I have a beatup empeg from a drive across the country that I am trying to bring to life. I hooked up a new 80gig Blue WD laptop drive and I can connect via serial.
I havent tested them, but the solder joints for the IDE cable visual seem okay and I have two IDE cables to test with. I keep getting Bad Pump Response using the Big Disk Builder to initilize the disk. I can hear the disk spin up. I've included the output from COM1 below. I tried everything in the fabulous FAQ to try but I am hitting the hoover dam on this.
Can anyone point out some warning signs for me or ideas to try? or is my empeg too beat up to come back to life!
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg55-hijack-v508 (hijack@rtr.ca) (gcc version 2.95.3 20010315 (release)) #2 Fri Jan 9 16:06:35 EST 2009
Checking for extra DRAM:
c1000000: wrote ffffffff, read e28cc001
empeg-car player (hardware revision 9, serial number 40103958) 16MB DRAM
Command line: mem=16m
Memory: 15000k/16M available (996k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Tuner: loopback=0, ID=-1
show_message("Hijack v508 by Mark Lord")
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004100).
empeg RDS driver initialised
RAM disk driver initialized:  16 RAM disks of 4096K size
empeg single channel IDE
Probing primary interface...
ide_data_test: wrote 0x0000 read 0xffff
ide_data_test: wrote 0xffff read 0xffff
ide_data_test: wrote 0xaaaa read 0xffff
ide_data_test: wrote 0x5555 read 0xff7d
ide_data_test: wrote 0x5555 read 0xffff
ide_data_test: wrote 0x5555 read 0xff7f
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:0f:76
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...VFS: Cannot open root device 03:05
Kernel panic: VFS: Unable to mount root fs on 03:05
Edited by JeepBastard (01/05/2012 00:03)
Mark I + Mark IIa | Jeep 97 TJ
my current blog
