 06/12/2004 23:52
[Re: genixia]
I have my Empeg apart and I think the power supplies are functioning correctly. I even temporarily added an extra 220uF of capacitance in parallel with 3 blue caps on the input of the switching fets, no help. I then moved the 220uF cap to the 3 yellow surface mount caps at the back edge of the board this was the 3.3V supply (I would think this is what the flash would use but not for sure) this had no effect either. I also tried moving it to the two 5V caps and the 2.0V processor core cap all with no effect. I am starting to think that one of two things is happening. (1) the processor is not seeing the power supply go down (this probably happens by the processor looking at a voltage sense line somewhere on the board or (2) the application is somehow still corrupt and it is not looking for the shutdown signal. I just don't understand this because this thing has worked perfect since I bought it but after setting on the shelf for 3 months is now not working. I should say that the entire time I had it in my previous car it would power up in standby about 1/2 of the time and I was never able to figure it out. Does anyone think it would be worth wiping out the kernel and app and starting completely over? If so how would I do that. Very puzzled and sad
#243340 - 07/12/2004 00:21
[Re: farmtech]
If I'm not mistaken, the "player settings lost" does not indicate a capacitance problem. If the player doesn't save its settings properly, it merely uses the last settings in flash.
No, I think the "player settings lost" error indicates worse trouble with either the kernel or the flash itself. Just for the heck of it, do a RAM test, too (the ctrl-T thing in the hyperterminal section of the FAQ).
#243341 - 07/12/2004 00:58
Well, here it what it said....
0100 ram test starting 0110 testing ic 1 (0-15mb, low word) 0120 testing ic 2 (0-15mb, high word) 01f0 ram test done 0200 ide detect 0210 command issued 0220 drive id IBM-DARA-212000 02f0 ide ok 0300 dsp/i2c test 03f0 dsp/i2c ok 0400 temperature detect 0410 temperature is 26 04f0 temperature ok 0500 usb detect 0510 usb rev 1012 05f0 usb ok 0600 ethernet detect 0610 ethernet rev 334b 06f0 ethernet ok 0700 cs4231 detect 0710 cs4231 rev a0 07f0 cs4231 ok 00f0 tests complete
Just to clarify, the first 3 times I applied power after the install it said "player settings lost" but then after doing a reboot through Hijack it powers up fine with no warnings but the settings are always back to defaults.
#243342 - 07/12/2004 02:52
[Re: farmtech]
Can you post 3 boot logs? Leave the serial connected between boots. Do a full power down reboot, not hijacks reboot feature.
#243343 - 07/12/2004 12:36
[Re: genixia]
Sure I can, by "full power down reboot" do you mean just pulling the AC adapter when it is playing and then plugging it back in?
#243344 - 07/12/2004 14:15
[Re: farmtech]
If this is only happening in the car sled, then I would check out the fuse on the supply lead.
#243345 - 07/12/2004 14:34
[Re: schofiel]
This happens in the car and in the house. For now I am just using the AC adaptor on the back of the Empeg, I can play a song, pull the cord out and when I plug it back in every thing has reset. I do not see any error messages but I will post 3 boots tonight.
#243346 - 07/12/2004 14:35
[Re: farmtech]
Yes.
#243347 - 07/12/2004 20:11
[Re: farmtech]
More useful: blow V2 Developer. From the command line discard the current playlist and start the player from scratch with "player -i" (see the FAQ for this). Then reboot, connect with emplode, change one single piece of data, then do a sync.
#243348 - 08/12/2004 03:28
[Re: schofiel]
Quote: More useful: blow V2 Developer. From the command line discard the current playlist and start the player from scratch with "player -i" (see the FAQ for this). Then reboot, connect with emplode, change one single piece of data, then do a sync.
Sorry but I do not understand what you mean by "blow v2 developer", I searched the FAQ for this and "player -i" with no results. The boot messages look normal but here is what I received when I captured three complete boots with Hyperterminal.
empeg-car bootstrap v1.02 20001106 (hugo@empeg.com) If there is anyone present who wants to upgrade the flash, let them speak now, or forever hold their peace...it seems not. Let fly the Penguins of Linux!
e000 v1.04 Copying kernel... Calling linux kernel... Uncompressing Linux..................................... done, booting the kernel. Linux version 2.2.14-rmk5-np17-empeg52 (rob@aphex) (gcc version 2.95.3 20010315 (release)) #12 Tue Apr 1 18:51:41 BST 2003 Processor: Intel StrongARM-1100 revision 11 NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel Computer Corp. empeg-car player (hardware revision 9, serial number 120001063) Command line: mem=16m Calibrating delay loop... 207.67 BogoMIPS Memory: 15024k/16M available (964k code, 20k reserved, 372k data, 4k init) Dentry hash table entries: 2048 (order 2, 16k) Buffer cache hash table entries: 16384 (order 4, 64k) Page cache hash table entries: 4096 (order 2, 16k) POSIX conformance testing by UNIFIX Linux NET4.0 for Linux 2.2 Based upon Swansea University Computer Society NET3.039 NET4: Linux TCP/IP 1.0 for NET4.0 IP Protocols: ICMP, UDP, TCP TCP: Hash tables configured (ehash 16384 bhash 16384) IrDA (tm) Protocols for Linux-2.2 (Dag Brattli) Linux-IrDA: IrCOMM protocol ( revision:Tue May 18 03:11:39 1999 ) ircomm_tty: virtual tty driver for IrCOMM ( revision:Wed May 26 00:49:11 1999 ) Starting kswapd v 1.5 SA1100 serial driver version 4.27 with no serial options enabled ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UART ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UART ttyS02 at 0xf8030000 (irq = 16) is a SA1100 UART Signature is 206f6972 'rio ' empeg display initialised. empeg dsp audio initialised empeg dsp mixer initialised empeg dsp initialised empeg audio-in initialised, CS4231A revision a0 empeg remote control/panel button initialised. empeg usb initialised, PDIUSBD12 id 1012 empeg state support initialised 0089/88c1 (save to d0004100). empeg RDS driver initialised empeg power-pic driver initialised (first boot) RAM disk driver initialized: 16 RAM disks of 4096K size empeg single channel IDE Probing primary interface... hda: IBM-DARA-212000, ATA DISK drive hda: IBM-DARA-212000, ATA DISK drive hda: IBM-DARA-212000, ATA DISK drive hda: IBM-DARA-212000, ATA DISK drive hda: IBM-DARA-212000, ATA DISK drive hda: IBM-DARA-212000, ATA DISK drive ide0 at 0x000-0x007,0x038 on irq 6 hda: IBM-DARA-212000, 11513MB w/418kB Cache, CHS=23392/16/63 empeg-flash driver initialized smc chip id/revision 0x3349 smc9194.c:v0.12 03/06/96 by Erik Stahlman (erik@vt.edu)
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:18:04:27 Partition check: hda: hda1 < hda5 hda6 > hda2 hda3 hda4 RAMDISK: ext2 filesystem found at block 0 RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done. EXT2-fs warning: checktime reached, running e2fsck is recommended VFS: Mounted root (ext2 filesystem). empeg-pump v0.03 (19980601) Press Ctrl-A to enter pump... VFS: Mounted root (ext2 filesystem) readonly. change_root: old root has d_count=1 player.cpp : 385:empeg-car 2.00 2003/04/01. Prolux 4 empeg car - 2.1434 Mar 26 2003 Vcb: 0x4086d000 serial_notify_thread.cpp: 116:@@ N0 serial_notify_thread.cpp: 117:@@ F0x14e0 serial_notify_thread.cpp: 118:@@ TBamboo serial_notify_thread.cpp: 119:@@ AJoe Satriani serial_notify_thread.cpp: 120:@@ GOther serial_notify_thread.cpp: 180:@@ #0 0:00:00 serial_notify_thread.cpp: 170:@@ S0
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:18:04:27 Partition check: hda: hda1 < hda5 hda6 > hda2 hda3 hda4 RAMDISK: ext2 filesystem found at block 0 RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done. EXT2-fs warning: checktime reached, running e2fsck is recommended VFS: Mounted root (ext2 filesystem). empeg-pump v0.03 (19980601) Press Ctrl-A to enter pump... VFS: Mounted root (ext2 filesystem) readonly. change_root: old root has d_count=1 Trying to unmount old root ... okay Freeing unused kernel memo player.cpp : 385:empeg-car 2.00 2003/04/01. Prolux 4 empeg car - 2.1434 Mar 26 2003 Vcb: 0x4086d000 serial_notify_thread.cpp: 116:@@ N0 serial_notify_thread.cpp: 117:@@ F0x14e0 serial_notify_thread.cpp: 118:@@ TBamboo serial_notify_thread.cpp: 119:@@ AJoe Satriani serial_notify_thread.cpp: 120:@@ GOther serial_notify_thread.cpp: 180:@@ #14e0 0:00:00
#243349 - 08/12/2004 04:48
[Re: farmtech]
Rob meant to put the v2-developer build on your player, then 'Q' or Ctrl-C your serial port after it finishes booting, and then run the player with its "Ignore all our existing saved data" flag. I don't think that it will help you, unless it also resets the flash save-area to the default too. Is There Love In Space? Who knows? Anyway, your player is certainly not saving its state correctly: Quote: empeg state support initialised 0089/88c1 (save to d0004100)
The "save to" address should change at each boot. The fact that is the same each time indicates that the flash is not being written correctly at shut down, for whatever reason.
There is a debug flag in the kernel that could be compiled in that prints "The Quick Brown Fox..." at shutdown. The empeg guys put it in so that they could measure how long the power stays up (to ensure that the flash did indeed get written, no less). I'm not really sure what is considered normal though.
#243350 - 08/12/2004 12:09
[Re: genixia]
Ok, I installed the V2 developer version, and ran "player -i" from the shell prompt. It did reset my playlist but did not fix my problem. Posted below is a what Hyperterminal captured when I advanced a few tracks, adjusted the volume up a little and then pulled the AC cord and restarted. It is still not writing correctly to the flash area. Is it possible that the flash save area is corrupt? Can I view it or erase it?
serial_notify_thread.cpp: 116:@@ N1 serial_notify_thread.cpp: 117:@@ F0x730 serial_notify_thread.cpp: 118:@@ TGnaah serial_notify_thread.cpp: 119:@@ AJoe Satriani serial_notify_thread.cpp: 120:@@ GOther serial_notify_thread.cpp: 116:@@ N2 serial_notify_thread.cpp: 117:@@ F0x950 serial_notify_thread.cpp: 118:@@ THands in the Air serial_notify_thread.cpp: 119:@@ AJoe Satriani serial_notify_thread.cpp: 120:@@ GOther serial_notify_thread.cpp: 116:@@ N3 serial_notify_thread.cpp: 117:@@ F0x10b0 serial_notify_thread.cpp: 118:@@ TIf I Could Fly serial_notify_thread.cpp: 119:@@ AJoe Satriani serial_notify_thread.cpp: 120:@@ GOther serial_notify_thread.cpp: 116:@@ N4 serial_notify_thread.cpp: 117:@@ F0x1100 serial_notify_thread.cpp: 118:@@ TI Like the Rain serial_notify_thread.cpp: 119:@@ AJoe Satriani serial_notify_thread.cpp: 120:@@ GOther serial_notify_thread.cpp: 116:@@ N5 serial_notify_thread.cpp: 117:@@ F0x1090 serial_notify_thread.cpp: 118:@@ TIs There Love in Space serial_notify_thread.cpp: 119:@@ AJoe Satriani serial_notify_thread.cpp: 120:@@ GOther serial_notify_thread.cpp: 116:@@ N6 serial_notify_thread.cpp: 117:@@ F0x10e0 serial_notify_thread.cpp: 118:@@ TJust Look Up serial_notify_thread.cpp: 119:@@ AJoe Satriani serial_notify_thread.cpp: 120:@@ GOther serial_notify_thread.cpp: 116:@@ N6 serial_notify_thread.cpp: 117:@@ F0x10e0 serial_notify_thread.cpp: 118:@@ TJust Look Up serial_notify_thread.cpp: 119:@@ AJoe Satriani serial_notify_thread.cpp: 120:@@ GOther serial_notify_thread.cpp: 170:@@ S1 serial_notify_thread.cpp: 136:@@ V1 serial_notify_thread.cpp: 136:@@ V2 serial_notify_thread.cpp: 136:@@ V3 serial_notify_thread.cpp: 180:@@ #10e0 0:00:02 serial_notify_thread.cpp: 136:@@ V4 serial_notify_thread.cpp: 136:@@ V5 serial_notify_thread.cpp: 136:@@ V6 serial_notify_thread.cpp: 136:@@ V7 serial_notify_thread.cpp: 180:@@ #10e0 0:00:03 serial_notify_thread.cpp: 180:@@ #10e0 0:00:04 serial_notify_thread.cpp: 180:@@ #10e0 0:00:05 serial_notify_thread.cpp: 180:@@ #10e0 0:00:06
Linux version 2.2.14-rmk5-np17-empeg52 (rob@aphex) (gcc version 2.95.3 20010315 (release)) #11 Tue Apr 1 18:49:59 BST 2003
Partition check:
empeg-pump v0.03 (19980601) Press Ctrl-A to enter pump... hange_root: old root has d_count=1
Freeing unused kernel memory: 4k initempeg init 0.8 I see this is a developer image! Mounting proc Mounting first music partition Tried to mount /dev/hda4 as reiserfs but got error 19 Mounting second music partition Tried to mount /dev/hdc4 but got error 6 Error mounting partitions (possibly already mounted) Remounting first music partition read-only Remounting second music partition read-only No secondary hard disk Press 'q' now to go into development mode. You Have Zero Seconds To ComðStarting player player.cpp : 385:empeg-car 2.00 2003/04/01. Prolux 4 empeg car - 2.1434 Mar 26 2003 Vcb: 0x4086d000 serial_notify_thread.cpp: 116:@@ N0 serial_notify_thread.cpp: 117:@@ F0x14e0 serial_notify_thread.cpp: 118:@@ TBamboo serial_notify_thread.cpp: 119:@@ AJoe Satriani serial_notify_thread.cpp: 120:@
#243351 - 09/12/2004 05:59
[Re: farmtech]
Although you have blown V2Dev and reset the playlist, you did not connect with emplode and modify a playlist followed by a sync.
If your flash was corrupt/damaged/whatever, then the player app would not load.
Have you performed any modifications (hardware or software) to the player recently?
#243352 - 09/12/2004 12:38
[Re: schofiel]
I have not done any modifications to the empeg itself ever, I did make a device that monitored the serial notify info coming out of the serial port in order to indicate if the empeg was in aux or player mode. (This was needed for my previous installation) The empeg was running V2 and Hijack 379 before getting pulled out of my car and sitting on the shelf for 3 months.
The first time I powered the empeg on after sitting 3 months it said "player settings lost" so maybe that is a clue???
I will try modifying a playlist and re-synching tonight.
Nick
#243353 - 09/12/2004 23:12
[Re: farmtech]
Ok, I just reset my playlist using "player -i" I then connected to emplode, added a new playlist put 3 songs in it and resynched. My problem still exists, the empeg will reset and go back to the first song in the playlist in pause mode when power is removed. What next?
Does anyone know which GPIO pin the processor uses to monitor the power supply?
Nick
#243354 - 09/12/2004 23:50
[Re: farmtech]
Throw this kernel on your player and let's see the serial output from a couple of boot/power down sequences.
#243355 - 10/12/2004 00:06
[Re: genixia]
Cool, I am willing to try anything, however I am not sure how to load just the kernel. Is there something described in the FAQ or can you give some quick instructions?
Thanks for the help
Nick
#243356 - 10/12/2004 00:13
[Re: farmtech]
Download Logoedit. You'll find a kernel flashing utility there.
#243357 - 10/12/2004 00:38
[Re: genixia]
Sorry about that, I knew that. I am not thinking straight tonight for some reason. Here is what I came up with...
e000 v1.04 Copying kernel... Calling linux kernel... Uncompressing Linux..................................... done, booting the kernel. Linux version 2.2.17-rmk5-np17-empeg52-hijack-v413 (root@genixia.genixia.net) (gcc version 2.95.3 20010315 (release)) #3 Thu Dec 9 20:42:29 EST 2004 Processor: Intel StrongARM-1100 revision 11 Checking for extra DRAM: c1000000: wrote ffffffff, read e91ba9f0 NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel Computer Corp. empeg-car player (hardware revision 9, serial number 120001063) 16MB DRAM Command line: mem=16m Calibrating delay loop... 207.67 BogoMIPS Memory: 15008k/16M available (984k code, 20k reserved, 368k data, 4k init) Dentry hash table entries: 2048 (order 2, 16k) Buffer cache hash table entries: 16384 (order 4, 64k) Page cache hash table entries: 4096 (order 2, 16k) POSIX conformance testing by UNIFIX Linux NET4.0 for Linux 2.2 Based upon Swansea University Computer Society NET3.039 NET4: Linux TCP/IP 1.0 for NET4.0 IP Protocols: ICMP, UDP, TCP TCP: Hash tables configured (ehash 16384 bhash 16384) IrDA (tm) Protocols for Linux-2.2 (Dag Brattli) Starting kswapd v 1.5 SA1100 serial driver version 4.27 with no serial options enabled ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UART ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UART ttyS02 at 0xf8030000 (irq = 16) is a SA1100 UART Powerfail is now disabled (1) Powerfail is now enabled (0) Signature is 206f6972 'rio ' Tuner: loopback=0, ID=-1 empeg display initialised. empeg dsp audio initialised empeg dsp mixer initialised empeg dsp initialised empeg audio-in initialised, CS4231A revision a0 empeg remote control/panel button initialised. empeg usb initialised, PDIUSBD12 id 1012 Powerfail is now enabled (0) Powerfail line current level is 0 empeg state support initialised 0089/88c1 (save to d0004180). Powerfail is now enabled (0) empeg RDS driver initialised empeg power-pic driver initialised (first boot) RAM disk driver initialized: 16 RAM disks of 4096K size empeg single channel IDE Probing primary interface... hda: IBM-DARA-212000, ATA DISK drive ide0 at 0x000-0x007,0x038 on irq 6 hda: IBM-DARA-212000, 11513MB w/418kB Cache, CHS=23392/16/63 empeg-flash driver initialized smc chip id/revision 0x3349 smc9194.c:v0.12 03/06/96 by Erik Stahlman (erik@vt.edu)
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:18:04:27 Partition check: hda: hda1 < hda5 hda6 > hda2 hda3 hda4 RAMDISK: ext2 filesystem found at block 0 RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done. EXT2-fs warning: checktime reached, running e2fsck is recommended VFS: Mounted root (ext2 filesystem). empeg-pump v0.03 (19980601) Press Ctrl-A to enter pump... VFS: Mounted root (ext2 filesystem) readonly. change_root: old root has d_count=1 Trying to unmount old root ... okay Freeing unused kernel memory: 4k initempeg init 0.8 I see this is a developer image! Mounting proc Mounting first music partition Tried to mount /dev/hda4 as reiserfs but got error 19 Mounting second music partition Tried to mount /dev/hdc4 but got error 6 Error mounting partitions (possibly already mounted) Remounting first music partition read-only Remounting second music partition read-only No secondary hard disk Press 'q' now to go into development mode. You Have Zero Seconds To ComðStarting player Timezone: Atlantic/South_Georgia Hijack: intercepting config.ini
hijack: removed menu entry: "Serial Port Assignment" khttpd: listening on port 80 kftpd: listening on port 21 player.cpp : 385:empeg-car 2.00 2003/04/01. Prolux 4 empeg car - 2.1434 Mar 26 2003 Vcb: 0x4086d000 serial_notify_thread.cpp: 116:@@ N0 serial_notify_thread.cpp: 117:@@ F0x950 serial_notify_thread.cpp: 118:@@ THands in the Air serial_notify_thread.cpp: 119:@@ AJoe Satriani serial_notify_thread.cpp: 120:@@ GOther serial_notify_thread.cpp: 180:@@ #0 0:00:00 serial_notify_thread.cpp: 170:@@ S0 serial_notify_thread.cpp: 116:@@ N1 serial_notify_thread.cpp: 117:@@ F0x1090 serial_notify_thread.cpp: 118:@@ TIs There Love in Space serial_notify_thread.cpp: 119:@@ AJoe Satriani serial_notify_thread.cpp: 120:@@ GOther serial_notify_thread.cpp: 116:@@ N1 serial_notify_thread.cpp: 117:@@ F0x1090 serial_notify_thread.cpp: 118:@@ TIs There Love in Space serial_notify_thread.cpp: 119:@@ AJoe Satriani serial_notify_thread.cpp: 120:@@ GOther serial_notify_thread.cpp: 180:@@ #1090 0:00:00 serial_notify_thread.cpp: 170:@@ S1 serial_notify_thread.cpp: 180:@@ #1090 0:00:01 serial_notify_thread.cpp: 180:@@ #1090 0:00:02 serial_notify_thread.cpp: 180:@@ #1090 0:00:03 serial_notify_thread.cpp: 136:@@ V1 serial_notify_thread.cpp: 136:@@ V2 serial_notify_thread.cpp: 180:@@ #1090 0:00:04 serial_notify_thread.cpp: 136:@@ V3 serial_notify_thread.cpp: 136:@@ V4 serial_notify_thread.cpp: 180:@@ #1090 0:00:05 serial_notify_thread.cpp: 180:@@ #1090 0:00:06 serial_notify_thread.cpp: 180:@@ #1090 0:00:07 serial_notify_thread.cpp: 180:@@ #1090 0:00:08
hijack: removed menu entry: "Serial Port Assignment" khttpd: listening on port 80 kftpd: listening on port 21 player.cpp : 385:empeg-car 2.00 2003/04/01. Prolux 4 empeg car - 2.1434 Mar 26 2003 Vcb: 0x4086d000 serial_notify_thread.cpp: 116:@@ N0 serial_notify_thread.cpp: 117:@@ F0x950 serial_notify_thread.cpp: 118:@@ THands in the Air serial_notify_thread.cpp: 119:@@ AJoe Satriani serial_notify_thread.cpp: 120:@@ GOther serial_notify_thread.cpp: 180:@@ #950 0:00:00 serial_notify_thread.cpp: 170:@@ S0
#243358 - 10/12/2004 01:43
[Re: farmtech]
Quote: My problem still exists, the empeg will reset and go back to the first song in the playlist in pause mode when power is removed.
This might be normal/expected behavior depending on how many songs are in that playlist.
This is a completely different issue than the "Player Settings Lost" error you described before. Are you still getting that error or not?
#243359 - 10/12/2004 01:54
I only have 3 songs in that particular playlist. I think I only have around 1000 songs in the player total.
When I first powerered on the empeg after sitting 3 months it said "player settings lost" I pulled power 2 or 3 times and it kept saying "player settings lost". I then went into the Hijack menu and did a reboot player. I have not seen the "player settings lost" since but I am not able to retain settings or the time from the RTC.
Wierd huh.
#243360 - 10/12/2004 03:39
[Re: farmtech]
Hmm. no evidence that the power fail event was seen. As far as I can tell, we should have seen a serial message...
However, I'm not sure whether the serial notify feature may be clobbering it - or at least delaying it until the power is totally dead.
Can you set "suppress_notify=1" in the hijack section of your config.ini and try again.
#243361 - 10/12/2004 11:03
[Re: farmtech]
I wonder if the leaf spring in the DC power socket has failed into the on state?
Can you move the leaf with a matchstick or something?
#243362 - 10/12/2004 11:59
[Re: schofiel]
Ok, I set suppress notify = 1, now the player starts up and goes into standby mode every time. The last 2 powerfail statements in the boot cycle happen once I turn the empeg on after it has booted up. I can check the leaf spring in the power connector but I am pretty sure it is fine, the connector does not get used much.
Here it is, 2 boots.
e000 v1.04 Copying kernel... Calling linux kernel... Uncompressing Linux..................................... done, booting the kernel. Linux version 2.2.17-rmk5-np17-empeg52-hijack-v413 (root@genixia.genixia.net) (gcc version 2.95.3 20010315 (release)) #3 Thu Dec 9 20:42:29 EST 2004 Processor: Intel StrongARM-1100 revision 11 Checking for extra DRAM: c1000000: wrote ffffffff, read e91ba9f0 NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel Computer Corp. empeg-car player (hardware revision 9, serial number 120001063) 16MB DRAM Command line: mem=16m Calibrating delay loop... 207.67 BogoMIPS Memory: 15008k/16M available (984k code, 20k reserved, 368k data, 4k init) Dentry hash table entries: 2048 (order 2, 16k) Buffer cache hash table entries: 16384 (order 4, 64k) Page cache hash table entries: 4096 (order 2, 16k) POSIX conformance testing by UNIFIX Linux NET4.0 for Linux 2.2 Based upon Swansea University Computer Society NET3.039 NET4: Linux TCP/IP 1.0 for NET4.0 IP Protocols: ICMP, UDP, TCP TCP: Hash tables configured (ehash 16384 bhash 16384) IrDA (tm) Protocols for Linux-2.2 (Dag Brattli) Starting kswapd v 1.5 SA1100 serial driver version 4.27 with no serial options enabled ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UART ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UART ttyS02 at 0xf8030000 (irq = 16) is a SA1100 UART Powerfail is now disabled (1) Powerfail is now enabled (0) Signature is 67706d65 'empg' Tuner: loopback=0, ID=-1 Scheduling custom logo. empeg display initialised. empeg dsp audio initialised empeg dsp mixer initialised empeg dsp initialised empeg audio-in initialised, CS4231A revision a0 empeg remote control/panel button initialised. empeg usb initialised, PDIUSBD12 id 1012 Powerfail is now enabled (0) Powerfail line current level is 0 empeg state support initialised 0089/88c1 (save to d0004200). Powerfail is now enabled (0) empeg RDS driver initialised empeg power-pic driver initialised (first boot) RAM disk driver initialized: 16 RAM disks of 4096K size empeg single channel IDE Probing primary interface... hda: IBM-DARA-212000, ATA DISK drive ide0 at 0x000-0x007,0x038 on irq 6 hda: IBM-DARA-212000, 11513MB w/418kB Cache, CHS=23392/16/63 empeg-flash driver initialized smc chip id/revision 0x3349 smc9194.c:v0.12 03/06/96 by Erik Stahlman (erik@vt.edu)
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:18:04:27 Partition check: hda: hda1 < hda5 hda6 > hda2 hda3 hda4 RAMDISK: ext2 filesystem found at block 0 RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done. EXT2-fs warning: checktime reached, running e2fsck is recommended VFS: Mounted root (ext2 filesystem). empeg-pump v0.03 (19980601) Press Ctrl-A to enter pump... VFS: Mounted root (ext2 filesystem) readonly. change_root: old root has d_count=1 Trying to unmount old root ... okay Freeing unused kernel memory: 4k initempeg init 0.8 I see this is a developer image! Mounting proc Mounting first music partition Tried to mount /dev/hda4 as reiserfs but got error 19 Mounting second music partition Tried to mount /dev/hdc4 but got error 6 Error mounting partitions (possibly already mounted) Remounting first music partition read-only Remounting second music partition read-only No secondary hard disk Press 'q' now to go intStarting player Timezone: Atlantic/South_Georgia Hijack: intercepting config.ini
hijack: removed menu entry: "Serial Port Assignment" khttpd: listening on port 80 kftpd: listening on port 21 player.cpp : 385:empeg-car 2.00 2003/04/01. Prolux 4 empeg car - 2.1434 Mar 26 2003 Vcb: 0x4086d000 Powerfail is now disabled (1) Powerfail is now enabled (0)
