Chalk it up to Microsoft to not allow you to become an Administrator when you need the privileges without exiting every application you're currently working with.
Microsoft Windows 2000 [Version 5.00.2195]
(C) Copyright 1985-2000 Microsoft Corp.
C:\>runas
RUNAS USAGE:
RUNAS [/profile] [/env] [/netonly] /user:<UserName> program
/profile if the user's profile needs to be loaded
/env to use current environment instead of user's.
/netonly use if the credentials specified are for remote access only.
/user <UserName> should be in form USER@DOMAIN or DOMAIN\USER
program command line for EXE. See below for examples
Examples:
> runas /profile /user:mymachine\administrator cmd
> runas /profile /env /user:mydomain\admin "mmc %windir%\system32\dsa.msc"
> runas /env /user:user@domain.microsoft.com "notepad \"my file.txt\""
NOTE: Enter user's password only when prompted.
NOTE: USER@DOMAIN is not compatible with /netonly.
C:\>
Basically "su" with no balls. It works, but it's no Unix shell...
