#15063 - 23/08/2000 07:37 Lost USB connectivity
hamzy
Loc: TX, USA
Hello all,
A week ago, I installed the USB support on a Win 98 box and downloaded some songs. Then, I went on vacation and when I came back, I cannot get emplode to recognize the empeg.
It does work through the serial port.
This is on 0.96 RC1 and a developer's kernel.
Now, at home, I use Ethernet and at work I use (or at least want to) USB. Will this confuse things? I don't know what else might be wrong...
Thanks,
Mark
#15064 - 23/08/2000 08:32 Re: Lost USB connectivity [Re: hamzy]
Using different interfaces (serial, USB, ethernet) to the empeg won't cause a problem (as long as you don't try to use them at the same time).
While on the subject, you ought to upgrade to v1. It doesn't have any USB fixes in it, per se, but there's a heap of other good stuff in it.
emplode can be a bit finicky. Did you hit refresh a couple of times? Does the empeg-car appear in Device Manager?
Failing that, reinstalling the empeg USB driver can help.
#15065 - 23/08/2000 11:24 Re: Lost USB connectivity [Re: Roger]
hamzy
Loc: TX, USA
I did.
> couple of times?
Yes.
I take it you mean under Universal serial bus controller?
If so, then no. There is only an Intel 82371AB/EB PCI to USB Universal Host controller and a USB Root Hub under it.
How? I ran the emplode setup program.
I ran the tests at boot time and USB passed:
0500 usb detect
0510 usb rev 1012
05f0 usb ok
00f0 tests complete
It hung after testing everything. Is that normal?
In the normal boot log, it says:
Mark
#15066 - 24/08/2000 03:47 Re: Lost USB connectivity [Re: hamzy]
Ah, then this is a problem with the USB driver on the unit, or on the PC. At this point, I'll have to bow to Mike's superiour knowledge.
Yes. That's the simplest way to reinstall the USB driver. You may want to try uninstalling it first, then reinstalling it.
#15067 - 24/08/2000 07:34 Re: Lost USB connectivity [Re: Roger]
hamzy
Loc: TX, USA
Whew, it works now.
Sorry to raise the alarm...
#15068 - 24/08/2000 08:05 Re: Lost USB connectivity [Re: hamzy]
Whew, it works now.
What exactly got it working? A de-install and re-install of Emplode?
Don't be sorry- this is important information. For instance, if simply re-installing Emplode didn't fix the problem, then perhaps Empeg should look at modifying the InstallShield script so that the USB driver is force-replaced on every installation?
#15069 - 24/08/2000 11:39 Re: Lost USB connectivity [Re: tfabris]
hamzy
Loc: TX, USA
Sighhhhhhhhhhh,
This falls under embarrasingly stupid category. Since there was not a lot of room to maneuver while plugging in the USB cable, I assumed that what I was plugging it into was the USB connection (which it wasnt -- it was the ethernet connection). When I unplugged everything,
turned it around and plugged the USB cable in first, it worked.
I guess the stupid user syndrome can even affect me...
I'd crawl back under a rock, but I'm trying to develop programs for it and have got other questions to ask ^_^'
#15070 - 24/08/2000 13:22 Re: Lost USB connectivity [Re: hamzy]
I'd crawl back under a rock, but I'm trying to develop programs for it and have got other questions to ask.
So, which rock are you trying to develop programs for?
__________________
The Pronoun Police
