Why would you want to use DHCP on your win2000 box? Have you got a DHCP-server running at home which should assign a second IP-address to your win2k box?
Just the opposite. The Win2k box is on the DHCP network at work. The fixed IP addresses are at home and I have no DHCP server at home.
So every time I'm at home, I need to configure the Empeg to be 10.0.0.43, and every time I'm at work, I need to configure the Empeg to be DHCP and to pull an address from my work LAN's pool.
If I don't do this, since the Work LAN's IP address pool is on a different subnet than 10.0.0, my Win2k PC refuses to talk to the Empeg even if I feed it the IP address directly.
___________
