#109035 - 02/08/2002 13:00 Funny mark on case
g_attrill
Loc: Hants, UK
Hi,
I have this round brown mark on my player, and one on the other side at the same place:
It doesn't look as if it's heat from inside the player, it doesn't rub off and I don't *think* there are any screws in the sled at those places.
Any ideas?
Gareth
#109036 - 02/08/2002 13:01 Re: Funny mark on case [Re: g_attrill]
leftyfb
Loc: Lowell, MA
It's on mine also. Think it might just a result of manufacturing.
Mk2a 30GB Blue. Serial 030102999
#109037 - 02/08/2002 13:06 Re: Funny mark on case [Re: g_attrill]
I always persumed it was some sort of burn/scorch mark from a spot weld or the likes.
Anyone know whats on the inside at that point?
#109038 - 02/08/2002 13:15 Re: Funny mark on case [Re: Phoenix42]
fede
Loc: Texas
I believe it is just that. A spot weld. The tip on the spot welder is usually not spotlessly clean. As a result, there is a certain amount of discoloration when the impurities on the spot welder tip burn in contact with the metal to be welded.
BTW: Mine has the same mark, only darker.
'a stock car stereo is a beautiful thing to waste' MKIIa 60gb MKIIa 20gb
#109039 - 02/08/2002 13:35 Re: Funny mark on case [Re: fede]
g_attrill
Loc: Hants, UK
Thanks for the replies! I guess I didn't examine the case closely enough when I got it, I think I was busy drooling over the lovely logos on the back...
Also, after use it had that "hot power supply" smell which concerned me a little...
Had it three months or so and love it to bits...
Gareth
#109040 - 02/08/2002 14:09 Re: Funny mark on case [Re: g_attrill]
justinlarsen
Loc: Petaluma, CA
the old sand paper trick will result in your case looking shinny new, use the finest grade you can find or u will get a brushed aluminum look
---- Justin Larsen
#109041 - 02/08/2002 14:44 Re: Funny mark on case [Re: justinlarsen]
maczrool
Loc: Louisiana, USA
As opposed to the brushed stainless steel look it has now?
Stu
#109042 - 02/08/2002 19:50 Re: Funny mark on case [Re: justinlarsen]
genixia
I wouldn't do this without taking everything out of the case first, and rinsing it out well after..
