#155665 - 16/04/2003 18:32 trying to delete the database
elvis
Loc: Arizona USA
Ok, I'm trying to delete the database and am having 0 luck. I put the dev image on the player, but I can't even get to a working shell. I've tried holding down q, pressing rapidly, etc but no dice. The machine goes straight into player mode and won't even listen to keystrokes to control the player.
I'd like to know how I might be able to increase the timeout for pressing q or any other way I can get to a shell prompt.
after that I was going to do
dest-empeg:/# cd /empeg/var
dest-empeg:/empeg/var# rwm
dest-empeg:/empeg/var# rm tags database playlists
and reboot the player
HEALLLP!
Elvis
#155666 - 16/04/2003 18:42 Re: trying to delete the database [Re: elvis]
oliver
i think i had this problem once. and maybe it was ctrl+c that helped me out. but i can't remember. i'll try searching the bbs a bit
#155667 - 16/04/2003 18:52 Re: trying to delete the database [Re: elvis]
This indicates trouble with the serial cable or the port settings.
#155668 - 16/04/2003 18:56 Re: trying to delete the database [Re: tfabris]
elvis
Loc: Arizona USA
But I followed the FAQ RELIGIOUSLY!!!
I was able to interact with the player just fine using the standard consumer image and the same settings in hyperterm, so I doubt it's the cable.
How DOES one increase that timeout?
P.S. A thought for the bss faq when you have spare time... you could put an example next to the UBBCode flags.
Elvis
#155669 - 16/04/2003 19:01 Re: trying to delete the database [Re: elvis]
mcomb
Loc: San Carlos, CA
Could be this. But, as I seem to be the only one with that problem I would say it is more likely you have flow control set incorrectly in your terminal software.
The timeout isn't the issue (it is only there for the software that updates the player), you are supposed to be able to hit 'q' at any time. Did you try control-c as well?
-Mike
#155670 - 16/04/2003 19:23 Re: trying to delete the database [Re: mcomb]
elvis
Loc: Arizona USA
Ctrl-C doesn't work either. You know what's funny; the developer image seems to be mounting the drives read only.... isn't that abnormal when plugged into ac power?
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg52 (rob@aphex) (gcc version 2.95.3 20010315
(release)) #11 Tue Apr 1 18:49:59 BST 2003
empeg-car player (hardware revision 9, serial number 40103222)
Command line: mem=16m
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 636f6972 'rioc'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004100).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: FUJITSU MHL2300AT, ATA DISK drive
hdb: FUJITSU MHL2300AT, ATA DISK drive
hda: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
hdb: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:0c:9
6
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
Starting player
Vcb: 0x4086d000
Elvis
#155671 - 16/04/2003 20:17 Re: trying to delete the database [Re: elvis]
No. The drives are always mounted read-only except during a sync or when you manually change it.
Double-check your serial settings, especially flow control. Then wait until the player is no longer producing any text output and press `q', then <Return>. If that produces nothing, press `q' and <Return> again.
#155672 - 17/04/2003 03:48 Re: trying to delete the database [Re: wfaulk]
The only issues I have had along similar lines have all been down to problems with the serial interface on my PC (or more accurately issues with bl**dy Microsoft's handling of COM ports)
It is worth retrying 'q - Enter' at various points after the player is up and running, but I would try and change the com port you are using. I have had mine hijacked by something else a couple of times and it stuffs hyperterm.
