Tony, I was just thinking a little more, if the in car data does come out the sleeve port only is there a way to change the baud rate of the port on the Empeg itself when it is in the house on AC mode? If I could change that port then I could easily use it in the house for development work, otherwise I will have to try and access the sleeve port in the house without a sleeve attached.
Thanks much, Nick
