I just got the replacement front panel for my Mk2 yesterday. I would just like to thank Rob and the guys at empeg. The new panel and rotary knob fit perfectly and no longer rub together every revolution, the new panel is considerably brighter than the original, although I must admit I did a double-take when I first saw it - the blue is now (as mentioned in one of Rob's posts) closer to cyan, and I spent a couple of minutes wondering if I'd got a green panel by mistake
The only thing worrying me slightly is that I had to loosen two of the hex bolts a bit more than I would have liked to prevent a couple of the buttons from sticking (this was mentioned in the instructions provided, which were so clear and detailed, the fascia practically replaced itself
) I am guessing that when I removed the bolts, they seemed tighter due to the 'glue' used to lock them in place (what is that stuff called? It might be an idea to get some) My worry is that when I get it in the car, the vibration may shake the bolts loose over time - one of the bolts at the back of the Mk1 on either side of the DB9 connector has come loose at some point, and I imagine it has fallen down behind my dashboard somewhere. Are these bolts held in any tighter on the Mk2?
Anyway, once again, thanks for the great service Rob.
Geoff
Got one of the first Mark 2 empegs...
