#184336 - 12/10/2003 21:26 wishlist
Daria
a.k.a. stuff I can't have (yes, I already went and read stuff on Riovolution)
in RMM Lite:
-discovery so I don't have to type in IP addresses
-a way of updating firmware that doesn't involve a Windows machine
and generally:
-enough information that a USB driver can be written for non-Windows
#184337 - 13/10/2003 03:46 Re: wishlist [Re: Daria]
This isn't very likely, at least with the current firmware, because it wouldn't be very useful -- it's a read/write sector kind of interface, which means the PC needs to implement the filesystem, and Karma uses an extremely proprietary and icky filesystem. Non-Windows is what the Ethernet interface is for.
IMO (but there are other opinions at Rio) the best answer would be a so-called "mass storage class" player, one where you plug it in and with no drivers at all it becomes another drive letter, like Ipods and digital cameras do, due to having a standard Fat32 filesystem.
#184338 - 13/10/2003 05:10 Re: wishlist [Re: Daria]
mschrag
Loc: Richmond, VA
I was going to write this towards the end, but got nervous about adding a new feature in at the last minute. Hopefully in a firmware in the not-to-distant future it will switch back to an applet and it will know the IP address of its launcher.
Haven't heard if this is possible without USB yet ... If it IS possible, maybe they'd let me port this.
ms
#184339 - 13/10/2003 09:11 Re: wishlist [Re: peter]
Daria
Sure, but no firmware updater for non-Windows implies I need USB for it, so, given that...
#184340 - 13/10/2003 11:18 Re: wishlist [Re: Daria]
I'll bet that if they really wanted to, they could implement a firmare updater with ethernet.
It would have to be similar the empeg, where, if the ethernet firmware updater failed, the only fallback would be PC and serial/usb. But as long as it worked, you're OK.
#184341 - 13/10/2003 13:34 Re: wishlist [Re: tfabris]
Daria
That would be fine. Needing to boot a VirtualPC (which at the moment is being fussy) to update firmware is sort of crappy.
