Can anyone see a reason why a fsck would take substantially longer on one drive (Hitachi Travelstar 40GB) than another (Fujitsu 30GB)?
You can see in my boot log below where I timed a fsck on each drive. One took 12 minutes the other a little over two. The fast drive is about 25/30GB full and the the slow one is only about 15/40GB full.
The slow drive is the system drive if that could make any difference.
Any ideas? I just noticed when syncing on the checking media stage (I guess the fsck was due), that it was taking quite a long time so I did it myself manually.
There are no irq timeout etc errors that are quite often a sign of a dying drive. Am I paranoid?
Just found it a little strange that my brand new IBM would take that much longer to fsck than the original Fujitsu.
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v320 (root@ibbm) (gcc version 2.95.3 20010315 (release)) #2 Wed Feb 19 21:53:19 EST 2003
empeg-car player (hardware revision 9, serial number 40104192)
Command line: mem=16m
Memory: 14996k/16M available (996k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
IrCOMM protocol (Dag Brattli)
Starting kswapd v 1.5
Signature is 206f6972 'rio '
Found custom animation at offset 0x9bbb0
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005400).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IC25N040ATCS04-0, ATA DISK drive
hdb: FUJITSU MHL2300AT, ATA DISK drive
hda: IC25N040ATCS04-0, 38154MB w/1768kB Cache, CHS=4864/255/63
hdb: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:10:60
Partition check:
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...ԕjչѕɽсɁѕɕ)5change_root: old root has d_count=1
Mounting proc
Starting player
khttpd: listening on port 80
kftpd: listening on port 21
Vcb: 0x4086d000
q
Restored terminal settings
Player exited normally: 0
Starting bash.
empeg:/empeg/bin# ro
empeg:/empeg/bin# umount /dev/hda4
empeg:/empeg/bin# umount /dev/hdc4
empeg:/empeg/bin# swapon /swapfile
Adding Swap: 16028k swap-space (priority -1)
empeg:/empeg/bin# fsck -fay /
Parallelizing fsck version 1.19 (13-Jul-2000)
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
/dev/hda5: 1517/4096 files (0.5% non-contiguous), 9446/16384 blocks
empeg:/empeg/bin# time fsck -fayVC /dev/hdc4
[/sbin/fsck.ext2 -- /dev/hdc4] fsck.ext2 -fay -C0 /dev/hdc4
/dev/hdc4: 10303/228352 files (9.8% non-contiguous), 6157817/7304850 blocks
real 2m23.148s
user 0m16.630s
sys 0m6.790s
real 2m23.233s
user 0m16.190s
sys 0m6.890s
empeg:/empeg/bin# time fsck -fayVC /dev/hda4
[/sbin/fsck.ext2 -- /drive0] fsck.ext2 -fay -C0 /dev/hda4
/dev/hda4: 4425/304448 files (28.9% non-contiguous), 11223749/38965657 blocks
real 12m25.375s
user 0m37.270s
sys 0m23.790s
empeg:/empeg/bin#
