#93639 - 13/05/2002 14:40 Save&Replace option when changing playlists.
genixia
I'm using the Bookmark feature to switch between playlists, but I find it less than optimal. I'm always forgetting what is in each bookmark, and having to set a bookmark before replacing the current playlist is a pain.
What would make this really useful for me would be if the current running playlist & position were autosaved and labelled with playlist name and date saved, whenever the playlist got replaced (either directly through the playlist menu or the search function), and also to increase the number of bookmarks. (10??)
I think that this'd be great!
#93640 - 13/05/2002 14:46 Re: Save&Replace option when changing playlists. [Re: genixia]
thinfourth2
i asked a while back about getting renamable bookmarks or even better a small about line when each bookmark is selected.
Tony if you read this how does the jup or what ever it is called handle this feature if it has it.
#93641 - 13/05/2002 14:55 Re: Save&Replace option when changing playlists. [Re: thinfourth2]
I haven't messed with the bookmarks much on the Central. I think it's the same as the car player. Just a few predefined slots for bookmarks.
#93642 - 13/05/2002 15:14 Re: Save&Replace option when changing playlists. [Re: tfabris]
thinfourth2
So there is an argument for improving the way they are marked.
