#12091 - 27/07/2000 05:27 Emplode extras
muzza
It would be nice for emplode to back out to the first init dialog "chooser" from within the program without re-starting it.
Murray 06000047
____________________
#12092 - 27/07/2000 08:18 Re: Emplode extras [Re: muzza]
You can do this already. Just close the child window (use the lower of the two X buttons), and then select File|Open.
#12093 - 27/07/2000 08:34 Re: Emplode extras [Re: Roger]
Interesting. So what you're saying is that each child window is an "opened" empeg?
Does this mean that eventually we'll be able to open two empegs at the same time? Can you say drag and drop? That would be sweet.
Nah, you guys'll prolly disable that on purpose. Oh well.
#12094 - 27/07/2000 09:53 Re: Emplode extras [Re: tfabris]
You can open two windows on the same empeg (Window|New), and then drag and drop between them to give you more control over arranging your playlists.
While we could quite easily support opening two players (although there's a bundle of changes that would need to be made to emplode under the hood), it's unlikely that, even if we let you look at both, we'd let you drag and drop between them.
#12095 - 27/07/2000 10:12 Re: Emplode extras [Re: Roger]
Yeah, I knew you'd say that.
#12096 - 27/07/2000 16:18 Re: Emplode extras [Re: tfabris]
muzza
O that function.
woops
i'll just go and stand in a corner and bang my head on the wall for a while
Murray 06000047
#12097 - 27/07/2000 16:21 Re: Emplode extras [Re: Roger]
muzza
you could just be a high class napster
Murray 06000047
#12098 - 27/07/2000 16:35 Re: Emplode extras [Re: muzza]
muzza
OK, how abouot a sound that plays when a sync has finished?
Murray 06000047
#12099 - 28/07/2000 05:04 Re: Emplode extras [Re: muzza]
There should be one available already. Just go to Control Panel|Sounds, and assign one.
#12100 - 28/07/2000 10:04 Re: Emplode extras [Re: Roger]
Whaddya know, there they are. I'll be damned.
The only reason I never heard them on my system is because they default to Window's wave files like tada.wav and chord.wav, irritating sounds which I'd long since deleted off of my hard disk.
Time to go assign them to something more irritating, like Monty Python or MST sounds...
#12101 - 28/07/2000 10:49 Re: Emplode extras [Re: tfabris]
I suggest:
"Ah! I see you have the machine that goes *ping*!"
(Monty Python's Meaning of Life)
#12102 - 28/07/2000 11:13 Re: Emplode extras [Re: altman]
Heh, my "incoming mail message" sound is the bit from "Grail" where the boy imprisoned in Swamp Castle shoots an arrow out of the window with a message attached. You hear the arrow streaking through the air, piercing the chest of Lancelot's paige, and the paige exclaiming, "Message for you, sir!" as he falls to the ground...
#12103 - 29/07/2000 04:11 Re: Emplode extras [Re: tfabris]
muzza
DAMMIT
You see haw good these empeg folks are!!!?
I was expecting something in the program prefs (maybe that would help too!).
Murray 06000047
#12104 - 04/08/2000 15:04 Re: Emplode extras [Re: muzza]
muzza
OK
What about an undo function eh?
i seem to remember asking for it here
Murray 06000047
