#176677 - 25/08/2003 04:39 Start failed.
alich
Hello,
I have a problem that I have not been able to find a solution for.
This problem appeared directly after upgrading to 2.0-beta13. (The problem is that when downgrading to 1.03 the problem is still there)
The kernel starts fine. But when /empeg/bin/player try to start it fails with:
In serial interface: Vcb: 0x4044d00
(when having added <ReserveCache=8> to <config.ini> it becomes: 0x4054d00.
In the empeg display i read. "Start failed: 35d562"
Then nothing happens (if I don't press ctrl-c)
I have checked the disk (seem to be ok)
It is no problem to CTRL-C out and start up the shell.
I have not waited more than approximately 20 min.
--------------- log ----------------
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.14-rmk5-np17-empeg51 (mac@aphex) (gcc version 2.95.3 20010315 (release)) #16 Wed Jul 24 18:19:54 BST 2002
empeg-car player (hardware revision 7, serial number 90000979)
Command line: mem=12m
Memory: 10968k/12M available (964k code, 20k reserved, 332k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is ffffffff 'ÿÿÿÿ'
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004680).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DARA-206000, ATA DISK drive
hda: IBM-DARA-206000, 5729MB w/418kB Cache, CHS=12416/15/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:12:03:d3
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To Com.Starting player
Using non-standard cache size 68 (adjustment 16)
Vcb: 0x4044d000
------- HANG POINT .---------
#176678 - 25/08/2003 07:26 Re: Start failed. [Re: alich]
Send me an email (rob@empeg.com) and I'll work through the problem.
