I installed new software and get this:
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg49 (mac@aphex.internal.empeg.com) (gcc versi
on 2.95.3 20010315 (release)) #130 Mon Oct 22 18:52:07 BST 2001
empeg-car player (hardware revision 9, serial number 30103093)
Command line: mem=16m
Memory: 15024k/16M available (964k code, 20k reserved, 372k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004f80).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: FTJHTRU MHL2300@T, ATA DISK drive
hda: FTJHTRU MHL2300@T, 7935MB w/2048kB Cache, CHS=16382/16/62
smc chip id/revision 0x3348
SMC9194: SMC91C94(r:8) at 0x4008000 IRQ:7 INTF:TP MEM:0b MAC 00:02:d6:26:0c:15
Partition check:
hda: unknown partition table
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...attempt to access beyond end of device
03:05: rw=0, want=2, limit=0
dev 03:05 blksize=1024 blocknr=1 sector=2 size=1024 count=1
EXT2-fs: unable to read superblock
Kernel panic: VFS: Unable to mount root fs on 03:05
what does that mean?
