#237654 - 15/10/2004 00:12
broken (dead) empeg: what to do to ?
Loc: Italy
hi, my empeg is working no more, when i power it up i can't listen music, the main display is not working but the ethernet led is on and it replies to pings, i can't connect with emplode. i've discovered that the ide cable was cut and the IDE connector have problems as in FAQs but i've tried the display with another motherboard and the motherboard with another display (thanks Taym !!) but nothing seems to wok. every part is whole and the empeg is not fell before to dead , anyone could fix it ? there is a solution ? thank you very much.
shapeless
MK2a | #010101588 | 2x 120GB SSD | Hijack v526 | v3.0a11 | > melpomene < MK2 | #090000581 | 60 & 100GB HD | v2final.mk2 | v2.01 | > backup < radio | all colors lens | greenlights LBSSK buttons | KCA-R6A + ERC-1A remotes | carry cases | empeg sticker!
#237655 - 15/10/2004 04:05
Re: broken (dead) empeg: what to do to ?
[Re: shapeless]
Very first thing to do is to connect the serial wire and grab a log of the boot process, then post it here and it's likely that we'll be able to zero in on the problem.
#237656 - 15/10/2004 16:54
[Re: shapeless]
Sell it to me. $100.
#237657 - 15/10/2004 19:05
Me. $125.
#237658 - 16/10/2004 10:10
[Re: genixia]
Loc: Italy
of course !! consider it yours if you have another working one to sell me at the same price
i really love my empeggy and i want to do the possibile to save it. :'\
mlord and genixia, what about to repair it for me please ? (paying it of course)
shapeless
#237659 - 16/10/2004 10:15
[Re: mtempsch]
Loc: Italy
ok i'll post my serial log
shapeless
#237660 - 16/10/2004 10:18
[Re: shapeless]
Loc: Italy
MY SERIAL LOG:
e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux..................................... done, booting the k
l.a:
Linux version 2.2.14-rmk5-np17-empeg52 (rob@aphex) (gcc version 2.95.3 20010315
smc chip id/re
(release)) #11 Tue Apr 1 18:49:59 BST 2003
Processor: Intel StrongARM-1100 revision 11ATUS(0xa1) instead of ALTSTATUS(0xff): 16
empeg-car player (hardware revision 9, serial number 10101588)re is anyone present who wants
Command line: mem=16m STATUS(0xa1)
Calibrating delay loop... 207.67 BogoMIPSTATUS(0xa1) instead of ALTSTATUS(0xff)
Memory: 15024k/16M available (964k code, 20k reserved, 372k data, 4k init)tel StrongARM-1100 revision 11ISith STATUS(0xa1) instead of ALTSTATUS(0xff
Linux NET4.0 for Linux 2.2
hdb: pr
e000 v1.04grade th
Cop(0x
IP Protocols: ICMP, UDP, TCP = 0xa1)i
TCP: Hash tables configured (ehash 16384 bhash 16384)ng with STATUS(0xa1) instead of ALTSTATUS(0xff)ctabl
hda: probing with STATUS(0xa1) in
Linux-IrDA: IrCOMM protocol ( revision:Tue May 18 03:11:39 1999 ).2.14-rmk5-np17-empeg52 (rob@aphex)sed RAM disks of
ircomm_tty: virtual tty driver for IrCOMM ( revision:Wed May 2
hdb: probing with STATUS(0xa1) insteaRM-11
Signature is 67706d65 'empg'instead of
Scheduling custom logo.
empeg display initialised.: virtu
h
empeg dsp audio initialised) instead of ALTSTATUS(0xff
empeg dsp mixer initialisedc versi
empeg dsp initialised
empeg audio-in initialised, CS4231A revision a0TATUS(0xa1) instead of ALTSTATUS(0xff)ith STAT
empeg usb initialised, PDIUSBD12
4o
Partition check:i
empeg single channel IDEtus = 0xa1)error: status
Probing primary interface...
emp
hda: probing with STATUS(0x01) instead of ALTSTATUS(0xff)xa1)is a SA1100 UART no response (status = 0xa1)
hda: probing with STATUS(0xa1) instead of ALTSTATUS(0xff)
TCP: Hash tablb: probing wit
hda: no response (status = 0xa1)S(0xa1) insteaff)
hdb: probing with STATUS(0xa1) instead of ALTSTATUS(0xff)disks of STATUS(0xa1) instead of ALTSTATUS(0xff)
hda: no response (status = 0xa1) revision a0on 4.27 withSTATUS(0
hda: p
hdb: probing with STATUS(0xa1) instead of ALTSTATUS(0xff)eg state support initiali1)
hdb: no response (status = 0xa1)of ALTSTATUS(0xff)ersion=01)0300
smc chip id/revision 0x3349
hda: probing with STATUS(0xa1) instead of ALTSTATUS(0xff)f ALTSTATUS(0xff)ith STATUS(0x00) instead of
hdb: probing with STATUS(0xa1) instea0800
hdb: no response (status = 0xa1)yone present who wants to upgrad
hda: probing with STATUS(0xa1) instead of ALTSTATUS(0xff) of ALTSTATUS(0xff)
e000 v1.04
Copying ke
hdb: no response (status = 0xa1)obing with STATUS(0xa1) instead
hda: probing with STATUS(0xa1) instead of ALTSTATUS(0xff)..... done, booti
hda: no response (status = 0xa1) id/revision 0x3349998 Corel Com
smc9194.c:v0.12 03/06/96 by Erik Stahlman (eri
SMC9194: SMC91C94(r:9) at 0x4
NET4: Linux TCP/IP
I
hda: no response (status = 0xa1)ts to upgrade the flash, let the
i
hdb: probing with STATUS(0xa1) instead of ALTSTATUS(0xff) { Dri
hda: probing with STATUS(0xa1) instead of ALTSTATUS(0xff)(c) 1998 Corel Computer Corp.d TrackZero/16M available (9
Signature is 67
Command line: mem=16m dsp audio in
hda: probing with STATUS(0xa1) instead of ALTSTATUS(0xff)... 207.67 BogoMIPSreset: master: error (0x00?)ALTSTATUS(
hdb: probing with STATUS(0xa1) instead of ALTSTATUS(0xff)de, 20k reserved, 372k data, 4k init)n
hdb: probing with STATUS(0xa1) instead of ALTSTATUS(0xff)da: set_geometry_intr: status=0x51 { DriveReady SeekCompl
hda: probing with STATUS(0xa1) instead of ALTSTATUS(0xff)S
hda: probing with STATUS(0xa1) instead of ALTSTATUS(0xff)rCOMM ( revision:Wed May 2: read_intr: status=0x51 { Dri
ttyS01 at 0xf8050000 (i
hda: no response (status = 0xa1)drMarkNotFound }, CHS=16128/15/8
ttyS02 at
hda: set_geometry_intr: stat
Signature is 6
empeg dsp initialisedusError SectorIdNotFo
hdb: no response (status = 0xa1)empeg audio-in initialised, CS42
RAMDISK: ext2 filesyste
empeg
hda: probing with STATUS(0xa1) instead of ALTSTATUS(0xff)entries: 4096 (order 2, 16k)p
RAM disk driver initialized: 16 RAM disks of 4096
Based upon S
Calling linux kernel...er
hdb: no response (s
hda:
empeg
hda: probing
hdb: probing with STATUS(0xa1) instead of ALTSTATUS(0xff)ter Society NET3.039o wants to upgrade
empeg power-p
Probing primary interface...th STATUS(0xa1) instead of A
hda: probing with STATUS(0xa1) instead of ALTSTATUS(0xff)STATUS(0xa1) instead of ALTSTATUS(0xff)
empeg state support
hda: probing with STATUS(0xa1) insteaLinux 2.2S
hda: no res
empeg powe
hda: probing with STATUS(0xa1) instead of ALTSTATUS(0xff) ALTSTATUS(0xff) w/1874kB Cache, CHS=38760/16/63serial dr
hda: no response (status = 0xa1) STATUS(0xa1) instead of ALTSTAT
ide0: reset
hdb: probing with STATUS(0xa1) instead of ALTSTATUS(0xff) initializedUS
hdb: probing with STATUS(0xa1) instead of ALTSTATUS(0xff)1): status=0x51 { DriveReadylised.
hdb: probing with STATUS(0xa1) instead of ALTSTATUS(0xff)h STATUS(0xa1) instead of ALTSTATUS(0xff)robing primary i
hda: no response (status = 0xa1)da:
Starting kswapd
hda: probing
hdb: probing with STATUS(0xa1) instead of ALTSTATUS(0xff)4 =serial driver versio
ide0
hda: probing with STATUS(0xa1) instead of ALTSTATUS(0xff)s = 0xa1)15 V0.94.1 (
riveR
hdb
hda: probing with STATUS(0xa1) instead of ALTSTATUS(0xff)99 ) protocol ( revision:Tue May 18 03:11:39 1999 )ad
hdb:
hdb: probing with STATUS(0xa1) instead of ALTSTATUS(0xff)of ALTSTATUS(0xff)bing
hdb: probing with STATUS(0xa1) instead of ALTSTATUS(0xff)comm_tty: virtual tty driver for Ir
hdb: no response (status = 0xa1) STATUS(0xa1) instead of ALTSTAT
lM
SA1100 serial driver version 4.27
hdb
SA1100 serial d
hda: probing with STATUS(0xa1) instead of ALTSTATUS(0xff))h STATUS(0xa1)
hda: no response (status = 0xa1): probing with ST
hdb: probing with STATUS(0xa1) instead of ALTSTATUS(0xff)US(0xff)
hdb: probing with STATUS(0xa1) instead of ALTSTATUS(0xff) response (status = 0xa1)
hdb: no response
hda: probing wit
hdb: no response (status = 0xa1)US(0xff)
hda: probing with STATUS(0xa1) instead of ALTSTATUS(0xff)(0xa1) instead of
hda: probing with STATUS(0xa1) instead of ALTSTATUS(0xff)US(0xff).5: IrCOMM pro
SA1100 seri
hda: no response (status = 0xa1)ff)
hdb: probing with STATUS(0xa1) instead of ALTSTATUS(0xff)) instead of ALTSTATUS(0xff)probing with STATUS(0xa1) ins
hdb: no response (status = 0xa1)ponse (status = 0xa1)
hda: probing with STATUS(0xa1) instead of ALTSTATUS(0xff)TATUS(0xa1) instead of ALTSTATUS(0xff)
hda: probing with STATUS(0xa1) instead of ALTSTATUS(0xff)onse (sta
hdb: no response (s
hda: probing wit
hdb: no response (status = 0xa1)US(0xff)d of ALTSTATUS(0xff)
hda: set
hdb: probi
hda: no response (status = 0xa1)LTSTATUS(0xff)ff)780 r5
h
hda: r
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:06:3
4
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...VFS: Cannot open root device 03:05
Kernel panic: VFS: Unable to mount root fs o
I've to say that the HD is perfectly working with another empeg.
shapeless
#237661 - 16/10/2004 10:49
[Re: shapeless]
Are you _sure_ it's responding to pings? The network isn'f configured until the player is loaded, which isn't happening here.
IDE problem. Probably the cable. Possibly the IDE header. SInce you've mentioned a ripped cable, I'd chase this down first. Get a new one from Eutronix (link up top).
If there's nothing at all on the display then you've probably misaligned the display cable when swapping them about and blown a fuse.
I should be able to fix both these issues, but let's narrow them down first. Start with the cable.
#237662 - 16/10/2004 11:08
[Re: genixia]
Loc: Italy
Quote: Are you _sure_ it's responding to pings? The network isn'f configured until the player is loaded, which isn't happening here.
you are right, this times it's not responding to pings but it was responding last time i've tested it. the eth led is up by the way. in fact the last time i've tested it the pulsing led on the main display was working and isn't working this time...
sorry, i meant DISPLAY cable, not IDE, and unsoldered IDE connector as in FAQs. by the way i've tested another IDE cable, another DISPLAY cable and another main display at all and i've got the same.
i really hope it so
let me know what do you think, i can post it to you if you can think you can fix it*. thank you very much.
p.s. *and if it's possible, to add more RAM if you can do that.
shapeless
#237663 - 16/10/2004 14:26
[Re: shapeless]
Post a photograph of the insides -- I'm still not clear about the states of the IDE and display cables..
#237664 - 17/10/2004 00:31
Loc: Italy
if you really think to need it, i'll send photos as soon as i can do that, by the way the empeg seems like new, the only thing you can see is a cutted display cable repaired by me as in faqs (i've tested the repaired cable with a tester and seems to work). i don't think i can take so little macro photos of the unsoldered IDE connector but is absolutely like the one in faqs. i really think (and hope) that's a fuse problem. let me know, thanks.
shapeless
#237665 - 17/10/2004 03:13
[Re: shapeless]
The display cable probably got pinched by the (grounded) drive tray. If the power wire within it got pinched then a fuse would have blown. This is fairly easy to check with a multimeter. There are 3 1A surface mount fuses in close proximity to the display header. Search the FAQ or this forum and you should find photos,,,
I assume that the VFD nipple is intact? That is definitely FAQed.
#237666 - 17/10/2004 14:40
[Re: genixia]
Oliver
#237667 - 17/10/2004 17:38
[Re: oliver]
Loc: Louisiana, USA
I would also like to add that the display may be blank due to a damaged ICT 18CV8-25 PEEL device. Apparently if there is a short in the display cable somewhere, it can blow this chip out. We've seen this twice now and the fix was to replace the chip. The problem is fairly easy to spot, as there will be a hole burned through the package. The part is not easy to obtain however, as they are discontinued and carry firmware. Hugo was kind enough to provide us with some preprogrammed ones. It's not an easy repair unless you really know what you are doing though.
Stu
#237668 - 17/10/2004 17:39
[Re: genixia]
Loc: Italy
today I've changed the repaired (as in FAQs) cutted wire of the VFD cable with an entire new wire (taken from a normal IDE cable) and re-tested my VFD module with another working motherboard and fortunately it is working to my great relief.
with this problem solved i've got the peace of mind to test the fuses and to discover that they are all blown (is it possible ? all 3 blown ?). right now, i need to replace the fuses and to get another VFD cable (the wires are ok but one cable connector is broken).
tomorrow i'll search for fuses in my city and i think i'll find them and do the replacement to myself, btw i'm near to be sure that i'll not find the VFD cable and connectors i need.
at this point, please suggest me if it's better to post the empeg to you to do all the repairs (a new VFD cable, fuse replacement, IDE connector resoldering) or if it's better to search and buy the components and do it to myself. i think i can do the soldering work but i'm not a professional and i dunno where to find the VFD cable.
thank you.
shapeless
#237669 - 18/10/2004 08:43
[Re: genixia]
Loc: Italy
Nevermind, i can't find SMD components in my city. I'm going to buy it online but taking it from Digy-Key costs me near 30$ for shipment over 3$ of fuses (using 5-10 days shipment option). same problem for the display cable. any ideas ? thanks.
shapeless
#237670 - 18/10/2004 09:07
[Re: shapeless]
Loc: Wellingborough, UK
#237671 - 18/10/2004 23:19
[Re: shapeless]
Fuses, I can donate. But fixing the display cable is more complex: the old solder-type connector on the displayboard will likely need replacing, and the best replacement is to install a pin header, and then use normal mating headers on each end of the cable.
#237672 - 19/10/2004 05:15
Loc: Italy
thanks Mark! ![](/ubbthreads/images/graemlins/smile.gif) about the display cable, the soldered connector over the display board is intact but the "cap" have a lateral tooth broken, the connector over the other side is broken and have a broken cap. i need 2 connectors like the one on the mother board side, one to replace the broken one, and another to use the cap for the display board one. the wires are ok but will be nice to replace that with another cable with all wires united and same color. do you know the name of that connector ? thanks.
shapeless
#237673 - 19/10/2004 12:31
[Re: shapeless]
The best fix for this display cable is to completely remove the old connector from the displayboard and replace it. This requires careful desoldering of the existing 20-pin connector there.
Replace it with a pin-header (same as what's on the empeg mainboard), and then crimp up a new cable using identical mating connectors on each end (again, same as the original mainboard end connector).
Digikey #3M1120-ND for the pin header, Digikey #ASA20K-ND for the two crimp-on connectors, and a length of high density ribbon cable (20 conductor).
If you can, and want to, do the whole proper repair, then paypal me US$12 and I'll mail you a care package with all of the pieces, plus four fuses for the mainboard. mlord at pobox dot com, cash/account payment only, NO CREDIT-CARDs.
#237674 - 22/10/2004 13:37
Loc: Italy
thank you mark, there are news:
i've found a really nice electronic professional that have replaced my fuses that are ok now and resoldered my IDE connector all for free, a great person! thanks Tony!, i'm returned to a situation like the original one (the one at the first post time), let me explain:
my display unit (with the repaired cable that i'd like to replace) is ok: i've tested the whole part with another working empeg and is pefectly functioning.
my empeg motherboard is working, * i can listen music * BUT: the "pulsing" led is working, it pulses normally when i powerup the unit and if i press the upper-left button it pulses less (pulsing but not arriving to completely off); the main display doesn't show nothing (when in stand by and while playing music). i've tested the motherboard with another working display unit and i've the same problem.
i'm suspecting a software problem.
this is the situation: my serial log says: ... Mounting first music partition Tried to mount /dev/hda4 as reiserfs but got error 19 Mounting second music partition Tried to mount /dev/hdc4 but got error 6 Error mounting partitions (possibly already mounted) ... (complete log posted later) i can listen music i can connect with emplode (serial and eth) i've tested v3alpha8 and v2 software i've tested hijack 413 and original v2 kernel i've removed config.ini file IR controller is working buttons are working when hijack is installed FTP is working all seems perfect but the main display is blank and the led is pulsing all the time.
any ideas ?
about the display cable, i really want to replace the repaired one but i think that desoldering the original display connector is difficult (for me) and avoidable because is really intact, i think i need a spare #ASA20K-ND to take a new "cap" for the original soldered connector as they use the same, i'll "crimp" wires one by one as i've done with the repaired one. btw, if i can't solve the main problem above and i have to ask to you to fix my empeg and you'll accept, i'll post it to you and i'll ask you to change the display connector and cable too, otherwise if there is a solution to the problem above, i'll ask you to post me two, urhmm... better three #ASA20K-ND and a length of high density ribbon cable, what do you think ?
my serial log:
empeg-car bootstrap v1.02 20001106 (hugo@empeg.com) If there is anyone present who wants to upgrade the flash, let them speak now, or forever hold their peace...it seems not. Let fly the Penguins of Linux!
e000 v1.04 Copying kernel... Calling linux kernel... Uncompressing Linux..................................... done, booting the kerne l. Linux version 2.2.17-rmk5-np17-empeg52-hijack-v413 (hijack@rtr.ca) (gcc version 2.95.3 20010315 (release)) #2 Tue Aug 17 18:05:30 EDT 2004 Processor: Intel StrongARM-1100 re Checking for extra DRAM: c1000000: wrote ffffffff, read e91ba9f0 NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel Computer Corp. empeg-car player (hardware revision 9, serial number 10101588) 16MB DRAM Command line: mem=16m Calibrating delay loop... 207.67 BogoMIPS Memory: 15008k/16M available (984k code, 20k reserved, 368k data, 4k init) Dentry hash table entries: 2048 (order 2, 16k) Buffer cache hash table entries: 16384 (order 4, 64k) Page cache hash table entries: 4096 (order 2, 16k) POSIX conformance testing by UNIFIX Linux NET4.0 for Linux 2.2 Based upon Swansea University Computer Society NET3.039 NET4: Linux TCP/IP 1.0 for NET4.0 IP Protocols: ICMP, UDP, TCP TCP: Hash tables configured (ehash 16384 bhash 16384) IrDA (tm) Protocols for Linux-2.2 (Dag Brattli) Starting kswapd v 1.5 SA1100 serial driver version 4.27 with no serial options enabled ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UART ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UART ttyS02 at 0xf8030000 (irq = 16) is a SA1100 UART Signature is 67706d65 'empg' Found custom animation at offset 0x9a790 Tuner: loopback=0, ID=-1 Scheduling custom logo. empeg display initialised. empeg dsp audio initialised empeg dsp mixer initialised empeg dsp initialised empeg audio-in initialised, CS4231A revision a0 empeg remote control/panel button initialised. empeg usb initialised, PDIUSBD12 id 1012 empeg state support initialised 0089/88c1 (save to d0005400). empeg RDS driver initialised empeg power-pic driver initialised (first boot) RAM disk driver initialized: 16 RAM disks of 4096K size empeg single channel IDE Probing primary interface... hda: HTS548060M9AT00, ATA DISK drive hda: HTS548060M9AT00, ATA DISK drive hda: HTS548060M9AT00, ATA DISK drive hda: HTS548060M9AT00, ATA DISK drive hda: HTS548060M9AT00, ATA DISK drive hda: HTS548060M9AT00, ATA DISK drive ide0 at 0x000-0x007,0x038 on irq 6 hda: HTS548060M9AT00, 57231MB w/7877kB Cache, CHS=7296/255/63 empeg-flash driver initialized smc chip id/revision 0x3349 smc9194.c:v0.12 03/06/96 by Er
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:06:3 4 Partition check: hda: hda1 < hda5 hda6 > hda2 hda3 hda4 RAMDISK: ext2 filesystem found at block 0 RAMDISK: Loading 320 blocks [1 disk] into ram disk... done. EXT2-fs warning: checktime reached, running e2fsck is recommended VFS: Mounted root (ext2 filesystem). empeg-pump v0.03 (19980601) Press Ctrl-A to enter pump...VFS: Mounted root (ext2 filesystem) readonly. change_root: old root has d_count=1 Trying to unmount old root ... okay Freeing unused kernel memory: 4k initempeg init 0.8 I see this is a developer image! Mounting proc Mounting first music partition Tried to mount /dev/hda4 as reiserfs but got error 19 Mounting second music partition Tried to mount /dev/hdc4 but got error 6 Error mounting partitions (possibly already mounted) Remounting first music partition read-only Remounting second music partition read-only No secondary hard disk Press 'q' now to go into development mode. You Have Zero Seconds To Comply... Starting player Timezone: Atlantic/South_Georgia Hijack: intercepting config.ini
hijack: removed menu entry: "Serial Port Assignment" khttpd: listening on port 80 kftpd: listening on port 21 player.cpp : 385:empeg-car 2.00 2003/04/01.
shapeless
#237675 - 22/10/2004 23:16
[Re: shapeless]
Mmm.. software looks fine. You can probably "view" the display remotely using EmpFace, JEmplode, or just a web-browser even (http://your.empeg.ip.addr/proc/empeg_display.png).
Triple-check those three fuses again?
Best not to send it to me -- I'm heading off down under for a spell, and it might get lost and not-repaired in the meanwhile. I think maybe genixia might be willing to have a go at it, though -- he's at least as good as I at empeg touch-ups now.
EDIT: Also, check out the chip that Stu (maczrool) mentioned in an earlier message
Edited by mlord (22/10/2004 23:19)
#237676 - 23/10/2004 09:07
Loc: Italy
urhm... my empeg doesn't reply to HTTP requests... i can access the .png from FTP and with jemplode, i've hijack installed (manually reinstalled and checked with jemplode that says it's the last version) but when i long-press the right round button i can see through jemplode that it switches to auxiliary, no hijack menu... do you think it's connected with the problem ?
fuses rechecked, they are ok and i can't see burned holes in circuitry, could you indicate me where the chip is ? thanks
genixia, could i ask you to give a look to my empeg ?
(Edit: fixed a duplicate post -wfaulk)
Edited by wfaulk (23/10/2004 14:11)
shapeless
#237677 - 23/10/2004 11:55
[Re: shapeless]
Quote: when i long-press the right round button i can see throug jemplode that it switches to auxiliary, no hijack menu..
That is normal behaviour when the knob is pressed for LONGER than 1 second.
But you've now proven to yourself that the blank physical display is a hardware problem, not software.
#237678 - 23/10/2004 22:24
Loc: Italy
ok, it's clear. i don't know exactly how the display is managed but i can't see the hijack menu in any way through jemplode. could you give me more informations about the ICT placement and how to test it ? i can't see any "burned hole" in any component. do you think i should send PM to genixia and ask him for a repair ? i've just tried with schofiel without success, i don't know if there is a "right way" (besides good education) to ask this kind of things.
#237679 - 03/11/2004 11:36
[Re: maczrool]
Loc: Italy
Quote: I would also like to add that the display may be blank due to a damaged ICT 18CV8-25 PEEL device. Apparently if there is a short in the display cable somewhere, it can blow this chip out. We've seen this twice now and the fix was to replace the chip. The problem is fairly easy to spot, as there will be a hole burned through the package. The part is not easy to obtain however, as they are discontinued and carry firmware. Hugo was kind enough to provide us with some preprogrammed ones. It's not an easy repair unless you really know what you are doing though.
Stu
i can't see any "burned hole" in any chip, could you please give me more informations about where the chip is and how to test it please ?
shapeless
#237680 - 04/11/2004 00:33
[Re: shapeless]
Loc: Louisiana, USA
The ICT PEEL that goes bad is located behind the VFD. Peel it back from the display board and at least do a visual inspection.
Hope this helps, Stu
#237681 - 04/11/2004 00:48
[Re: maczrool]
Quote: behind the VFD. Peel it back from the display board
An Exacto knife (or similar, or a dreaded box cutter) can be used to gently slice through the three pieces of double-stick foam tape that hold the VFD against the PCB. Just add a new small slice of double stick tape onto each of the three sliced foamies afterwards to stick it all back together again.
#237682 - 04/11/2004 03:34
...and be careful not to bust the VFD nipple!
#237683 - 04/11/2004 03:36
[Re: genixia]
Oh, hang on...didn't he determine earlier that the display board worked in another player?
