I just had my mk2a upgraded to 32 MB. I loaded hijack v391 before upgrading.
After turning it on, it passed the memory test, but unfortunately the kernel
panic's soon afterwards. It always panics or oopses at the same spot.
I tried v390, v391 and v392 without luck. Hugo's bootloader did not have
effect either. Reverting back to v380, which I used before makes the
problems (and the extra memory) go away.
Here's a dump of a v392 oops using Hugo's e000.rom.
So, is this a hardware or a software problem?
Maybe we need a more thorough memory test?
Thanks,
Pim
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v392 (root@localhost.localdomain) (gcc version 2.95.3 20010315 (release)) #2 Mon May 24 15:31:28 PDT 2004
Checking for extra DRAM:
c1000000: passed.
c1100000: passed.
c1200000: passed.
c1300000: passed.
c1400000: passed.
c1500000: passed.
c1600000: passed.
c1700000: passed.
c1800000: passed.
c1900000: passed.
c1a00000: passed.
c1b00000: passed.
c1c00000: passed.
c1d00000: passed.
c1e00000: passed.
c1f00000: passed.
c2000000: wrote ffffffff, read 00000000
empeg-car player (hardware revision 9, serial number 40104351)
Command line: mem=16m
Memory: 31240k/32M available (980k code, 20k reserved, 524k data, 4k init)
Dentry hash table entries: 4096 (order 3, 32k)
Buffer cache hash table entries: 32768 (order 5, 128k)
Page cache hash table entries: 8192 (order 3, 32k)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
TCP: Hash tables configured (ehash 32768 bhash 32768)
Starting kswapd v 1.5
Signature is 206f6972 'rio '
Tuner: loopback=0, ID=-1
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004180).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hdb: IC25N080ATMR04-0, ATA DISK drive
hda: IC25T060ATCS05-0, ATA DISK drive
hda: IC25T060ATCS05-0, 57231MB w/1768kB Cache, CHS=7296/255/63
hdb: IC25N080ATMR04-0, 76319MB w/7884kB Cache, CHS=9729/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:10:ff
Partition check:
hdb: hdb1 hdb4
RAMDISK: Loading 320 blocks [1 disk] into ram disk... <1>Unable to handle kernel NULL pointer dereference at virtual address 00000020
memmap = C0004000, pgd = c0004000
*pgd = c012f801, *pmd = c012f801, *pte = c000000b, *ppte = c000000a
Internal error: Oops: 0
CPU: 0
pc : [<c002a9a4>] lr : [<00000020>]
sp : c0003828 ip : c1f98fa0 fp : c0003844
r10: 00000000 r9 : c0103f38 r8 : c0003868
r7 : 00000005 r6 : 00000000 r5 : c0103fd8 r4 : c0181740
r3 : 00000000 r2 : e58bc018 r1 : 00000005 r0 : c0181740
Flags: nZCv IRQs off FIQs on Mode SVC_32 Segment kernel
Control: C000517D Table: C000517D DAC: 0000001D
Process swapper (pid: 1, stackpage=c0003000)
Stack:
c0003800: 00000020 c002a9a4
c0003820: 60000093 ffffffff 00000000 c0103fd8 00000000 00000400 c0003860 c0003848
c0003840: c0033f14 c002a940 c1f98f20 00000800 00000000 c0003898 c0003864 c0033fdc
c0003860: c0033ea8 c1f90000 c0002000 00000000 00000000 c1f90000 00000400 00000100
c0003880: c0103f98 c0103f38 00000048 c00038b8 c000389c c003493c c0033f9c 00000400
c00038a0: 00000000 00000001 00000100 c00038cc c00038bc c003370c c00348d4 00000400
c00038c0: c00038fc c00038d0 c00338d8 c0033708 c00038fc 00001000 00000001 00000000
c00038e0: 00000000 00000400 00000000 00000048 c0003b58 c0003900 c003760c c00337b8
c0003900: 00000001 00000100 00001000 00000000 00000000 00000000 00000000 00000400
c0003920: c0003c68 00000400 c0191800 c0003c54 00093fa7 0800b2a1 ba03a7ff 6a949b67
c0003940: 4100008c 0246dd49 885805ff 8645bf6f a10398ea 060070d8 8e5c873f 6a11d3de
c0003960: 00401843 40121458 8431ebed af07aa77 9300eedb 1a20329c ba52bed7 ac15f7df
c0003980: 04114800 a050f8b3 2e7567d7 240028d3 8000f24b a0647f7f ae53bdff 5a601fae
c00039a0: 40180e90 cf57fae7 2b15ff7c 008926c8 00123d3a bae7fef1 2b5169d7 041230c4
c00039c0: 084495af 5255fc1b ac4f8fad 100430bd a0000013 c0003a30 c010d9ac c0003a00
c00039e0: c00039ec c000f580 00000000 0000001a 00000340 00000001 c0003a20 c0003a08
c0003a00: c00d51a8 c00bae30 00000000 00000000 c012c210 c011f244 00000000 c0121d68
c0003a20: c01120f0 c011f244 00000000 c0121d68 c0003a58 c0003a40 c00bb19c c001560c
c0003a40: c011f1d0 00000000 00000000 c0003a68 c0003a5c c00bbce0 c00bb0cc c0003a78
c0003a60: c0003a6c c00cf2e4 c00bbcd8 c0003a90 c0003a7c c0015d54 c00cf2e0 00000001
c0003a80: c0121dcc c0003aac c0003a94 c001e820 c01946e0 00000003 00000060 00000000
c0003aa0: c0003ad8 c0003ab0 c000ab68 c000a9d0 fa050000 c0003b24 00000001 c00e427c
c0003ac0: 20000013 ffffffff c0003c54 c0003b58 c0003adc c0009e60 c000aa6c c01918a4
c0003ae0: d00bd8a4 00000000 0affffec c00f4513 c011273b c0109018 00000002 00000000
c0003b00: 00000002 c011273e c0003b48 c0003b18 c0019830 c001560c 00000000 00000002
c0003b20: 00000040 00000400 00000400 c0003cc0 00000048 00000048 c0191800 c0003cac
c0003b40: 00000000 00000140 c0003c54 c0003f84 c0003b5c c00a1100 c00374a4 00000140
c0003b60: 00000005 00000000 00000000 000001fa 5c2d2f7c 00000000 00000000 c0003d04
c0003b80: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
c0003ba0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
c0003bc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
c0003be0: 00000000 00000000 00000000 c0003e30 00000000 00000000 00000000 00000000
c0003c00: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
c0003c20: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
c0003c40: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 c0003b74
c0003c60: c0108798 00000003 00012000 00000000 00000000 00000000 00000001 00000000
c0003c80: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
c0003ca0: 00000000 00000000 00000000 00000000 00000000 c0003be4 c010875c 00000001
c0003cc0: 00012400 00000000 00000000 00000000 00000000 00000000 00000000 00000000
c0003ce0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
c0003d00: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
c0003d20: 00000000 00000000 00000000 01000000 00000000 00000000 00000000 00000000
c0003d40: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
c0003d60: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
c0003d80: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
c0003da0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
c0003dc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
c0003de0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
c0003e00: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
c0003e20: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
c0003e40: 00000000 00000000 00000000 00000000 00000000 00000000 01fa0000 00000000
c0003e60: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
c0003e80: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
c0003ea0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
c0003ec0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
c0003ee0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
c0003f00: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
c0003f20: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
c0003f40: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
c0003f60: 00000002 00000080 c012aea0 c0122540 4401a11b c0008580 c0003f94 c0003f88
c0003f80: c00a12e4 c00a0d48 c0003fb4 c0003f98 c00468ec c00a12d4 00000001 c0100768
c0003fa0: c012188c c0108754 c0003fdc c0003fb8 c0009ac0 c00467b4 00000000 c0009b88
c0003fc0: c012b80c c0100760 c0100764 c0100988 c0003ffc c0003fe0 c0009b98 c00099b4
c0003fe0: c0009b88 c012b80c c0100760 c0100764 c00fffd8 c0004000 c000b6cc c0009b94
Backtrace:
Function entered at [<c002a934>] from [<c0033f14>]
r7 = 00000400 r6 = 00000000 r5 = C0103FD8 r4 = 00000000
Function entered at [<c0033e9c>] from [<c0033fdc>]
r6 = 00000000 r5 = 00000800 r4 = C1F98F20
Function entered at [<c0033f90>] from [<c003493c>]
r10 = 00000048 r9 = C0103F38 r8 = C0103F98 r7 = 00000100
r6 = 00000400 r5 = C1F90000 r4 = 00000000
Function entered at [<c00348c8>] from [<c003370c>]
r7 = 00000100 r6 = 00000001 r5 = 00000000 r4 = 00000400
Function entered at [<c00336fc>] from [<c00338d8>]
r4 = 00000400
Function entered at [<c00337ac>] from [<c003760c>]
r10 = 00000048 r9 = 00000000 r8 = 00000400 r7 = 00000000
r6 = 00000000 r5 = 00000001 r4 = 00001000
Function entered at [<c0037498>] from [<c00a1100>]
r10 = C0003C54 r9 = 00000140 r8 = 00000000 r7 = C0003CAC
r6 = C0191800 r5 = 00000048 r4 = 00000048
Function entered at [<c00a0d3c>] from [<c00a12e4>]
r10 = C0008580 r9 = 4401A11B r8 = C0122540 r7 = C012AEA0
r6 = 00000080 r5 = 00000002 r4 = 00000000
Function entered at [<c00a12c8>] from [<c00468ec>]
Function entered at [<c00467a8>] from [<c0009ac0>]
r7 = C0108754 r6 = C012188C r5 = C0100768 r4 = 00000001
Function entered at [<c00099a8>] from [<c0009b98>]
r8 = C0100988 r7 = C0100764 r6 = C0100760 r5 = C012B80C
r4 = C0009B88
Function entered at [<c0009b88>] from [<c000b6cc>]
r7 = C0100764 r6 = C0100760 r5 = C012B80C r4 = C0009B88
Function entered at [<c00096c4>] from [<c00098a4>]
Function entered at [<c00096dc>] from [<c0008080>]
r7 = C0121D60 r6 = C0121CB4 r5 = C012C240 r4 = C012C240
Code: e3530000 1a00001a (e58ec000) e5943008 e063500e
