Here it is again:
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v320 (root@ibbm) (gcc version 2.95
.3 20010315 (release)) #2 Wed Feb 19 21:53:19 EST 2003
Processor: Intel StrongAR
empeg-car player (hardware revision 9, serial number 30102312)
Command line: mem=16m
Memory: 14996k/16M available (996k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
Based upon Swansea Universit
IP Protocols: ICMP, UDP, TCP
IrCOMM protocol (Dag Brattli)
Starting kswapd v 1.5
Signature is 206f6972 'rio '
Found custom animation at offset 0x98378
empeg display initi
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004280).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DJSA-220, ATA DISK drive
hda: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:09:0
8
Partition check:
RAMDISK: ext2 filesystem found at
empeg-pump v0.03 (19980601)
Mounting proc
Tried to mount /dev/hda4 as reiserfs but got error
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To ComðStarting
player
khttpd: listening on port 80
kftpd: listening on port 21
player.cpp : 385:empeg-car 2.00-beta13 2002/07/24.
Prolux 4 empeg car - 2.1434 Jul 24 2002
Vcb: 0x4086d000
1993 MR2 MK2a 32gb. 1991 NSX unfortunately with and IPOD.
