#118259 - 28/09/2002 08:41 start failed : 35d5c83
empegteg67
Loc: canada
i keep get this message everytime i put the consumer software "start failed : 35d5c83" can you please tell me what's wrong and what can i do for i don't have this message no more
g2 power
#118260 - 28/09/2002 09:20 Re: start failed : 35d5c83 [Re: empegteg67]
empegteg67
Loc: canada
i see that the player work but the message " start failed:35d5c83" stay on front of the screen and only gone when the player is synchronise i try to install the player many time but he showing up this message any help will be appreciate
g2 power
#118261 - 28/09/2002 09:54 Re: start failed : 35d5c83 [Re: empegteg67]
mtempsch
Have you tried downloading the software again? With a utility like GetRight?
Which version of the software?
The md5sum for the 2.0b13 consumer MkII .upgrade file as I have it here ends in ...fdcc1853b9 .
(Note: I don't use the consumer version, but downloaded it the same time and by the same method as my (functional) developer version (md5sum ends in ....dec1fc773e) )
Any error messages during the installation of the software?
#118262 - 28/09/2002 10:00 Re: start failed : 35d5c83 [Re: empegteg67]
Make sure that you are using the correct software for your player.
For instance, if you own a Mark1 player, the file must say "Car1" in the file name. If you own a Mark2 or a Rio Car player, it must say "Car2" in the file name.
Also, as was already suggested, grab the file again with GetRight.
#118263 - 28/09/2002 14:14 Re: start failed : 35d5c83 [Re: tfabris]
empegteg67
Loc: canada
i do all the step that you told me, i download the builder and the sonsumer software and my empeg is a mk2, so i take the upgrade that have car2, but i still have the same message "start failed:35d5c83" what can i do else
g2 power
#118264 - 28/09/2002 19:58 Re: start failed : 35d5c83 [Re: empegteg67]
what can i do else
You can contact support. Please click here.
#118265 - 29/09/2002 13:35 Re: start failed : 35d5c83 [Re: tfabris]
empegteg67
Loc: canada
thanx i finally fix it it work with the V1.0. I don't know why but the 1.3 don'T work on my empeg
g2 power
#118266 - 29/09/2002 14:23 Re: start failed : 35d5c83 [Re: empegteg67]
Laura
Loc: Greenhills, Ohio
Are you using a different version of Emplode than you are the player software? They both have to be the same. Just a guess.
Laura
MKI #017/90
whatever
#118267 - 29/09/2002 14:58 Re: start failed : 35d5c83 [Re: Laura]
The version of emplode shouldn't have anything to do with the player failing to start all by itself.
It is important that he be able to upgrade to a newer version, so that he can take advantage of all of the new features. I still recommend that he contact support on this subject.
#118268 - 29/09/2002 15:00 Re: start failed : 35d5c83 [Re: empegteg67]
Incidentally, empegteg67, in case you haven't already done so, please read through this FAQ entry, and give the rest of the FAQ a quick skim.
#118269 - 30/09/2002 05:33 Re: start failed : 35d5c83 [Re: empegteg67]
Please email David - dmoss@sonicblue.com - I'm sure he can diagnose the problem.
