#224399 - 11/01/2004 17:04 Looks like bad transmission? (trio 0.1.4.alpha4)
johann
I will try updating to the latest trio... but wondered if anyone had some thoughts. I originally installed 0.1.4.alpha4, worked fine, 2 receivers, Win 2K, ARM software.
Lately, I've been seeing what appears to be a lot of "resend requests" and skipping audio playback.
For example:
opened contentStream. tune: Between Your Heart And Mine, currOffset: 955604
gotContent. reqLen: 6000, actualLen: 2920
opened contentStream. tune: Between Your Heart And Mine, currOffset: 967098
gotContent. reqLen: 5494, actualLen: 5272
thx,
-j
#224400 - 12/01/2004 01:41 Re: Looks like bad transmission? (trio 0.1.4.alpha4) [Re: johann]
markb
For what its worth, I had a similar problem. I would get masses of Resend requests and occasional skipping. I eventually tracked it down to a dodgy 4 port switch. After replacing it, it runs perfectly.
Might be worth trying to remove any switches/hubs and test it like that.
Good luck
M
#224401 - 12/01/2004 08:09 Re: Looks like bad transmission? (trio 0.1.4.alpha4) [Re: markb]
johann
Thanks, good suggestion. My 4-port hub is my broadband router as well, I've swapped it out with no success, same problems.
