#20700 - 18/10/2000 08:55 Playlist randomization
Squid2k1
Loc: Ocean Floor
I have a question. In emplode you can make a playlist and set a property for it to always be randomized. Does this mean EMPEG will see this and everytime it starts that playlist it automatically randomizes it? Is this the same as Shuffle? Do I need to turn Shuffle on or just leave it? Will Shuffle reset to Off when I switch to a non-randomized playlist?
When I select Shuffle from the menu it shows either On or Off. Is this its current setting or what the setting will be if I select it (DNPP)?
Thanks.
Squid - jammin' to 18GB of Green fury (Fast As A Shark)
Squid2k1 --- 18GB of revived Green Mk II Fury - Fast As A Shark
#20701 - 18/10/2000 10:57 Re: Playlist randomization [Re: Squid2k1]
Yes. Independently of the state of the "shuffle" feature.
Not exactly. Shuffle takes the currently-playing playlist and its sub-playlists, then flattens that list, then de-dupes that list (based on FID), then shuffles it like a deck of cards.
"Always Randomize" does much less than "Shuffle". It takes the current playlist and shuffles it. It doesn't flatten it first (hence, sub-playlists are not shuffled, just the positions of the playlists themselves), and it doesn't de-dupe (so you might possibly get the same song twice).
Personally, I don't use the "Always Randomize" feature. I choose whether or not to shuffle from the remote. All of my playlists are sequential. So I turn shuffle on and off with the "0" key on the remote as the whim strikes me. I find this the most flexible method.
EMPEG GUYS: THIS IS A SERIOUS PROBLEM WITH THE USER INTERFACE. It's been mentioned before, and it really should be fixed. After hitting that option from the menu, it needs to flash "Shuffle On" or "Shuffle Off" the same way it does when you hit "0" on the remote.
To answer your question, Squid, the main menu indicates the current state of affairs. When you hit it, it toggles it.
And if you still can't figure out its behavior from that description, that's just more ammo to get the Empeg guys to fix the interface.
#20702 - 18/10/2000 15:38 Re: Playlist randomization [Re: tfabris]
Shuffle selection has been changed in v1.1 (which has a number of shuffle modes, not simply on or off). There is a menu entry for each mode, including Off.
#20703 - 18/10/2000 16:02 Re: Playlist randomization [Re: rob]
Ah, cool then. I take back the boldface and all-caps.
#20704 - 18/10/2000 17:43 Re: Playlist randomization [Re: rob]
TEASE!
DiGNAN
#20705 - 18/10/2000 17:51 Re: Playlist randomization [Re: tfabris]
Happy Birthday tanstaafl.
But not the italics?
#20706 - 18/10/2000 18:22 Re: Playlist randomization [Re: tanstaafl.]
Okay, the italics, too.
(I'd forgotten that I used italics in the original message. Why did I know it'd be you who'd point that out?!)
#20707 - 18/10/2000 22:27 Re: Playlist randomization [Re: rob]
teemcbee
Is there a beta of the 1.1 already available / when in release ?
What's about Voice Recognition? (is this asleep as I didn't hear of it for a long time now)
TeeMcBee
Got my Mk2! # 080000143
TeeMcBee
#20708 - 19/10/2000 03:51 Re: Playlist randomization [Re: tfabris]
Squid2k1
Loc: Ocean Floor
So, basically "Always Randomize" is equivalent to Shuffle only if the playlist has no sub-playlist (just songs inside of it)?
#20709 - 19/10/2000 07:32 Re: Playlist randomization [Re: Squid2k1]
Yes, "always randomise" only shuffles the immediate children of a playlist.
#20710 - 19/10/2000 08:45 Re: Playlist randomization [Re: teemcbee]
VR is not in 1.1, this will be a later release. The systems we're evaluating are still in development, and so aren't complete enough to fully evaluate.
