e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v335 (root@ibbm) (gcc version 2.95
.3 20010315 (release)) #2 Tue May 13 15:01:19 EDT 2003
NetWinder Floating Point Emulator V0.94.1 (c)
empeg-car player (hardware revision 9, serial number 30103138)
Command line: mem=16m
Memory: 14996k/16M available (996k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
ttyS01 at 0xf80
TCP: Hash tables configured (ehash 16384 bhash 16384)ze 86 (adjustment 48Hijack:
empeg dsp audio initial
IrCOMM protocol (Dag Brattli)Starti
empeg dsp mixer
Starting kswapd v 1.5epting config.in
SA1100 serial driver version 4.27 with no serial options enabledalisedsignal 6ti
Using non
ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UARTa0k: intercepting config.inipp :12
! playe
em
ttyS02 at 0xf8030000 (irq = 16) is a SA1100 UARTment 48)eived signal
Signature is 636f6972 'rioc'
Remounting fi
Found custom animation at offset 0x9b720alised, PDIUSBD12 id 1012:UnabRestored t
Tuner: loopback=0, ID=-1
Scheduling custom logo.
Remounting seco
SMC9194: SMC91C94(r:9) at 0x4
empeg usb initialised, PDIUSBD12 id 1012d7:26:0c:4ayerly
empeg state support initialised 0089/88c1 (save to d0005180).
Hijack: intercepting config.inimounting second music
empeg RDS driver initialised
Starti
hda: hda1 < hda5 hda6 >
! player.cpp
RAMDISK: ext2 filesystem found
empeg single channel IDE signal 6layer
Probing primary interface...
hda: FUJITSU MHM2200AT, ATA
Ab
empeg-flash driver initialized0601)rly
smc chip id/revision 0x3349
Press Ctrl-A to enter pum
': not a valid identifieropts: `Op
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0c:4
Using non-s
Saved AC volume was 11adjustment 48)rcepting
2
Partition check:
V
Restored te
Mounting procsd signal 6fi
Using non-st
No secondary hard disk
Remounting first music partition read-onlydary hard diskrst music partition re
Remounting second music partition read-onlyAbnormal player terminationon read-onlymina
Press 'q' now to go into development modeStarting player
H
Hijack: intercepting config.inip
': not a valid identifieropts: `Option
No seconda
Re
Volume=11 terminal
hijack_exec("/drive0/var/ttsclock t2"), rc=0 (okay)
starting notify thread...
! player.cpp
notify thread started (tid=1026)...
Using non-standard cache size 86 (adjustment 48)
Remountin
lyrics thread started (tid=2051)... 48)Starting player
emphatic Restored terminal settings
U
Hija
Player received signal 6
Starting player
! player.cpp :1240:Unab€Restored terminal settings
Starting player
! player.cpp :1240:Unable to load default string table.ýRestored terminal
settings
it loop in final part:
settings
Jemplode and emplode don't have access
i cannot upgrade kernel
pls help me
I use WinXP only and 2.0beta13 + hijack 335
Rio Green 60Gb
