#21699 - 02/11/2000 08:56 remote, frequency
anti
Loc: BaWue, Germany, Europe
Can anyone tell me the frequency that the KCA-R6A uses ?
I'm thinking about using my empeg-remote for everything.
MKII 08000073 12GB BLUE
-------------------- MKII 08000073 40GB BLUE
#21700 - 02/11/2000 09:05 Re: remote, frequency [Re: anti]
Happy Birthday schofiel
It's Infra Red, not radio. Are you talking about the encoding scheme the remote uses?
#21701 - 02/11/2000 09:29 Re: remote, frequency [Re: schofiel]
anti
I was talking about the base frequency of the signal.
Right now I'm working with RC5 (Philips and others) which uses 36kHz.
I have a small receiver module (TSOP1736) in every room and would like to know which one to use for the KAC-R6A.
I really prefer this tiny thing over my big old Philips remote.
#21702 - 02/11/2000 10:43 Re: remote, frequency [Re: anti]
bmihulka
Loc: Lincoln, NE
Here is some info describing the Kenwood protocol.
TECHNICAL INFO
Code length: 32 bits
Carrier: 39.2kHz
The code is only transmitted once, and after that a stop code is transmitted.
Header: | |
16T 8T
8.8ms 4.4ms
1 is coded: | |
T 3T
0 is coded: | |
T T
Stop code: | | | |
16T 4T T
8.8ms 2.2ms
T = 550us
Space between transmissions: 95000us between the start of the codes.
To use the code (not with the remote package):
GROUP * 10000h + (Code * 100h) + (Code XOR FFh)
Brian
-See my empeg here-
Brian
-See my empeg <a href="www.hulkster.net/empeg" target="_blank">here</a>-
#21703 - 02/11/2000 12:37 Re: remote, frequency [Re: anti]
I think you mean the signal clock rate at which the words are generated. Not too sure, I'm afraid.
#21704 - 03/11/2000 04:35 Re: remote, frequency [Re: bmihulka]
anti
Carrier: 39.2kHz
Thanks, that's exactly what I wanted :)
It looks like I have to replace all my 36kHz modules with 40kHz modules :(
At least it's not 455kHz (old Kenwoods...)
And a TSOP1740 is only ~1$
#21705 - 03/11/2000 21:50 Re: remote, frequency [Re: bmihulka]
borislav
Loc: Sunnyvale, CA, USA
A related question: I'm toying with the idea of buying an infrared keyboard and getting it to work with the empeg. I know I'll have to write a driver from scratch, but can I expect the IR port to physically be able to pick up signals from a random IR transmitter? What parameters do I have to make sure to match?
Thanks,
Borislav
