#70384 - 12/02/2002 15:43 Has anyone installed a Tuner in an E34 BMW 5series
The_Optimizer
Loc: Texas
Has anyone here installed their empeg with a TUNER in an E34 BWM 5 Series (1989-1996) perferably one equipped with the full OBC (on board computer - not the digital Clock+Temperature module, or the analog face clock I see on some euro models)
My question is this: Is there enough room anywhere in the console close enough to the empeg unit for the tuner module to connect to it with the supplied cable, and if so where/exactly how did you install it? And if not, how much longer a cable was necessary to find the tuner module a mounting spot?
For those who wonder what I'm talking about, I was discussing the upcoming empeg installation on my 1995 M5 Touring with my longtime mechanic (who has previously done other custom stereo installations for other BMWs I've owned --- to excellent standards and results I must add), and basically it's just so very very tight in the cental console around the rear of the stereo due to the adjacent OBC moudule, dual-zone climate controls, wiring harnesses, and the heater core.
We're really not sure where to put the tuner module with the supplied length of cable. If we could get a longer connecting cable it would be no problem (we could move it towards the kick panel where there's plenty of room).
[green]-Matt Pritchard[/green] Riocar 60gig S/N : 010102081
#70385 - 12/02/2002 15:47 Re: Has anyone installed a Tuner in an E34 BMW 5series [Re: The_Optimizer]
Isn't the connecting cable a male/female straight-through?
Maybe just contact David at carsupport@riohome.com and ask for another tuner extension cable, then you could daisy-chain them. (Check and make sure your current one is good just in case he needs to replace it at the same time. )
Hugo, any problem with lengthening the cable that much?
#70386 - 12/02/2002 15:48 Before you all flame me... [Re: The_Optimizer]
The_Optimizer
Loc: Texas
Ok, I just saw the installation message board listed at the bottom of the main screen.. I'm moving the post to over there.
#70387 - 12/02/2002 23:43 Re: Has anyone installed a Tuner in an E34 BMW 5series [Re: tfabris]
Noise pickup may start to be an issue with long extensions, but it's worth a try. Ideally you want to extend the antenna cable, not the tuner interface cable.
#70388 - 13/02/2002 04:49 Re: Has anyone installed a Tuner in an E34 BMW 5series [Re: altman]
I stupidly extended the tuner interface cable by about 50cm for my Supra, and it does pick up a little bit of noise. I'm going to put it back how it was and extend the antenna instead.
#70389 - 13/02/2002 12:47 Re: Has anyone installed a Tuner in an E34 BMW 5series [Re: rob]
beaker
Loc: England
How is your Supra now Rob? Did you get the head skimmed OK?
