Here's how to get picker set up to launch this version:
1) Install hijack and preinit.
2) Copy the script at the end of this message to /etc/preinit.d/init_empgps.sh. Make the script executable with:
chmod +x /etc/preinit.d/init_empgps.sh
NOTE: This script will need another mount if you have two drives. I don't know which partition gets mounted in this case so haven't included it.
3) Make a directory /drive0/bin.
4) Put empgps and picker in that directory. Make them executable.
5) Make sure the binaries and script are executable!
6) Reboot.
If something goes wrong you will need to reinstall the player software from an upgrade package.
Note that the script does not allow other preinit scripts to run once it has.
Upon rebooting you should be presented with a menu for 3 seconds. Hit the top button to launch the player (or just wait) or the left button to launch empgps. Once empgps is loaded, press and hold the knob to bring up the hijack menu and select empgps from there.
Hope that helps!
I will add a baud rate selector. It may not help with the update rate though, on the units I have used that was fixed.
Rex.
#!/bin/bash
PATH=.:/usr/local/sbin:/drive0/bin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/root/bin:/usr/local/root/sbin
TERM=vt100
export PATH TERM
mount -n -o remount,ro /
/bin/mount -n -o nocheck,rw /proc
/bin/mount -n -o nocheck,ro /dev/hda4 /drive0
while :
do
#if grep -q '0 (AC Power)' /proc/empeg_power
#then
CUSTOM=`picker -t 3 1 "Player" "empgps"`
if [ "$CUSTOM" = "1" ]
then
/empeg/bin/player
else
empgps
fi
#else
# /empeg/bin/player
#fi
done
