Worked first try! 32MB available:
Checking for extra DRAM:
c1000000: passed.
c1100000: passed.
c1200000: passed.
c1300000: passed.
c1400000: passed.
c1500000: passed.
c1600000: passed.
c1700000: passed.
c1800000: passed.
c1900000: passed.
c1a00000: passed.
c1b00000: passed.
c1c00000: passed.
c1d00000: passed.
c1e00000: passed.
c1f00000: passed.
c2000000: wrote ffffffff, read 00000000
empeg-car player (hardware revision 9, serial number 10101626) 32MB DRAM
Command line: mem=16m
Memory: 31240k/32M available (980k code, 20k reserved, 524k data, 4k init)
But now I get weird stuff after it detects my harddrive. My primary harddrive died, so there's only my secondary in there now (without jumper = master). It started the player just fine before the RAM upgrade...
Will that go away once I add the new primary drive?
empeg single channel IDE
Probing primary interface...
hda: IC25N080ATMR04-0, ATA DISK drive
hda: IC25N080ATMR04-0, 76319MB w/7884kB Cache, CHS=9729/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:06:5a
Partition check:
Timezone: /usr/share/zoneinfo
Unable to handle kernel paging request at virtual address 0000df20
memmap = C0004000, pgd = c0004000
*pgd = c012f801, *pmd = c012f801, *pte = 00000000, *ppte = 00000000
Internal error: Oops: 0
CPU: 0
pc : [<c00330e0>] lr : [<c0033a34>]
sp : c01f7f84 ip : c01f7f94 fp : c01f7f90
r10: c0103fc8 r9 : c0108704 r8 : 00000002
r7 : 00000004 r6 : 00000001 r5 : 00000000 r4 : c1f79aa0
r3 : 00000004 r2 : 00000000 r1 : 0000df20 r0 : c1f79aa0
Flags: nZCv IRQs on FIQs on Mode SVC_32 Segment kernel
Control: C000517D Table: C000517D DAC: 0000001D
Process kupdate (pid: 3, stackpage=c01f7000)
Stack:
c01f7f60: c0033a34 c00330e0 60000013
c01f7f80: ffffffff c01f7fb0 c01f7f94 c0033a34 c003300c 00009a20 0000004e 00000001
c01f7fa0: 00000004 c01f7fe0 c01f7fb4 c003512c c00339cc c1f79aa0 00000001 c01f6000
c01f7fc0: c0104024 c0108794 c0100988 4401a11b c0008580 c01f7ffc c01f7fe4 c0035790
c01f7fe0: c00350a0 c0035720 c012b84c c0100760 c0003fb4 c01f8000 c000b6ec c003572c
Backtrace:
Function entered at [<c0033000>] from [<c0033a34>]
Function entered at [<c00339c0>] from [<c003512c>]
r7 = 00000004 r6 = 00000001 r5 = 0000004E r4 = 00009A20
Function entered at [<c0035094>] from [<c0035790>]
r10 = C0008580 r9 = 4401A11B r8 = C0100988 r7 = C0108794
r6 = C0104024 r5 = C01F6000 r4 = 00000001
Function entered at [<c0035720>] from [<c000b6ec>]
r6 = C0100760 r5 = C012B84C r4 = C0035720
Function entered at [<c001d36c>] from [<c0009b40>]
r10 = C0008580 r9 = 4401A11B r8 = C0122580 r7 = C0108794
r6 = C01218CC r5 = C0100768 r4 = 00000008
Function entered at [<c00099b4>] from [<c0009ba4>]
r8 = C0100988 r7 = C0100764 r6 = C0100760 r5 = C012B84C
r4 = C0009B94
Function entered at [<c0009b94>] from [<c000b6ec>]
r7 = C0100764 r6 = C0100760 r5 = C012B84C r4 = C0009B94
Function entered at [<c00096c4>] from [<c00098b0>]
Function entered at [<c00096dc>] from [<c0008080>]
r7 = C0121DA0 r6 = C0121CF4 r5 = C012C280 r4 = C012C280
Code: e5821034 e5803000 (e5812000) e59f10a8 e3a02000
32MB, serial: 10101626
