#177162 - 27/08/2003 14:46 My tuner module has broken - any ideas?
craigalsop
Loc: Edinburgh
Any ideas - I get a really bad reception from my tuner module now (as of 2 weeks ago) Lots of static, crackles & pops - some days it has no reception at all.
Although this sounds like the FAQ item with dodgy connectors/wiring, I don't believe it is, because I swapped my module with a known working one & the other module worked fine.
I've checked for obvious bad joints & can't see anything wrong.
Maybe the crystal has died?
If anyone has any suggestions, I'd be glad to hear them....
Craig
#177163 - 27/08/2003 17:15 Re: My tuner module has broken - any ideas? [Re: craigalsop]
David
Loc: Cambridge
You've probably got a faulty opamp chip in the tuner module. Contact Rob Schofield for a reapir. carsupport@xs4all.nl.
#177164 - 03/09/2003 14:35 Re: My tuner module has broken - any ideas? [Re: David]
davec
Loc: Georgetown, TX USA
Did anyone ever post a pic of the dry solder joint problem in the tuner? I can't find the original thread but it was mentioned that my FM output may have this problem and someone was going to post a pic.
Dave Clark Georgetown, Texas MK2A 42Gb - AnoFace - Smoke Lens - Dead Tuner - Sirius Radio on AUX
#177165 - 25/09/2003 14:29 Re: My tuner module has broken - any ideas? [Re: David]
craigalsop
Loc: Edinburgh
Well, it's been almost a month after emailing carsupport@xs4all.nl, and I've had no response - does anyone know if this is the right address for support?
(I've been away for a couple of weeks, so haven't been able to chase it untill now)
cheers,
Craig
#177166 - 26/09/2003 04:41 Re: My tuner module has broken - any ideas? [Re: craigalsop]
Unfortunately Rob has had other things on his mind over the last several weeks. I don't think he will be doing much car support right now, but I'm sure he'll post when he's back on the case.
#177167 - 26/09/2003 09:29 Re: My tuner module has broken - any ideas? [Re: rob]
julf
Ouch! Anything we can help with?
#177168 - 27/09/2003 08:30 Re: My tuner module has broken - any ideas? [Re: craigalsop]
mrfixit
Would you like to sell the tuner broken?
Ben
hijacked
