I got the same thing recently, it recognizes the hard drives, however it complains about reading the superblock, haven't heard back from support yet, here's my hyperterminal session.
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg50 (mac@aphex.internal.empeg.com) (gcc versi
on 2.95.3 20010315 (release)) #7 Fri Feb 8 18:45:38 GMT 2002
empeg-car player (hardware revision 9, serial number 30102380)
Command line: mem=16m
Memory: 15024k/16M available (964k code, 20k reserved, 372k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004a80).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hdb: IC25N030ATDA04-0, ATA DISK drive
hda: IBM-DJSA-220, ATA DISK drive
hda: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63
hdb: IC25N030ATDA04-0, 28615MB w/1806kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:09:4
c
Partition check:
hda: hda1 < > hda2 hda3 hda4
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...XT2-fs: unable to read superblock
Kernel panic: VFS: Unable to mount root fs on 03:05
Empeg 50gig MkIIa (stolen :'(, my baby)
In an Impreza 2.5 RS-T
-also (new additions to the family)-
Empeg 10gig MkIIa
Empeg 50gig MkIIa
