#231318 - 23/08/2004 15:02 How much current is drawn on the switched power lead?
kday
Loc: Boston, MA
Can I hook it up directly to the remote amp output of another head unit, or do I need a relay?
#231319 - 23/08/2004 15:21 Re: How much current is drawn on the switched power lead? [Re: kday]
Assuming that the player doesn't have any problems with its main constant power lead (blown fuse etc), and assuming that it's a Mark2a player instead of a Mark2, then I think you can do what you're asking. I think the bulk of the current is drawn fron the constant power lead, and the ignition-sense is only a sensor line and draws very little current.
However, if your player is a Mark 2, there is a chance that you could draw too much current. There is a difference in the power scheme between the 2 and the 2a described here. If you blow the fuse on the constant-power wire of a Mark 2, then it will draw its current from the ignition switched wire.
#231320 - 24/08/2004 02:16 Re: How much current is drawn on the switched power lead? [Re: tfabris]
kday
Loc: Boston, MA
Eh. With that many caveats I think I'll spend the 10 minutes and add a relay. Thanks.
