#219172 - 21/06/2004 07:09 ISP info needs translated
CrackersMcCheese
Advice needed from those in the know!
There are plans here to run a wireless network from a college and provide an internet connection to 15 learning centres.
I have been sent information for me to select a broadband provider for the college but I have no experience of what I actually need.
1) Is there any advantage to static over dynamic IP addressing?
2) Number of IPs... What is the difference between having one or multiple
3) Do I need PAT and NAT?
4) What would be an ideal connection speed? I think the 1MB package would be insufficient.
Cheers guys for keeping me from looking incompetent!
Edited by PhilipOHare (21/06/2004 07:37)
#219173 - 21/06/2004 08:46 Re: ISP info needs translated [Re: CrackersMcCheese]
Yes. If you're running servers from your site, you'll need (for all practical purposes) a static IP. Even if you're not, dynamic IPs can be a pain when dealing with long-term TCP sessions, like a telnet or ssh session, since if your IP address changes, you lose your session. How often it would change is an important point, too. It might change every five minutes or it might change once a week or less.
This has more to do with running servers from your site. If you want to have multiple servers accessible, it's easier, sorta, if you have multiple IP addresses, though it's not a requirement except in certain cases. Also, multiple IP addresses would make it easier to have a DMZ, which is a separate network that's more open to the internet than your regular network used for, usually, servers that need more unfettered access.
If you have more computers that you want to access the internet than you have IP addresses, then you need NAT. You can do it yourself if your ISP is offering to do it for a cost. NAT also increases security a bit, as it implies having a firewall, too, though not necessarily a very complete one. (I haven't heard the term "PAT" in ages, but it's essentially the same thing.)
This obviously depends on how much bandwidth you need. ADSL starts at around 512kbps and goes up to about 8Mbps. T1 lines, formerly the default commerical non-dialup access ran at 1.522Mbps. Honestly, this is something that's not really answerable. You need to consider how much traffic will be being passed at once. How many computers do you have? Is it going to be all web traffic or are people going to be downloading CD images? Make sure you know both the incoming and outgoing bandwidth. If you plan to have no servers, then outgoing bandwidth isn't important, but if you do, you wouldn't want to get an 8Mbps line and then be disappointed to discover it's only 512kbps outgoing.
You might also find out if your ISP is going to provide open access to everything or if they're blocking ports or forcing you through a transparent web proxy or anything else obnoxious like that.
Also, you might want to see if they have upgrade options. For example, you might be able to get a line that's reprovisionable on the fly, so that if it turns out, for example, that the 1Mbps line you chose isn't fast enough they can just make it bigger without having to redo everything and cause a lot of downtime.
#219174 - 21/06/2004 09:19 Re: ISP info needs translated [Re: wfaulk]
CrackersMcCheese
Thanks for all the information.
So if the college has this single ADSL access point coming in, and are wirelessly piping it out to 15 centres, it must be on a server, no? And if so, then they will need a static IP, PAT and multiple IP addresses?
Or what if they simply connect the ADSL link to a wireless router... would that automatically allocate the IPs and therefore they'd have no need for PAT and multiple IP addresses?
Sorry if my understanding of this is very very flawed
#219175 - 21/06/2004 09:36 Re: ISP info needs translated [Re: CrackersMcCheese]
A server is a computer that provides data to other computers. In this case, I'm using it to mean that someone on the internet-at-large would want to access your computers without you having to initiate the connection, as if you ran a web server or a mail server or something like that. If you have no need for anyone to access your computers externally, then you have much less need for a static IP address. Keep in mind that external access includes remote administering.
Your scenario doesn't say anything about incoming traffic, and none of what you said indicates that you need a static IP, which is not to say that you don't need one; I just don't have any data that indicates you do at the moment.
Wireless routers include NAT. They do an okay job of it. If you'd be happy with that, then you don't need your ISP to provide NAT service. However, 15 remote sites sounds like a lot of computers. (Hell, "college" sounds like a lot of computers.) I don't think that a generic wireless router will be powerful enough.
You need NAT if you have more computers than you have IP addresses assigned by the ISP. There are other reasons you might want it, but you definitely need it in that case.
