#107611 - 27/07/2002 07:41 Vauxhall Astra install
CrackersMcCheese
Hi Guys
Quick question... does the Astra have a standard DIN? Or do I need to mess about with knives and plastic? If no DIN, is there a dealer kit available? Its a '99 Sxi (or might not be if I can't fit my empeg!). Any other problems I should be prepared for?
Thanks for any info
Phil
#107612 - 27/07/2002 08:36 Re: Vauxhall Astra install [Re: CrackersMcCheese]
thinfourth2
99 is that a blobby astra or the new anglely astra if it is the blobby astra then it is a piece of piss but a crap car.
If it is a Anglely one than i don't know
Talk to someone at a stereo shop just don't mention it is an empeg as that will only confuse them.
#107613 - 27/07/2002 08:44 Re: Vauxhall Astra install [Re: thinfourth2]
CrackersMcCheese
99 is the same shape as the current models AFAIK. Started in 98 till present.
#107614 - 27/07/2002 09:01 Re: Vauxhall Astra install [Re: CrackersMcCheese]
thinfourth2
Wasn't too sure when they started as my parents had a blobby astra god it was a horrible car.
I would think it should be pretty easy to get an empeg into it as i have seen quite a few cars in Max Pants etc with a after market head unit fitted.
Hell go down to halfords and see if you can buy an adapter?
#107615 - 28/07/2002 04:24 Re: Vauxhall Astra install [Re: CrackersMcCheese]
Gareth
Loc: Peterborough, UK
It's a standard DIN. The Astra (new shape 98 onwards) actually has 2 standard DINs but they are not next to each other. Depending on your cars options, the CD holder/'small shelf with rubber mat' next to the heating controls is actually another DIN if you take it out.
I've had an Empeg installed in 2 Astras, a 99 2.0 SRi and curently an 02 Coupe Turbo in the 2nd DIN with the factory fit unit as Aux-in to the empeg via line level converters.
