Page 2 of 2 < 1 2
#170322 - 14/07/2003 01:22 Re: Mark1 dead? [Re: vbezemer]
Happy Birthday schofiel
You are not supposed to tighten it, it is designed to be loose.
So it hangs when you switch to the radio: I am going to go check this on my own player to see if this is a problem with V2 as I have not tried the radio since upgrading.
#170323 - 14/07/2003 01:23 Re: Mark1 dead? [Re: schofiel]
Hang on - you say it doesn't respond to the remote. Which remote are you using, the Kenwood or the Rio? I have found an issue with the Kenwood relating to the Radio.
#170324 - 14/07/2003 01:24 Re: Mark1 dead? [Re: andym]
vbezemer
OK, I will take a closer look at this post. (my English and technical skills are not that good )
Vince
p.s. I have not changed any disk owse
#170325 - 14/07/2003 01:25 Re: Mark1 dead? [Re: vbezemer]
Since it sounds like a memory issue, I would say you should try and revert to V2 consumer. If that still hangs it, then go back one further to 2B13 consumer, then report your findings.
#170326 - 14/07/2003 01:27 Re: Mark1 dead? [Re: vbezemer]
Sounds like you may still have some form of handshaking enabled. Make sure you have NO handshaking set in your term s/w
#170327 - 14/07/2003 01:29 Re: Mark1 dead? [Re: vbezemer]
What size (capacity) are the hard drive(s) ?
#170328 - 14/07/2003 01:32 Re: Mark1 dead? [Re: mlord]
vbezemer
I have a Toshiba 6495MB hdd
#170329 - 14/07/2003 02:49 Re: Mark1 dead? (UPDATE) [Re: schofiel]
vbezemer
When it worked, the remote worked too...
The situation is that I get the boot logo on the display, then a message of loading stuff... and then it goed to standby (light flickers)...
I can still hear the disk spinning... but it does not power on (besides the light)... not from the buttons not from the remote.
Emplode on XP can not find the player (on USB and Serial). But before the crash/freeze that was no problem...
I can upgrade also hyperT (but there i get no prompt)...
I have done the things that you sugested to the pins on the mb.
Vince
I use the Kenwood remote.
#170330 - 14/07/2003 02:53 Re: Mark1 dead? [Re: schofiel]
vbezemer
with MTTTY I CAN get in...
I will try all the stuff mentioned and update you guys soon!
Vince
#170331 - 14/07/2003 03:11 Re: Mark1 dead? CONFIG??? [Re: tfabris]
vbezemer
hmmmm....
Since the player is not recognized bij emplode... I can't do anything on the config file, right?
Enclosed the bootlog after ctrl+c
Vince
168831-bootlog2.txt (243 downloads)
#170332 - 14/07/2003 03:28 Re: Mark1 dead? CONFIG??? [Re: vbezemer]
Are you sure you didn't set the handshaking on hyperterminal?
#170333 - 14/07/2003 03:41 Re: Mark1 dead? CONFIG FILE [Re: andym]
vbezemer
I'm in
168833-config_ini.txt (209 downloads)
#170334 - 14/07/2003 04:07 Re: Mark1 dead? CONFIG FILE [Re: vbezemer]
[shuff
deduplicate=1
I am not sure that the missing square bracket is good, but I doubt that this would hang up the player. You obviously don't have the "massive CONFIG.INI" problem caused by the bug in 2B11, so it's not that either.
Hmmm....
#170335 - 14/07/2003 09:36 Re: Mark1 dead? CONFIG FILE [Re: schofiel]
vbezemer
how can I add the bracjet (I'm not a linux man).
Vince
#170336 - 14/07/2003 14:48 Re: Mark1 dead? CONFIG FILE [Re: vbezemer]
Hmm. I could see how a missing close-bracket might theoretically screw up the ini-file-reading routine if it wasn't bullet-proofed against that sort of thing. Don't bother with adding the close bracket, just delete the ini file completely and see if that solves the problem.
#170337 - 14/07/2003 15:08 Re: Mark1 dead? CONFIG FILE [Re: vbezemer]
oliver
Just in case, here is the FAQ with the commands you need to type for deleting the config.ini file.
#170338 - 14/07/2003 22:45 Re: Mark1 dead? CONFIG FILE [Re: tfabris]
vbezemer
Unfortunately this doesn't help either...
#170339 - 15/07/2003 00:34 UPDATE [Re: vbezemer]
vbezemer
Hello All,
I still have the problem
This morning I have rebuild the disk, put the developer v2 software back and added the tunes.
Back in the car: it worked great... after playing in the car and haning the player on my XP pc... DEAD.
It boots untill the "Loading Visuals" message... and then nothing on the display and just the burning light in the bottom right corner.
I can re-boot what ever I want or press whatever button I want... the player does not respond (the disk is running!!!)
Hyperterminal has access to the player and lets me mount the drive.
The player does not pop up in the select player dialogue screen of emplode (not on USB not on serial)...
The only thing that I can come up with is that the player gets corrupted in my car... 'cause after playing in the car, undocking it from the car and haning it on my pc... the problem first shows herself...
Does anyone have the correct wiring? (it think I have it right, because it plays in the car....)
I have posted the config.ini and the bootlog earlier... I have shortened the pins on the MB. I have checked all connectors... The player does play, but only one session in the car (so this is not a memory problem, right). Basically I have done all I could do (stuff in the FAQ and your tips in these posts).
HELP!
Vince
#170340 - 15/07/2003 03:35 Re: UPDATE [Re: vbezemer]
vbezemer
I have tested it again (re-build the disk and added the developer v2 and some tunes)...
Went to my car, docked it, turned on the egnition, player starten and played pefect. Shut down the juice, started again... PLAYER DEAD!!!!
So undocking is not the problem... the power (or something else) in the car is... Can somebody point out what I did wrong?
Vince
#170341 - 15/07/2003 04:24 Re: UPDATE [Re: vbezemer]
At this point, I really do not know what to add. It might be a good idea to contact support and have them look at the unit. I cannot (personally) think of anything to add at this point.
#170342 - 15/07/2003 15:25 Re: UPDATE [Re: pgrzelak]
He's coming round for coffee and a diagnostic on Thursday ....
#170343 - 15/07/2003 15:38 Re: UPDATE [Re: schofiel]
Excellent!!!
#170344 - 17/07/2003 05:31 Fixed!!! [Re: vbezemer]
Problem solved. VInce has ben here and it turned out that the audio daughterboard was loose. It's been glued back in, and he's gone away with a handful of stickers and a big smile.
Yet another satisified customer!!!
#170345 - 17/07/2003 07:17 Re: Fixed!!! [Re: schofiel]
A loose audio daughterboard? That is a new one. Should that go in the FAQ, or is it too obscure?
#170346 - 17/07/2003 10:09 Re: Fixed!!! [Re: pgrzelak]
No, I think it's a candidate - it's the second Mk 1 I've seen with "weird" behaviour, but had a seriously loose daughterboard. In this case, I did the same as the advice I gave for securing it as before - remove the original silicone bead from the connector header for the board, then make sure it's correctly positioned, and finally coat the connector area and board with lots of semi-rigid hot glue to make sure it doesn't move. I also put big blobs at the opposite side to fix the board to two capacitors sticking up, to make sure it was supported on more than just one side.
It seems to have fixed it: we spend about half an hour turning it on and off, rebooting, all the rest and it came up perfectly every time.
#170347 - 17/07/2003 12:09 Re: Fixed!!! [Re: schofiel]
I added a note to the other Mk1-power-loss FAQ entry about the loose daughterboard.
Page 2 of 2 < 1 2
