#106683 - 23/07/2002 04:29 Broke my Empeg - Please please please help!
retmana
I have an Mk2 empeg with two drives onboard, and have been using an old version of Hijack (can't remember the version number) with the v2.00 beta 11 consumer kernel happily for some time.
Having seen the latest round of cool add on apps available, I thought I'd have a go at installing pacman, telnet daemon etc. etc. So, the first step was to upgrade to a developer version of the kernel so that I get shell support. So, I used the Emplode upgrade wizard to install 2.00 betal 11 developer image.
This worked fine too, but I lost Hijack in the process. So today I thought I'd upload the latest build of Hijack (v281) using the Logo Editor. The upload seemed to go fine, but when I reboot the empeg it just seems to hang with the power light flashing.
I hooked it up to Hyperterminal and I get the following boot log:
e000 v1.04
Copying kernel...
Calling linux kernel...
And then it just hangs! Waaahh! I tried flashing the hijack file over again and it still hangs. Tried downloading the hijack file again and reflashing but it still hangs. I'm hoping that I can reinstall the standard 2.00 betal 11 kernel and it will all be mended, but I'd like to get Hijack back too.
So, any ideas on how to fix this? Is this a known problem with latest version of Hijack? Anybody else using v281 without problems?
Cheers Dudes,
Andrew.
#106684 - 23/07/2002 04:33 Re: Broke my Empeg - Please please please help! [Re: retmana]
retmana
Hmmmm.... just rolled back to an old version of Hijack I had lying around (v266) and it cures the problem. Empeg is back again....
More investigation required then...
#106685 - 23/07/2002 04:33 Re: Broke my Empeg - Please please please help! [Re: retmana]
Could it be a dodgy download of the hijack upgrade? I use getright to download all my kernal, bios bits and bobs. If you've got a known good copy of the original 2b11 kernel then try and flash that in, check the unit and then get hijack via getright.
Hope everything works out, I very much doubt you've permanently hosed your player
#106686 - 23/07/2002 04:34 Re: Broke my Empeg - Please please please help! [Re: andym]
Damn, not quick enough! Sounds like a dodgy download of hijack
Edited by marria01 (23/07/2002 04:34)
#106687 - 23/07/2002 04:37 Re: Broke my Empeg - Please please please help! [Re: andym]
retmana
Weird.
Just downloaded Hijack again - admittedly not using getright (I just use IE6) and flashed over v281, I get the exact same hanging problem.
Looking at the file I've downloaded, v266 is 506K, while v281 is 505K. Should they be the same size?
#106688 - 23/07/2002 05:07 Re: Broke my Empeg - Please please please help! [Re: retmana]
Greetings!
It definately sounds like a bad download. On the hijack page, it lists the file size for 281 as 518056 bytes...
#106689 - 23/07/2002 05:41 Re: Broke my Empeg - Please please please help! [Re: pgrzelak]
retmana
Fair enough. I'll give this getright lark a try.
Just for the record, is anybody else using Hijack v281 successfully? I just want to make sure that the file on the Hijack site isn't corrupted.
Cheers.
#106690 - 23/07/2002 07:55 Re: Broke my Empeg - Please please please help! [Re: retmana]
tms13
Loc: Lochcarron and Edinburgh
The server advertises the file as text/plain, which could cause corruption during transfer. I've been meaning for ages to bug Mark about that...
Toby Speight
030103016 (80GB Mk2a, blue)
030102806 (0GB Mk2a, blue)
#106691 - 23/07/2002 09:29 Re: Broke my Empeg - Please please please help! [Re: tms13]
mtempsch
v281 works for me...
Filesize: 518056 bytes
md5sum: \34be5ef3479b03937a2198174299a67d
