#216987 - 24/05/2004 21:41 I attempted the memory upgrade, I have a chalenge.
jamville
Loc: South Texas
Do you think I killed any componemtes? Did I merely desolder something?
The boot log is as follows:
(prefetch abort vector)
Thanks in advance.
Joe Mumme
#216988 - 24/05/2004 22:15 Re: I attempted the memory upgrade, I have a chale [Re: jamville]
genixia
Solder bridges.
Check pins 13, 19-24, 27-33, 36. They're the write enable, address lines and output enable respectively. Something is preventing the CPU talking to the rest of the system.
#216989 - 24/05/2004 23:20 Re: I attempted the memory upgrade, I have a chale [Re: genixia]
jamville
Loc: South Texas
genixia, Thank you Sir,
I removed the solder bridges that I could see.
log is as follows:
(undefined instruction vector)
Joe Mumme
#216990 - 25/05/2004 01:58 Re: I attempted the memory upgrade, I have a chale [Re: jamville]
The fact you are getting the first line means a fair number of your data and address lines are OK.
I would guess the boot flash is only 16 bits and you have messed up the other half of the 32 bit data bus to the RAM so when the kernel is trying to decompress into RAM if falls over. I assume the decompression routine is copied to RAM first for speed and that's the bit causing the undefine instruction vector.
Can you get a multimeter with a continuity buzzer to check every line? I little trick because of the small size of the pins is to get some solid core wire and wrap that around the probes. Then use the solid core wire as probes. Makes it easier for stuff like this.
Did you possibly count pin 14 from the wrong end of the chip?
#216991 - 25/05/2004 13:18 Re: I attempted the memory upgrade, I have a chale [Re: Shonky]
jamville
Loc: South Texas
Christian,
The dot is pin 1, right?
I'll test for continuity shortly.
Thank you,
Joe Mumme
#216992 - 25/05/2004 16:24 Re: I attempted the memory upgrade, I have a chale [Re: jamville]
Yes. The dot is pin 1 and then count anticlockwise. Continuity test should show any problems. If you use my trick with the solid core wire, try and touch the pads on the PCB rather than the bottom set of pins - just to make sure the each pad is still connected to the bottom pin which is connected to the top pin.
#216993 - 28/05/2004 11:25 Re: I attempted the memory upgrade, I have a chale [Re: Shonky]
jamville
Loc: South Texas
Thanks again Christian.
I finally got a chance to look at it today. I do have some opens.
Thanks again for your input.
Joe Mumme
