#106973 - 23/07/2002 17:52 ethernet problems
Teo
Hey, I've got a problem (and yes, i've already tried the FAQ)...
I've got a mk2a that i was able to see via ethernet just fine until one day...
Now when I've got a network cable plugged into the player and start it up it shows a ton of collisions for a few seconds and cannot be accesses by emplode (either by broadcast or specific IP). I can't ping it or anything! This really sucks!
If anyone can help, i'd really appreciate it. I'm running xp and have the computer and deck running into a hub.
Thanks,
-Teo
#106974 - 23/07/2002 17:57 Re: ethernet problems [Re: Teo]
Have a look at what the network settings are for the player by going to the About menu option on the player.
You sure there is nothing at that IP address on your network?
- Trevor
#106975 - 24/07/2002 19:06 Re: ethernet problems [Re: tman]
Teo
naw, i checked there first... tried dhcp and manual config and made sure both matched up (except for, of course, the IP address) perfectly... still no luck... the collisions really have me curious tho...
-Teo
ps: i appreciate anyone even thinking about this little pain in the butt problem of mine
#106976 - 24/07/2002 20:21 Re: ethernet problems [Re: Teo]
Magnus
Loc: Tampa, Florida
I'll just toss this out there:
You didn't happen to use a crossover cable or plug it into an uplink port on the hub instead of a normal port right? Just one more thing to check.
-Dave
RioCar 40103779
'67 Mustang
#106977 - 25/07/2002 03:59 Re: ethernet problems [Re: Magnus]
Teo
I wish it was that easy
unfortunately, it's a regular patch cable...
Here's some other info real quick (in case it helps)
-Windows XP Pro
-3com nic card w/ a netgear hub..
-currently the only 2 devices on the ethernet network
-computer also has a dsl modem
-owner is willing to try ANYTHING to get this to work again.
Thanks again,
-Teo
#106978 - 25/07/2002 04:21 Re: ethernet problems [Re: Teo]
Is it worth trying to unplug everything from the hub except the rio. Does it show any collisions then? If it does, could it be a dodgy hub? If it only happens when the computer is plugged in, what IP settings are you using on the computers network card? Are they the usual range (10.x.x.x or 192.168.x.x)? The DSL modem, is it an internal modem or is it Ethernet or USB? Could it be a conflict between the the DSL modem and the network card?
#106979 - 25/07/2002 06:52 Re: ethernet problems [Re: andym]
Teo
I trieid only having the rio on the hub and it's still causing collisions.. on the computer, i tried having it automatically get an ip and manually get one.. wheni specified an ip, i used 169.254.150.229 (.230 for the rio) whtn a subnet mask of 255.255.255.0 and gateway of 169.254.130.1
The DSL modem that's in the computer as well is internal and uses the windows dialer... This computer was the same one that I used previously to talk to the rio over ethernet so i'm not ruling out the possibility of incompatibility BUT in my mind it all goes back to the collisions...
hmmm.....
Thanks,
-Teo
#106980 - 25/07/2002 08:49 Re: ethernet problems [Re: Teo]
jets
Loc: Toronto, Canada
i dont know if it makes a difference but on mine the subnet mask is 255.255.0.0
It seemed like a good idea at the time.
#106981 - 25/07/2002 10:38 Re: ethernet problems [Re: Teo]
Assuming you're intending them to be on the same LAN, your netmask is wrong in your example. The easiest thing to do would be either to change it to 255.255.0.0 or change the IP addresses of the units so that the third number is the same between them, in addition to the first and second ones.
#106982 - 26/07/2002 06:16 Re: ethernet problems [Re: wfaulk]
Teo
whoops, typo.. the netmask i was trying was 255.255.0.0 and the ip's are good..
-Teo
