#78754 - 08/03/2002 14:55 Shell mode on development kernel & Hijack
Amarth
Loc: Helsinki, Finland
I didn't find this in the FAQ.
How can I enter the shell-mode I was previously able to do with the 'q' key. Now my empeg just goes past it as I have installed Hijack (latest version just now and several versions before:
Press 'q' now to go into development mode. You Have Zero Seconds To ComStarting player
Empeg Mk2 090000839 (BMW 330Ci E46 -02) http://guildhouse.net/BMW330Ci/
#78755 - 08/03/2002 15:02 Re: Shell mode on development kernel & Hijack [Re: Amarth]
This is in the FAQ.
#78756 - 08/03/2002 15:09 Re: Shell mode on development kernel & Hijack [Re: tfabris]
Amarth
I just read it twice. Either I'm dumb or blind.. OR both. But I still can't figure it out. Q used to work pre-hijack, but alas, no longer.
Am I not seeing something?
#78757 - 08/03/2002 15:11 Re: Shell mode on development kernel & Hijack [Re: Amarth]
You're not seeing the sentence "If you just have the consumer software installed, you'll get:"
I'll re-word that FAQ entry to be more clear now.
#78758 - 08/03/2002 15:16 Re: Shell mode on development kernel & Hijack [Re: tfabris]
Amarth
Um. I have the development version of 2.0-b11 and hijack (2.2.14-rmk5-np17-empeg50-hijack-v235) .. I just upgraded it since my hijack 223 wasn't letting me into shell either.
My empeg bootup:
e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux...................................... done, booting the kernel.
Linux version 2.2.14-rmk5-np17-empeg50-hijack-v235 (root@tbird.localnet) (gcc version 2.95.3 20010315 (release)) #2 Fri Mar 8 14:49:23 EST 2002
empeg-car player (hardware revision 7, serial number 90000839)
Command line: mem=12m
Calibrating delay loop... 208.08 BogoMIPS
Memory: 10912k/12M available (1008k code, 20k reserved, 344k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004e00).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DJSA-220, ATA DISK drive
hda: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:12:03:47
Partition check:
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...ԕjչѕɽсɁѕɕ)5change_root: old root has d_count=1
Wѽչչсɽсokay
Mounting proc
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To Comp
Starting player
hijack: removed menu entry: "Home/Work Location"
khttpd: listening on port 80
kftpd: listening on port 21
player.cpp : 385:empeg-car 2.00-beta11 2002/02/08.
Loading dancefile: "/empeg/lib/visuals/breakdance.raw"
Loading dancefile: "/empeg/lib/visuals/stonkdance.raw"
Loading dancefile: "/empeg/lib/visuals/princedance.raw"
Prolux 4 empeg car - 2.1434 Feb 7 2002
Vcb: 0x4054d000
! mp3_decoder.cpp :1049:Failed to find valid sync after seeking to offset 4429915, error=0xc0044000
#78759 - 08/03/2002 15:25 Re: Shell mode on development kernel & Hijack [Re: Amarth]
I have no trouble dropping to the shell with Hijack installed. Works like it always has. You sure the serial port is working right? Have you rebooted the player and the PC? Have you checked the cable?
#78760 - 08/03/2002 15:27 Re: Shell mode on development kernel & Hijack [Re: Amarth]
peterk
Loc: California (Ex NZ)
wait till the player has started and then hit q <enter>
works for me on b11 dev hijack 200
PeterK
EDIT: From your initial post, it sounds as if you are expecting to hit q during the boot up sequence. The q is trapped/processed by the player so you have to wait till the player has started.
Edited by peterk (08/03/2002 15:29)
#78761 - 08/03/2002 15:29 Re: Shell mode on development kernel & Hijack [Re: tfabris]
Amarth
Hmm.
I just used the same cable to upgrade to Hijack ver. 235 (by using the kernel flash utility in the Logo editor). I took the cable and plugged it into my laptop (was in my desktop computer)...the same effect
Doing some more tests.
#78762 - 08/03/2002 15:33 Re: Shell mode on development kernel & Hijack [Re: peterk]
Amarth
I verified my terminal settings, they're correct.
I am getting output from the empeg on both of my comps' screens.
I even turned the RS-cable around (swapped heads), btw it is the same one shipped w/ my empeg.
I succesfully flash upgraded the hijack kernel through this same cable.
I tried waiting 5 seconds before any key-presses after all the boot messages had been printed.
It seems no key-commands go through to the player.
#78763 - 08/03/2002 15:41 Re: Shell mode on development kernel & Hijack [Re: Amarth]
peterk
when I go to dev mode from hyperterminal I hit q then <enter> as posted/discussed.
Thing is, I see the 'q' on the terminal screen (its echoed back to me)
Is this the case for you, do any characters you type in get echoed back?
PeterK
#78764 - 08/03/2002 15:44 Re: Shell mode on development kernel & Hijack [Re: peterk]
Amarth
No, nothing is echoed back.
I'm currently doing it the long way again from step 1:
1) Using emplode to upgrade to 2.0b11-devel.
2) Using LogoEditor to put Hijack 235 in.
Just downloaded everything from the appropriate sources again. Maybe something had went wrong in my previous installations or some old hijack version broke something .
I'll post info here ASAP.
#78765 - 08/03/2002 15:53 Re: Shell mode on development kernel & Hijack [Re: Amarth]
Amarth
ERM. After re-installing 2.0b11 developer image, I am still not able to enter the shell-mode with 'q'. At this point I have no hijack installed.
Maybe the sunspots are to blame?
#78766 - 08/03/2002 15:56 Re: Shell mode on development kernel & Hijack [Re: Amarth]
Amarth
OK.
I found the reason.
I'm using SecureCRT to connect through serial to the empeg. Even though I clicked RTS/CTS hardware flow control OFF, my existing connection re-did the setting back as I exited 'properties-mode' and 'disconnected'.
Sorry My bad. You might want to emphasize this in the FAQ once more. Now it works wonders. Thanks for all the help everyone. Especially the note about characters echoing back helped me trace back the problem.
#78767 - 08/03/2002 16:14 Re: Shell mode on development kernel & Hijack [Re: Amarth]
It's in red letters with the word "Important" in red, bold and italic. Don't see how that could be more emphasized...
#78768 - 08/03/2002 16:31 Re: Shell mode on development kernel & Hijack [Re: tfabris]
Amarth
Perhaps you might want to write an additional:
If you think you're doing everything right and still cannot access the shell-mode (or give any other commands through the serial connection), please check that your terminal settings' RTS/CTS flow protection has been turned OFF (default is usually ON).
Just after the "If your player is working properly, you can control it at this point by typing commands such as N (Enter) for the next track. A full list of commands can be found at the developer's site."
Your call, of course, though!
