#129442 - 06/12/2002 15:26 IP Detective Work, can someone help?
darwin
I'm just trying to find out who own's this ip address: 67.250.135.102 Like who is the isp or something. Where can I search for this? Is there a website or something? To make it short, i'm getting harrassed, that's why I need this info.
#129443 - 06/12/2002 15:34 Re: IP Detective Work, can someone help? [Re: darwin]
oliver
Whois on ARIN should give you what you need. or Visual Route is a very nice trace route program, with all whoises built it!
#129444 - 06/12/2002 15:37 Re: IP Detective Work, can someone help? [Re: oliver]
oliver
ARIN will give you their ISP, do a whois on their ISP's domain, call the tech contact number, and let them know what’s going on with their user. They will probably also tell you to email abuse@hisISP.ext.
#129445 - 06/12/2002 15:39 Re: IP Detective Work, can someone help? [Re: darwin]
schofiel
This is what the DNS lookup comes back with:
1Cust102.tnt2.coupeville.wa.da.uu.net
Looks like it's probably a dialup.
#129446 - 06/12/2002 16:05 Re: IP Detective Work, can someone help? [Re: schofiel]
To elaborate on what Rob S. just said...
If it's a dial-up number, that means it's not a fixed IP address so it could be any one of that ISP's customers. Your only recourse is to contact the ISP with an exact time/date of the harassment and convince them that it's worth their time to look up the user name in their logs as referenced against that address (assuming they even log that data).
#129447 - 06/12/2002 16:25 Re: IP Detective Work, can someone help? [Re: darwin]
darwin
Thanks for your replies, I'll try to figure it all out with the info given. Hopefully, I should be able to find out at least what city they are from.
#129448 - 06/12/2002 16:38 Re: IP Detective Work, can someone help? [Re: darwin]
Well from that address
It looks like they dialed into a modem pool in Coupeville, WA.
#129449 - 06/12/2002 16:57 Re: IP Detective Work, can someone help? [Re: tonyc]
jimhogan
Loc: Seattle, WA, U.S.A.
Looks like. From the nomenclature it looks like an Ascend MAX TNT, which also does DSL, but if you experience repeats with a different address, then that suggests dial-up.
One other thing to keep in mind is that even though it is a UUNet port, it might be a resold port that is under another ISP's umbrella for services, authentication, etc.. So if you contacted UUNet and they referred you somewhere else, I wouldn't automatically take offense.
Jim
#129450 - 06/12/2002 19:26 Re: IP Detective Work, can someone help? [Re: darwin]
ashmoore
Loc: TX
I have found that for this type of stuff, there really is no substitute for
http://www.samspade.org
========================== the chewtoy for the dog of Life
