#6117 - 22/09/1999 22:53 'accelerated' volume
jfranke
What would be nice if other share that wish: If you are on loud volume settings, like -0 dB, it takes ages to turn the volume down to a low level. Would it be possible to change the behaviour, so the longer one presses the volume up/down, the faster it changes ? First slow, like now, than faster, like a 'logarithmic'behaviour. You know what i mean ? Any ideas ? Very unimportant, though....
Thanks, Jo
#6118 - 23/09/1999 00:29 Re: 'accelerated' volume [Re: jfranke]
Nils
Loc: Germany
sharing it ... that linear behaviour goes on my nerves too :=)
Minor but still a wish ...
Nils
#6119 - 23/09/1999 01:04 Re: 'accelerated' volume [Re: jfranke]
Happy Birthday schofiel
Do you mean something like a "Keyboard repeat", where if you hold down a key for a second it operates once, then after a delay starts to repeat at a pre-set rate?
#6120 - 23/09/1999 01:42 Re: 'accelerated' volume [Re: schofiel]
Nils
Loc: Germany
No, that is, like it is right NOW, what he means ( i hope so ) is:
The repeat rate accelerates, so for example:
The first second the volume de/increase is repeated, it gets 5 dB de/increased, if you still hold the button, the second second it gets de/increased 10 more dB, then 15 per second and so on ...
Nils
#6121 - 23/09/1999 05:16 Re: 'accelerated' volume [Re: Nils]
danthep
Loc: new zealand
Yes, this feature would be great!!!
Especially useful when switching from tuner to mp3. On my unit the tuner is much quiter than the mp3 players, so if you have the radio at a nice level you get blasted switching back to mp3.
#6122 - 23/09/1999 08:31 Re: 'accelerated' volume [Re: danthep]
Mark Petersen
Loc: Denmark, Kbh Ø
Way not have a setting that for an ofset FX radio = +5
so when you switch around it go up and down
Mark
emaks rouls
Mark wait for mk III with a USB Host/slave (USB->GPS)(USB->Bluetooth)(USB->You name it)
#6123 - 23/09/1999 12:00 Re: 'accelerated' volume [Re: Mark Petersen]
The radio should be boosted to the same volume - this was in pre-beta1 versions but vanished for some reason. It'll go back in (hopefully) in the next release.
#6124 - 23/09/1999 23:44 Re: 'accelerated' volume [Re: altman]
Henno
Loc: Meije, Netherlands
Altman,
Having an input offset that adjusts the relative output of the line-in vs the empeg would be very welcome.
Could you, at the same time, put in a decelerated (mute) function?
My home pre-amplifier provides for a user define mute function that quickly reduces the output level by a pre-defined amount (1-60 dB); factory setting is -20 dB, but can be changed by the owner.
Whenever mute is pressed, the mute-offset is applied. Pressing it again (without adjusting the volume in the mean time) restores the original output level. Any volume adjustment (accelerated or linear) kills the latter feature and applies the mute offset on the newly set level.
Would be nice to have, especially if triggered by an incoming phone call (via serila connect??)
