#106662 - 22/07/2002 17:49 Bad Pump Response, looking for new ideas
kazama
Loc: Boston, MA
SO I was happily listening to music in my office today when I remembered I needed to delete some files off the Empeg. I selected them in Emplode and tried to sync the player. Half way through the sync, the software froze on both emplode and the player. I unplugged the player and plugged it back in. It booted up but would not play any files I selected. I powered down then powered up again and got the "Can't find hard drive, contact support screen" I let the player sit then brought it home to re-upload the install file in the hope it would solve the problem.
During the upload, I get "Error “Bad pump response” occurred during stage 0x25”. " When I hook up terminal to it, I get the following
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.14-rmk5-np17-empeg50 (mac@aphex.internal.empeg.com) (gcc version 2.95.3 20010315 (release)) #4 Sat Dec 22 10:13:57 GMT 2001
empeg-car player (hardware revision 7, serial number 90000784)
Command line: mem=12m
Memory: 10968k/12M available (964k code, 20k reserved, 332k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004600).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:12:03:10
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...VFS: Cannot open root device 03:05
Kernel panic: VFS: Unable to mount root fs on 03:05
Now I know I am getting the error because it can't mount the hard drive but the upgrade tool doesn't seem to want to find the proper pump either. I have tried teh 2.0b11 and 2.0b7 images and nothing seems to load. SUggestions on what to do next? ANd if you suggest I use GetRight, I will need SPECIIFIC instructions on what to do. I don't think that is the problem tho because the player did work fine before unless it is not using the proper .upgrade file to load. Just grasping at straws there.
Greg
#106663 - 22/07/2002 18:18 Re: Bad Pump Response, looking for new ideas [Re: kazama]
Pump error covered in the FAQ here.
You are having disk drive or cable trouble.
#106664 - 22/07/2002 18:23 Re: Bad Pump Response, looking for new ideas [Re: tfabris]
kazama
Loc: Boston, MA
As I stated before, the FAQ says:
Try using the GetRight utility to re-download the upgrade file. See if that fixes it.
What are the specific instructions for using this tool to fix this problem? I am 90% sure it's a drive/software problem.
#106665 - 22/07/2002 19:06 Re: Bad Pump Response, looking for new ideas [Re: kazama]
The FAQ also says "It has also been reported that a bad pump error can be caused by disk drive problems such as a bad disk drive, problems with the cable, or an inadequate power supply which doesn't provide enough juice to spin up the disk drives."
It then links this which is what I believe your problem to be.
#106666 - 23/07/2002 00:12 Re: Bad Pump Response, looking for new ideas [Re: tfabris]
Loc: Los Angeles, CA
i got this error when i was upgrading my hdd. turns out that the ide cable was just unplugged from the main board.
#106667 - 23/07/2002 07:35 Re: Bad Pump Response, looking for new ideas [Re: tfabris]
kazama
Loc: Boston, MA
Thanks for the clarification on that. I will check the cables and the HDs tonight. As always, you are right on top of things Tony.
#106668 - 25/07/2002 11:56 Re: Bad Pump Response, looking for new ideas [Re: kazama]
eliceo
I get these errors about every 2 weeks, have replaced ide cable. Its funny because the last time this happened i reverted to the original ide cable, seems to work for now. I dont know if I have more serious problems with the rio.
