My problems started over the winter when I would start to see once in a while the contact support hard disk problem and it got more and more common. Normally a try tries to start and it would eventually come up. After reading on here I found out abouut the problem with hard drive cables and so took the suggestion to move the drive to the 2nd IDE cable position which I did. The unit fired right up (it has come up on the 1st try sometimes since the problem was intermittent so that doesn't mean I fixed it). I went to load some songs into it and it ran fine for a while and then emplode locked up on me.
So wanting to find out if I had a drive problem or not, I decided to put the builder image on and let it format and stress test the drive. I know that is an exteme action it just seemed to best way to find out for sure if I had a drive problem or not.
Now the unit will not even boot at all anymore. I have tried loading numerous version of the kernal including both builder versions and I am not sure if any of them are taking. I did follow the directions - unplug unit, double click .upgrade file, plug in power when prompted - and all upgrades claim successful completion with no errors. The upgrade is being done out of the sled directly into AC power with the originial power supply.
I did run a control-T test and all tested fine.
Here is the output after putting on the latest car2 builder image.
Any ideas?
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg49 (mac@aphex.internal.empeg.com) (gcc versi
on 2.95.3 20010315 (release)) #130 Mon Oct 22 18:52:07 BST 2001
empeg-car player (hardware revision 9, serial number 10101754)
Command line: mem=16m
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004a00).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: TOSHIBA MK3017GAP, ATA DISK drive
hda: TOSHIBA MK3017GAP, 28615MB w/0kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:06:d
a
Partition check:
empeg-pump v0.03 (19980601)
Freeing unused kernel memory: 4k initinit(1): memory violation at pc=0x40012714,
lr=0x40006e24 (bad address=0x4a000000, code 2)
pc : [<40012714>] lr : [<40006e24>]
sp : bffffae0 ip : 40021258 fp : bffffb40
r10: 4002110c r9 : 40020e48 r8 : 00000028
r7 : 40021ae4 r6 : 00000000 r5 : 40021ad0 r4 : 40021adc
r3 : 40021af8 r2 : 40017c58 r1 : 4a000000 r0 : 4a000002
Flags: nzCv IRQs on FIQs on Mode USER_32 Segment user
Control: C0FA517D Table: C0FA517D DAC: 00000015
Function entered at [<40006cac>] from [<40004768>]
r10 = 4002110C r9 = 00000000 r8 = 00000190 r7 = 020000F4
r6 = 020000FC r5 = 40021878 r4 = 40021830
Function entered at [<40003f2c>] from [<4000f434>]
r10 = 4002110C r9 = 00000000 r8 = 00000000 r7 = 40003F2C
r6 = 4002185C r5 = 00000006 r4 = 40021860
Function entered at [<4000f104>] from [<40003dd8>]
r10 = 4002110C r9 = BFFFFEF4 r8 = FFFF5D8C r7 = 00000002
r6 = 40000000 r5 = 40000000 r4 = 400215A0
Function entered at [<40003700>] from [<40003678>]
r10 = 00000000 r9 = 00000000 r8 = 00000000 r7 = 00000000
r6 = 00000000 r5 = 00000000 r4 = 00000000
init(1): memory violation at pc=0x40012714, lr=0x40006e24 (bad address=0x4a00000
0, code 2)
0, code 2)
0, code 2)
