While I was emplode over the ethernet, the player stopped working. (Download indicator hasn't moved) So I had to power off.
Now everytime I try to use emplode I get the error message: the download process failed during stage 2: Error 0xfffffff8.(For USB, serial and ethernet)
I uploaded the consumer and the developer image several time. But it still doesn't work. Any ideas?
At the moment there is no music on the player. When I reboot the player it say's End of playlist.
Is there a tool, which erase everything on the hole disc, including partition and then creates it as if the player was new?
Thanks
Rene
Here is the output from the serial line:
empeg-car bootstrap v1.00 20000601 (hugo@empeg.com)
Copying kernel...
Calling linux kernel...
Uncompressing Linux........................
mpeg-car player (hardware revision 7, serial number 80000251)
Command line: mem=12m temp=47
Memory: 11000k/12M available (968k code, 20k reserved, 292k data, 8k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
empeg display initialised.
empeg dspaudio driver initialized
empeg infra-red support initialised.
empeg state support initialised 0089/88c1 (save to d0004900).
empeg single channel IDE
Probing primary interface...
hda: IBM-DARA-218000, ATA DISK drive
hda: IBM-DARA-218000, 17301MB w/418kB Cache, CHS=35152/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:10:00:f
b
Partition check:
empeg-pump v0.03 (19980601)
change_root: old root has d_countTrying to unmount old root ... okay
Freeing unused kernel memory: 8k initEXT2-fs: #blocks per group too big: 1678566
4
empeg-car 1.0.
