#20720 - 18/10/2000 19:45 Which ID3 editor?
dewdman42
Hello all. Let's assume for a minute that I have a humongaloid directory structure (tree) full of MP3's and let's assume that they are all missing ID3 tags. What is the best program to use for filling in the tags? Are there any command line utilities for this sort of thing? IN particular, I'd like to know what tool will let me put the same value into a particular field of multiple files. For example, if a given dir has all the songs from a certain album, then the year, artist, genre and source fields all need the same value for that album. I'd like to be able to type it in once and easily populate multiple files with the same info. The only thing needing to be different is the song name...which is usually already close to correct.
Which tool?
-steve
sjs@bstage.com
#20721 - 19/10/2000 06:57 Re: Which ID3 editor? [Re: dewdman42]
Squid2k1
Loc: Ocean Floor
I use Dr. Tag. It fixed all my invalid v2 tag problems. It supports multiple files, multiple sub-dirs, etc. Undo, too. Intelligent tag creation from filename, too.
Squid2k1
18GB of Green Mk II Fury - Fast As A Shark
Squid2k1 --- 18GB of revived Green Mk II Fury - Fast As A Shark
#20722 - 19/10/2000 12:01 Re: Which ID3 editor? [Re: Squid2k1]
dewdman42
Where can I find Dr. Tag?
#20723 - 19/10/2000 12:26 Re: Which ID3 editor? [Re: dewdman42]
mtempsch
#20724 - 19/10/2000 16:14 Re: Which ID3 editor? [Re: dewdman42]
doug316
Without a doubt, helium:
http://www.intermedia.st/helium/
