#171874 - 23/07/2003 00:48 HDD as Storage?
rowitech
Loc: Germany, Cologne
I tried to transfer 50MB via ftp to my /programs0. After 6 MB is aborts with an "internal error". So my general question: Isn't it possible to transfer any file to the empeg? I only want to use it as a portable harddisk.
Rolf
Connecting Empeg via Bluetooth or Wireless LAN http://empeg.rowi.net
*** Proud owner of the European Worst Install Trophy 2003 ! ***
RoWi
#171875 - 23/07/2003 01:37 Re: HDD as Storage? [Re: rowitech]
I'm pretty sure programs0 is only 16 or 32 megabytes minus filesystem overhead. I'm guessing you also have other stuff already there?
I just use /drive0 or /drive1 for big files. Just make sure you correctly mount read only when you're done.
#171876 - 23/07/2003 03:49 Re: HDD as Storage? [Re: rowitech]
Yup, Shonky is right. If you want to store big files, it has to go on one of the music partitions.
I regularly use /drive0 to taxi files much larger than 50mb between home and work.
#171877 - 23/07/2003 11:21 Re: HDD as Storage? [Re: tfabris]
rowitech
Yes, works. Thank you. I should get an df on the empeg :-).
Rolf
RoWi
#171878 - 24/07/2003 02:04 Re: HDD as Storage? [Re: rowitech]
I do actually have df on my developer version empeg (which you'll need anyway) - it came with it, I didn't add it. I think it used to work. However it now says "df: cannot read table of mounted filesystems: No such file or directory". Dunno what that means exactly.
I figure I'll worry about it when disc space starts getting low. I know I have about 20Gb free but I don't know how it's spread across the drives
Edit : It appears to be something to do with /etc/fstab or possibly a non existent /etc/mtab.
Edited by Shonky (24/07/2003 02:06)
#171879 - 24/07/2003 03:18 Re: HDD as Storage? [Re: Shonky]
Happy Birthday bonzi
I am sure that an easy (as in defining an alias or something) workaround exists (I use it, but don't have my empeg handy, and can't remember what it was exactly). I think this was discussed several times, so serach a bit...
Hm, I think that it boiled down to df working if given a single device (or was it mountpoint) as parameter, and those, in turn, can be gleaned from /etc/something-or-other. So, a bit of grepping etc would probable do...
Sorry for not being more helpful...
#171880 - 24/07/2003 08:15 Re: HDD as Storage? [Re: Shonky]
Loc: Los Angeles, CA
all you have to do is do a "df ." while in the partition. it will give the error, but will also output the free space. thats what i've been doing, at least.
#171881 - 24/07/2003 19:28 Re: HDD as Storage? [Re: Shonky]
genixia
It's complaining because it can't find /etc/mtab.
