#21507 - 31/10/2000 01:36 Kernel Panic
mardibloke
Loc: Penarth, UK
I am after suggestions of things to try, as my Empeg just boots to the empeg logo and sits there. Have tried reloading the consumer 1.01 image ( did have dev 1.01 ) but no joy. Note that my unit was "bg" ( Before Glue ).
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...VFS: Cannot open root device 03:05
Kernel panic: VFS: Unable to mount root fs on 03
Rod, UK Mk2 18gig Red S/No.341
Rod, UK
#21508 - 31/10/2000 02:44 Re: Kernel Panic [Re: mardibloke]
fvgestel
Loc: Netherlands
this looks like your ide connector has come loose...
Ask support@empeg for instructions...
Frank van Gestel
Frank van Gestel
#21509 - 31/10/2000 02:57 Re: Kernel Panic [Re: mardibloke]
Liufeng
Loc: Alaska
Sounds like your hard drive is bad or your HD cable has come loose. You should probably write to support@empeg.com and ask them if you can open it up and take a look at the cable. That has been a problem in the past. I thought they fixed it with glue or something.. and I've never had trouble with mine so it must be a particuliar batch of empegs.
Tom
Reg #2845: Mark 1 #00173, Mark 2 #119
Reg #2845: Mark 1 #00173, Mark 2 #119, Mark 2a
