I made the upgrade with the (car2-builder.upgrade) file from the empeg homepage. It succeeded sucessfully.
After rebooting the player it displays "partitioning hd" and so on. But at the stage makeing directories it stoped for over 15 minutes. The serial log says:
Function entered at [<400c782c>] from [<0200c31c>]
r10 = 4002110C r9 = 00000000 r8 = 00000000 r7 = 00000000
r6 = 0200C2F8 r5 = 00000000 r4 = 40021A0C
init: permission fault on section, address=0xe5932200, code 2
pc : [<020131c0>] lr : [<0200f434>]
sp : bffff5ec ip : ffffd800 fp : bffffe24
r10: 4018c134 r9 : 02067930 r8 : 02080080
r7 : bffff62c r6 : bffffc6c r5 : 000000f0 r4 : 000000f0
r3 : e5932100 r2 : fffffffe r1 : 00000000 r0 : 0207d334
Flags: nZCv IRQs on FIQs on Mode USER_32 Segment user
Control: D03B917D Table: D03B917D DAC: 00000015
Function entered at [<0200f1c8>] from [<0200f034>]
r8 = 02080080 r7 = 0200C3D4 r6 = 400217C0 r5 = 00000000
r4 = 02081FCC
Function entered at [<0200efac>] from [<0200f154>]
Function entered at [<0200f078>] from [<0200ed88>]
Function entered at [<0200ebfc>] from [<0200cd10>]
Function entered at [<0200c3d4>] from [<400c795c>]
r7 = 0200C3D4 r6 = 400217C0 r5 = 00000002 r4 = BFFFFF04
r4 = 02081FCC
and so on ...
I powered off the empeg and updated the player once again with "car2-builder.upgrade" image. The upgrade wizward says "The upgrade has succesfully been applied" but after this it doesn't reboot at all!
The serial log always says:
empeg-car bootstrap v1.00 20000601 (hugo@empeg.com)
Copying kernel...
Calling linux kernel...
Uncompressing Linux.................................... done, booting the kernel
Linux version 2.2.14-rmk5-np17-empeg35 (mac@fatboy.internal.empeg.com) (gcc vers
ion 2.95.2 19991024 (release)) #13 Sun Aug 27 17:35:36 BST 2000
empeg-car player (hardware revision 7, serial number 80000251)
Command line: mem=12m temp=38
Memory: 11000k/12M available (968k code, 20k reserved, 292k data, 8k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
empeg display initialised.
empeg dspaudio driver initialized
empeg infra-red support initialised.
empeg state support initialised 0089/88c1 (save to d0004e80).
empeg single channel IDE
Probing primary interface...
hda: IBM-EASA-218101 ! ! ! ! ! ! ! ! ! ! ! !, ATA DISK drive
hda: IBM-EASA-218101 ! ! ! ! ! ! ! ! ! ! ! !, 8063MB w/418kB Cache, CHS=16383/16
/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:10:00:f
b
Partition check:
hda: unknown partition table
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...X]]Y[\]H]
)kkḱ役٥)5ӓ
݅ɱ)5ˁՁͥсŁ͕ѽɁͥсչ)5 E
XT2-fs: unable to read superblock
Kernel panic: VFS: Unable to mount root fs on 03:05
There seems to be a problem with the disc. Maybe a manual filecheck would help, but how do I get a shell prompt?
Any ideas?
Thanks
Rene
