Hi,
In reply to:
I'm confused as to why 4800 baud is a requirement. Didn't someone else describe (in a different thread in the "projects" section of this BBS) a fairly simple mod for his Peugot control stalk which talked to the Empeg at its default baud rate?
That was my project you mentioned. In order to cost ruduce the interface, lowering the baud rate would be the 1st step. Empeg also commented that they intended to set the docked-by-default baud rate to 4800 for use with serial GPS's etc. but was left at 115K for some reason. An empeg menu or Emplode advanced option is required to set the docked baud rate (ideally using an empeg menu).
Regards,
_________________________________________
John, (S/No 0114, 20G).
