#229908 - 05/08/2004 09:37 USB to Serial adapter..
SE_Sport_Driver
I connecting to my empeg, checking to bootlog after getting one of those USB to Serial adapters... The boot log looks all garbled up. Anyone have any tips on setting one of these up? Is the one I got too slow or something?
Running XP, Com8.
Here is the boot log:
empeg-car bootstrap v1.02 20001106 (hugo@empeg.com)_chunk_cache_runner.cpp: 294:Filling up space (-21)
If there is anyone present who wants to upgrade the flash, let them speak now,cache_runner.cpp: 294:Filling up space (-21)
or forever hold their peace...it seems not. Let fly the Penguins of Linux!up space (-21)
e000 v1.04_chunk_cac
Copying kernel...:Filling up space
Calling linux kernel...
Uncompressing Linux..................................... done, booting the kerne)
l.
spindown_chunk_cache_runner.cpp:
2.95.3 20010315 (release)) #2 Wed Aug 4 00:27:49 EDT 2004
Checking for extra DRAM:_cache_runner.cpp: 294:F
c1000000: wrote ffffffff, read e91ba9f0
spindown_chunk
empeg-car player (hardware revision 9, serial number 30102609) 16MB DRAM
spindown_chunk_cache_runner.cpp: 294
Command line: mem=16m)
Calibrating delay loop... 207.67 BogoMIPS spindown_chunk_cache_runner.cpp: 294:Fi
Memory: 15008k/16M available (984k code, 20k reserved, 368k d
Linux NET4.0 for Linux 2.2.cpp: 294:Filling up space
spindown_chunk_cache_runner.cpp: 294:Fill
IP Protocols: ICMP, UDP, TCP_cache_runner.cpp: 294:Filli
Starting kswapd v 1.5_runner.cpp: 294:Fill
SA1100 serial driver version 4.27 with no serial options ena
Found custom animation at offset 0x9877cche_runner.cpp: 294:Filling up space (-2
Tuner: loopback=0, ID=-1
Scheduling custom logo.n_chunk_cache_runner.cp
empeg display initialised.1)
empeg dsp audio initialised
spindown_chunk_
empeg dsp mixer initialisedg up space (-21)
empeg dsp initialised
empeg audio-in initialised, CS4231A revision a0illing up space (-21)
empeg remote control/panel button initialised.chunk_cache_runner.cpp: 294:Filling up space (
spindown_chunk_c
empeg single channel IDEing up space (-21)
Probing primary interface...
hdb: IC25N080ATMR04-0, ATA DISK driveFilling up space (-21)
hda: HTS548080M9AT00, ATA DISK drive
hdb: IC25N080ATMR04-0, ATA DISK drive_cache_runner.cpp: 294:Filling up spa
hda: HTS548080M9AT00, 76319MB w/7877kB Cache, CHS=9729/255/63
smc9194.c:v0.12 03/06/96 by Erik Stahlman (erik@vt.edu)space (-21)
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0a:3
spindown_chunk_cach
1r
Partition check:lling up space (
spindown_ch
hdb: hdb1 < hdb5 hdb6 > hdb2 hdb3 hdb4ce (-21)
RAMDISK: ext2 filesystem found at block 0chunk_cache_runner.cpp: 294:Filling up sp
spindown_chunk_cache_runner.cpp: 294:Filling u
EXT2-fs warning: checktime reached, running e2fsck is rec
Mounting proc
Starting player
Timezone: America/Detroit
hijack: removed menu entry: "Button Codes Display"
hijack: removed menu entry: "Button Illumination Level"
hijack: removed menu entry: "Font Display"
hijack: removed menu entry: "Show Flash Savearea"
hijack: removed menu entry: "Volume Level on Boot"
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
! tags.cpp : 61:Failed to open tags (0xc0041002).
#229909 - 05/08/2004 10:02 Re: USB to Serial adapter.. [Re: SE_Sport_Driver]
Are you capturing to a file? Many times, screen buffer captures tend to show this kind of thing.
#229910 - 05/08/2004 10:59 Re: USB to Serial adapter.. [Re: pgrzelak]
I agree with Paul. Capture to a file. Ditch hyperterminal if possible too. I'm guessing you are using cut and paste using hyperterminal.
This seems to happen quite often on boot log captures for some reason - probably the 115200 baud with no flow control doesn't help eventhough the average PC should be able to hand those kind of data rates.
Edit:
Oh and we use a large number of these USB-serial adapters quite successfully.
Looking at the log, it seems it's overwriting things. You can see player messages at the very beginning of log well before the player even starts.
Edited by Shonky (05/08/2004 11:09)
#229911 - 05/08/2004 11:09 Re: USB to Serial adapter.. [Re: Shonky]
No, it's because, in contrast to the ones supplied with earlier versions of Windows, XP Hyperterminal is hopelessly, unusably, QA-clearly-didn't-even-run-it-once buggy. Get PuTTY or Teraterm instead.
#229912 - 05/08/2004 14:49 Re: USB to Serial adapter.. [Re: peter]
SE_Sport_Driver
Thanks everyone.
Not to sound terribly cheap.. but are any of those free? And if not, is there one you prefer for "empeg" type uses?
#229913 - 05/08/2004 14:53 Re: USB to Serial adapter.. [Re: peter]
genixia
PuTTY is IIRC...
#229914 - 05/08/2004 15:35 Re: USB to Serial adapter.. [Re: genixia]
Teraterm is as well
#229915 - 05/08/2004 15:36 Re: USB to Serial adapter.. [Re: peter]
matthew_k
There's a version of putty that'll work on a serial connection? AFAIK there isn't, but I'd be happy to hear that there is.
#229916 - 05/08/2004 15:41 Re: USB to Serial adapter.. [Re: matthew_k]
Hmm. Yeah. Just ran it and it doesn't seem to support serial. I use SecureCRT for SSH and serial and it works great but it is expensive.
#229917 - 05/08/2004 17:00 Re: USB to Serial adapter.. [Re: matthew_k]
Teraterm works well. PuTTY does not (yet?) support serial connections.
#229918 - 05/08/2004 19:17 Re: USB to Serial adapter.. [Re: wfaulk]
matthew_k
Yeah, that's been there since the last My Terminal Program Is Better Than Your Terminal Program discussion. I wish they'd implement it, Putty is great otherwise. (All it needs is a config-file-instead-of-the-registry setting so it'll work perfectly off my flashdrive)
#229919 - 05/08/2004 19:24 Re: USB to Serial adapter.. [Re: tman]
SE_Sport_Driver
TeraTerm Pro is working great! Thanks guys!
#229920 - 05/08/2004 19:26 Re: USB to Serial adapter.. [Re: tman]
SecureCRT
I've been using the VT100 fonts that came with that for years now, long after my version of SecureCRT became obsolete. I keep them on my USB flash drive, even.
